View Full Version : General Q & A
- Fuel line headaches. What can I do?
- Flame Arrestor Filters- COOL!!
- Help, Can't get my dist. rotor off!
- prop experts....mich wheel rapture vs mirage
- Royal Purple
- HoustonPropeller back on board Monday
- where can i get a pulley
- Xantrex Battery Chargers
- Aqua Buff
- Llooking for alternative to TRS drives
- Re-Painting an Outdrive question
- Installing a Merc Remote Oil Filter Kit
- I got some water in my oil - what should I do?
- Bravo Question
- Cd changer/ amp in engine compartment
- How much engine damage did I do?
- How many quarts of oil in a #6
- drives
- Need Carb advice
- Disc brake conversion
- sbc heads
- which Pwr steer brkt for Procharger??HELP
- Problem with IMCO dual ram steering
- SET-UP HELP/ V bottom w/outboards
- Tri Sonic
- fuel pump relay?
- Gaffrig RedLine Temp Guage
- where's the best place to mount Regulator
- fuel pressure sending unit.
- Prop Hub Change Out?
- Need Help with exhaust gaskets for SBC Vortec Heads
- whats a better block? World or Dart
- Anyone Using Psi Blowers
- Big Block Chevy Intake decision
- Trailer Bunks
- 2000 500HP Carb
- ID Oil Pan
- Pinging under medium to heavy throttle
- Need LOTO Area Powdercoater
- New cockpit flooring?
- Air in Trim Tab Pumps
- 25' with 250 Mercury OB
- Set-up help w/outboards
- wiring sch. for 29 fountain 1990,help,short?
- Whose drive reservoir foams and whose doesn't???
- Sea Strainers????????
- best spot to visit?
- Jetting/tuning For Procharger setup
- TrimTabs Question
- 540 whipple compatability
- Holley 3310-S
- Flame arrestor on procharger
- Finally got it started now it knocks
- SBC valve guide/seal leakage?
- Need new Dipstick...An Oil one
- Bravo XR questions
- pulleys
- Valve Job
- Recessed Holders
- rev marine drive resorvoirs
- Repower to 350 MAG MPI
- 525sc Oil Coolers
- Sunstream Floatlift's??
- 8mm blower belt change?
- Mercury 575 problem resolved!
- #1 tip to add to your spring checklist
- High speed eyewear
- Stingray Cuddy 20 ft.
- EGT's ,,,why so many diff. #'s??what's hot
- Flywheel Housing Question
- Exhaust Noise Limit?
- amsoil bypass filter
- Exhaust Bellows vs Tube
- Air-Dock boat lift
- new headers
- Drive Upgrade on a charged HP500
- Rocker Change
- Relocating oil filter
- Gil / Merc HP500 Manmifold Freeze Plugs
- This doesnt seem right
- perma cool fuel filter #81794 hi flo
- Sticking Exhaust Solenoid
- 502 MPI intake
- Bad temp Gauge (attn 97BossHammer)
- Gaffric controls adjustment??
- Cigarette Swim platform
- Water temp sender/Oil pressure sender?
- Cleaning and Painting drives and boxes
- mercruiser inboard engine doesn't want to go foward
- Maximum stroke in a 427 tall deck block?
- Re-plumbing for center rise manifolds?
- high volume water sep/filter??prochargr
- Another 540 Cam Thread?
- small oil leak?
- ARGH!! Rods hitting cam! What canI do?
- Need help with SBC Vortec Springs.
- S/B rod clearance?
- 454 mag
- Manifold pressure gauge
- raising the riser
- Distributer Problem
- Boat Audio
- Msd Rev Limiter With Tb5
- too embarrassed to ask
- 1.36 vs 1.50 Bravo One
- New Carb
- Will 2000 bravo lower fit a 1996-1998 bravo upper?
- Pulley hits new water pump.
- bell housing hinge pins
- Need 1996-1998 Bravo Lower...Help?
- 302 to 5.0 engine swap
- 350 mag won't start after new plugs
- Gen VI block, Mark IV heads....???
- spark plugs/high tension leads?
- multi viscosity motor oil
- Amsoil 75/90 in the drive
- Old Fire extinguishers
- Marine transmissions which ones?
- L-29 Vortec heads
- Polyester gel over marine tex
- What do you know about #3/3A drives?
- Oil Change Question
- Need help selecting an on-board battery charger
- beaten to death oil topic
- Looking for pump to change oil
- fuel lines?
- cooling/heating ac unit
- k plane size on 35 fountain late model
- Trim Tab Help Needed
- Fuel pump cam lobe excessive ware???
- Removing Bravo One
- Americn Offshore 2600 ???
- IMCO valves - best prices?
- Bravo 1 HP Gimbal Question
- prop work
- Need A Bbc Recirc. Pump Pulley
- Water reversion with Crane 741 cams
- Upstate NY boaters
- rev limiter
- BB Chevy heads
- where does the rev limiter live?Module?
- paper thin bravo
- edelbrock performer 2.0
- Removing # 6 Drive Spacers
- some problems twin 454 wellcraft
- 2 Charged 383 instead of 2 x 454 ?
- Who Rebuilds Marine Carbs?
- Droupy Drives
- Best Cam For A Mark 4 Bbc?
- Horn Sounding
- Merc 454 MPI dead in water
- 1990 454Magnum Locked Up?
- Whipple Intercooler comparision
- Is the cam change worth it?
- Lifters Lifters Lifters
- 502 Mag Hp
- Harmonic Balancer Bolt Torque?
- Calcium/scale
- Pros/Cons of a cleaver prop?
- ss windshield 382 fastech
- Billet Shifter Drive?
- soft transom!
- Roller cams, cons.....pros???
- Compression Readings on 454, 330hp
- Looking for belt drive pwer transmission parts
- water pressure sender, elec or mech?
- sealing transom opening
- oil temp sender location ?
- HP500 EFI owners - clearance measurement
- Need Merc PN
- Whipple Charged - fourth season
- Mercury hydraulic steering
- Block Pressure?
- TRS Tranny Question
- carpet
- Alternative engines
- bravo ???
- gps/color plotter
- Procharger Help needed
- upper steering shaft seal
- Opinions Wanted
- Weight of a Bravo vs a #5
- 5-Blades
- Donzi 22'and Blackhawk out drive
- Regular Power Steering Question
- fuel pick-up/check-valve?how to tell
- Timing problems - Help before I take a sledge to the motor!
- Prop Cavatation Problem
- Installing Corsa silent Choice
- Out Drive Corrosion Volvo Duo Prop
- making a boat offer
- Gen IV camshaft end play
- Fountain Steering reservoir!
- Little crush or compression washers?!?
- Gen? Roller?
- Stereo wire harness??
- Prop question
- B/W tranny ?'s
- Grease 101
- TRS drive oil
- motor set too high on stern
- DPX Steering Helm
- 502 operating water temp
- 496HO Surging?
- Bravo1 oil capacity w/o reservoirs?
- Whose running turbos?
- Gimble bearing play
- 502 MPI Fuel Pressure
- closed cooling
- Bravo Drive Noise
- Eagle trailer brake question
- Bravo transom mounting?
- K-plane problem
- carb jetting
- Bravo Drives
- What are these heads?
- ssm-v & bulldog500
- took out the krytonite for the first time.
- Impeller Question
- Leaking riser?
- Carbed HP500 Cam and valve spring specs
- Stainless manifold bolts?
- Thermostat
- Thunderbolt IV Ignition Coil
- How do you install freeze plugs?
- New High Performance Mercury Urethane Ram Bushings
- Billet pulleys - alignment
- Marine circuit breakers
- water circulating pump vs. crossovers
- Propeller qeustions?
- Adjusting Holley 750 Marine Carbs
- 434!!!
- Chris Craft Stinger Operations/Maintenance Manuels
- What Fuel Octane
- Help Please With My Mecury....
- Merc 575sc's & Mobile 1 15W50
- 300hp vortech
- Merc "Silent Choice", How Much?
- Alternator 4 wire to 2
- RM Builder. . .did you get that
- corsa muffler tips power restriction ?
- MSD coils
- Marine Generator Help
- Prop suggestions for new 271 power
- Internal Flappers replacement??
- Power Steering pulley puller
- Corsa Flappers
- Whipple Charger for a Fountain
- Yellow hull stains
- Possible bad valv job on SB Vortec heads?
