PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Typical MAP and Ign Advance values at idle for 496 MAG HO?
  2. Spark Plug Wires - MSD, Taylor, Multi Fire... which ones are best?
  3. K plane seal or rebuild kit?
  4. How to ID a 502 from a 454
  5. Going in Guardian mode
  6. 500 EFI breather tubes
  7. Hard to start 502 mpi
  8. 525 efi issue
  9. merc gen 2 remote
  10. 502 MAG EFI build reccomendations
  11. please help with a 525 EFI problem
  12. H or P main & rod bearings
  13. 8.1 Volvo Penta serpentine belt
  14. 500 EFI placard
  15. HP transom assbly torque
  16. West Coast Offshore Engines
  17. replacement block for 525SC
  18. time to step up to the plate
  19. How To Eliminate Corsa Quick & Quiet Exhaust?
  20. anti siphon valves
  21. Timing set for GenVI. Any favorites?
  22. help with a 1978 28ss cig twin 350 /trs
  23. New starter not working
  24. Insta trim 200 gauge
  25. 496 offshore mounts
  26. Old school BBC not starting
  27. Help picking 525SC rebuild cam
  28. Electric fuel pump kit Mercruiser ?
  29. 496ho troubleshooting start but engine sounds like its forcing 😢😢😢
  30. Easy 100HP Gain on 6.2 MPI...
  31. Motor rebuilds for 454 with blowers
  32. low on power any ideas?
  33. Raylar 600 HO
  34. anyone know?
  35. Sticky valve guide
  36. on-board battery chargers....
  37. 525 ps pump
  38. W/F code
  39. 496HO Cuts Out at Idle in Gear...
  40. Question re: MSD 6m-2L / blaster ss Ignition problem
  41. Everybody's favorite game....what cam is this?
  42. Need knowledge
  43. Bravo one outdrive Oiler line block off
  44. 1980 260 merc exhaust elbow gasket question
  45. Fuel Injectors-Cleaning and flowing
  46. Getting water in boat
  47. 454mag mpi surging
  48. Finalizing blower..need help with sizing
  49. 454 mag vst problem please help
  50. 500 efi fuel consumption?
  51. 502 Compression and Milky Oil
  52. bolt thru steel or aluminum ?
  53. Fuel injection VS Carburetor
  54. Trim TAB Question
  55. Push rod length
  56. 383 stroker longevity
  57. Merc 8.2 B3 380hp problem
  58. 2000 502 mag mpi engine code 14
  59. Forced Induction EFI or NA with a Carb
  60. Surveyor in California?
  61. TRS trim wiring issue - “black box”?
  62. Will this block work?
  63. Oil pumps
  64. 500 efi
  65. Sunsation Innovator help
  66. 502 EFI problems again
  67. Switching forward and reverse on shift lever
  68. Fuel pump not kicking on with key 500 efi
  69. 2001 575 sci 1 seconds beep every 3 seconds?
  70. Steering cables interchangeable - Ssc12416 and ssc13016?
  71. 88 Baja sport 226 exhaust
  72. 2000 502MPI Hard Start
  73. Overheating problem
  74. 1985 wellcraft nova
  75. Captain call exhaust
  76. 502 not starting
  77. Lost part
  78. Tach not Working
  79. 496HO issues
  80. Smartphone Borescope
  81. Ignition shutting down when WOT.
  82. Need plastic elbow for 99 454 mag efi flame arrestor
  83. Trim pump self emptys!
  84. Importance of intake oil heat shield in 500efi
  85. 500 efi with a 525 cam installed
  86. Fuel pressure issues 600 SCi ??
  87. Need help..500hp blue motor. GenV.
  88. High engine temp and 502Mag MPI Exhaust riser gasket replacement
  89. 1998 Volvo Penta 5.7GSI
  90. Electric problem
  91. Stainless Steel T-Stat Housing for 502
  92. What Spark Plugs For 525?
  93. worn out B1 HP transom assemblies.... question...
  94. 525 SC Fuel Pressure
  95. Bravo 1 up trim not working works with separate trailer switch
  96. Mercury Optimax Fault Codes
  97. Oil leak?
  98. 502 MPI - Rich, sloppy idle. Fuel Pressure?
  99. High rise exhaust help with reversion?
  100. Another Cam recommendation
  101. 525 efi please help alarm going off codes 120 122 123
  102. Mercruiser 8.1 missing.
  103. -2 shorty drive on Checkmate 253
  104. 500EFI Overheat
  105. Here’s a riddle, Runs in start but not in run
  106. 496 ho temp
  107. Where should AFR readings be for MPI 509
  108. F292sr1 help!
  109. Widebands and sensor location
  110. Push rod Length
  111. K-plane pump question
  112. .??“ BRAVO X VS XR” ?? 4,000lbs boat 630hp
  113. Can I reuse my gaskets in between my elbows and header?
  114. Need help
  115. Help can’t get the inner exhaust flappers out!
  116. WHere does this ground wire go..hp500
  117. Old bravo 1 help
  118. How long did your exhaust flappers last?
  119. Need Help, 525 Engine Problem
  120. Valve lash caps?
  121. Need advice on new 401 SBC stroker build
  122. Hit a snag in my build..need help asap
  123. 525 SC Alternator Question
  124. Need help 525 EFI Miss firing after rebuild please!!
  125. BB502 MPI question
  126. Slipping Coupler or Prop Hub?
  127. TBI on a bbc marine application. Bad idea?
  128. Valve Springs with 741 cam
  129. Imco/Bravo gimbal bearing
  130. GGB muffler inserts
  131. questions about temp warning sender 7.4 MPI
  132. 502 mpi coil fuel pressure issue
  133. 500 EFI removing prochargers
  134. Fast fuel injection
  135. 525EFI Water Pressure Concerns
  136. Merc 502 Alarm
  137. TPS reset on merc 350
  138. 502 mag efi fuel pressure connection point
  139. Hardin Two Stage Sea Pumps Leak - 700sci
  140. 2006 Chaparall 496 MAG twins. Low Coolant pressure
  141. fi tech fuel injection
  142. 500 EFI High temp Low pressure
  143. 100 ll
  144. mirage solid hub prop
  145. 496 help?
  146. 575SCi mechanical fuel pump - Rebuild?
  147. Marine Machine still in business??
  148. Pressure testing Manifolds
  149. Mercruiser engine ID tags
  150. Exhaust thoughts for small blocks
  151. Boostline Connecting rods making a little JAM
  152. HP from Frankenstein motor
  153. Fuel Pressure Qusetion
  154. 500EFI cam into
  155. 502 mpi 95 octane
  156. Counter Rotate Whipple?
  157. 496 water circulating pump
  158. 502 build advise
  159. Valve spring retainers
  160. 496ho Ignition Troubleshooting
  161. 525EFI - How to clear heat exchanger???
  162. Lost all power steering fluid....
  163. BBC Crossover Temperatures
  164. Prochargers N Boost..
  165. 2003 496 mag
  166. 500 efi knock sensor
  167. Water pump 500 EFI
  168. Bravo 1 Built With Wrong Gears?
  169. Value of 496 pcm
  170. Cam bearing material?
  171. Fuel pressure loss at high rpm
  172. Maximum afrs in individual cylinders
  173. Fuel pump location
  174. Flame arrestor selection
  175. Tall deck to standard deck exhaust
  176. Arneson surface drive on single engine vee
  177. Buying a 40 Outlaw
  178. LSA swap, trying to figure out throttle linkage/cables?
  179. computer reprogram
  180. Twin Mercs 5.0 MPI running rough/stalling
  181. How to break in new motor - 275 Baja
  182. Fuel line size?
  183. Tall deck / stellings 2 1/8" center to center
  184. Calling BUP
  185. Post 02 sensor rusted/ partially plugged
  186. Valves still leaking after 2 machine shops did valve job
  187. 525 sc or 575
  188. Dual power steering system
  189. Mystery hose in transom assy???
  190. fuel pressure sender
  191. Power loss with Imco Scx upper and Imco -2 SC lower
  192. 454 mpi hard cold start
  193. 500EFI injectors
  194. 496 Mag / no more belt noise
  195. New 548 builds, AK Racing heads
  196. Dyno sheets
  197. Can the Formula 330 handle bigger seas?
  198. rear cover leak
  199. help with fuel pump selection
  200. Safe compression for 89 octane
  201. 350 EFI TBI Mods, cam, heads, intake, tune, 383?
  202. Fountain 12M
  203. Fontain 27' Fever Hatch
  204. Need help with identification
  205. 496HO Sea Pump/Block pressure high on Rinda Techmate Pro
  206. 2000 454 mag mpi starts and dies
  207. renitriding a crankshaft
  208. Hardin Marine oil filter mount leak fest
  209. Headers using closed loop to cool
  210. Flaps or windscreen
  211. 1998 29 outlaw twin 454 procharged and intercooled
  212. Chineese aluminum heads
  213. Cable steering safe?
  214. seapump wear holy cr@p !
  215. Strainers, stainless or aluminum?
  216. Alternator Pully ?
  217. Water pressure too high after adding back rec pump
  218. Bravo 1 upper unit rebuild questions
  219. 1998 29 outlaw twin 454 procharged and intercooled
  220. 29 outlaw
  221. Flame arrestor
  222. How to remove Shotgun slip on exhaust tips
  223. Stud girdles a good idea?
  224. 6V-71 Recomendations
  225. 502MAG mpi header question
  226. Need a little help here..
  227. Fuel filter cross reference???
  228. Stellings condensation??
  229. Xm270hr cam questions
  230. Let's hear cam suggestions
  231. Mercury 525 exhaust valves
  232. fuel line/rail leak
  233. ARP head studs 525 EFI
  234. Which intake manifold sbc 350
  235. Sportmaster -2 anodes same as Bravo 1
  236. blower pulley sizing help
  237. Estimated HP output - Build Sheet attached
  238. Scarab „High Output“
  239. Quality CARB SUGGESTIONS
  240. Overheat alarm sounding
  241. 24 (22)x7 X-dim
  242. Baseline Jetting - HP500 Carb on 454 Magnums
  243. 500 to 525
  244. ,freshly rebuilt 500 EFI,s won't restart after run
  245. Small block Chevy valve cover afr Heads and stock exhaust fitment
  246. 454 longer rod & shorter piston OR shorter rod and taller piston?
  247. I think i lost TDC. HELP
  248. Camshaft Identicication
  249. shift interrupter relocation pics please
  250. Best prop
