PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. TB IV timing different from G5 454 to G6 502?
  2. 454 Magnum EFI experts, I have some questions regarding a pending boat purchase
  3. Mercruiser power steering pump vs. Automotive pump
  4. Shipping a BBC
  5. Need Trim pump ID from KAAMA boats PIcs inside
  6. Mechanical fuel pump
  7. flushing without Drives?
  8. Good oil thermostats??
  9. Fuel issue
  10. What size carbs for B&M 250 blowers
  11. Saltwater used engine
  12. Ditch MerCathode for Anode Protection?
  13. Carpet Backing
  14. Mercury Verado 300's
  15. The rookie
  16. Best way to mount stand up bolster seats
  17. Header feedback
  18. 525 EFI question....
  19. Looking for cam ideas 5.7 Vortec Carb
  20. K/E Spring Oilers
  21. low compression 548 dyno testing has begun!!
  22. new standard lower
  23. Big cube 454 for fun
  24. 500efi hp gains
  25. WTB Air Dock Lift
  26. Rochester Quadrajet
  27. HP500efi Cylinder Heads
  28. Rigging/plumbing things
  29. Supercharged 502 versus HP500's
  30. Edelbrock EFI fuel pumps
  31. Where to buy windshield grommets for windshields?
  32. Will the Canton 90 Degree oil filter block adapter support both filter & cooler?
  33. Timing set for gen v block with step nose cam
  34. What happened to black baja
  35. BBC blower pistons.
  36. HP 500 Rebuild expertise
  37. Where to buy "Stainless marine" exhaust gaskets, disk gasket between the manf. &pipe
  38. Which Gimbal Anode? Two Part #'s Showing.
  39. Oil pans BBC
  40. Would you be afraid of buying a boat with these motors?
  41. Oil filter head.
  42. Need slightly taller 502 valve covers...
  43. Innotech dash panels??? Still in biz???
  44. Who's got a desk top dyno?
  45. 1985 454 best heads to use?
  46. Valve Cover Options , Opinions Needed
  47. Found something inside a coolant hose
  48. Tail pipe builder Grand Rapids MI area
  49. Bbc SC deck height
  50. Dump the Carb, intake, or both?
  51. Moisture in valve cover
  52. 540 build exhaust question
  53. Stainless marine to stellings width issues?
  54. Changing gear oil in mechanical fuel pump in 525EFI...
  55. Question on intakes
  56. Carb CFM
  57. 525,600,700 header gaskets
  58. 496 water actuators
  59. Solid roller duration vs hyd roller duration.
  60. Spark Plugs 496HO
  61. Did they ever make a 350 Vortec engine with a fuel pump boss?
  62. Merc 700sci
  63. Refinish Bravo One in Detroit
  64. another cam thread
  65. P5 Hydromotive Props on Formula 382 with 500 EFI
  66. Replacement oil filter/cooler lines/USCG approval?
  67. Adjustable guide plates
  68. Is anyone running an in the tank fuel pump?
  69. Were can I get these
  70. Moisture in heads and top side of Valve cover help.
  71. Trim Tabs quesitons
  72. 496 mag HO longevity
  73. extension box on this typ of hull and transom?
  74. cam suggestion
  75. engine oil temp sender
  76. Some videos thought I'd share .
  77. Fountain dash panel labels
  78. Drive shower option
  79. upgraded 500efi shift issues
  80. Impermeable Masking (Type) Tape?
  81. 502 engine build
  82. Extension box?
  83. Sea strainer install question
  84. Some Saturday Motor Fun
  85. 330hp 454 Flame Arrestor work on a 502HO?
  86. Afr heads with PAC 8002 spring upgrade.
  87. Gen V heads on a Gen IV block head gasket?
  88. Carb question. 850 vs 800
  89. LED Docking lights, any experience suggestion.
  90. Carb question
  91. Cam Question
  92. Need boat surveyor in NJ near Atlantic City/Little Egg
  93. Hawaiian jet boat
  94. Does Silent Choice contribute to reversion?
  95. 2.3L whipple blower Safe Limits
  96. Will carb need rejetted?
  97. Blower surge Make it stop
  98. 502 Mag Rebuild
  99. Heads Iron Vs alunimum
  100. Anyone seen gear lube leak out of water intake?
  101. Mercruiser 400 cyclone info needed
  102. Not fast enough, help!!
  103. Used merlin heads worth anything? 1 is cracked
  104. Imco sc -3
  105. Got my heads back fresh with a little clean up and a cam suprise
  106. Mercruiser 7.4 454 mpi overheating?
  107. Gen 6 firing order question
  108. Scorpion rockers
  109. Carb spacer or no ?
  110. Cam identification, please.
  111. Merc 600 SCI IAC 1 Amp Fuse Install
  112. Promaxx 320 flow numbers
  113. What Does OSU Do On Gibraltar Island @ PIB?
  114. Muscle car related vacuum advance vs piston speed
  115. installing imco +3 box, dropped
  116. Stamped Engine ID #'s
  117. Bad set of rings?
  118. Need a pic of p/s pump on 454/502 MPI v-belt engine w/ ProCharger
  119. idle adjustment 575 sci
  120. Injector cleaner
  121. 525 Repair Costs??
  122. Need some advice,procharger or 177blower
  123. 502 MPI aftermarket exhaust manifold
  124. Magic VooDoo 39 - any information appreciated!!!
  125. Can someone tell me year this engine is? Serial Number is
  126. engine question, good base or not
  127. Hub kit
  128. Roller rocker debate
  129. Bravo XR Trim Insert Adjuster Positioning
  130. Gen VI 489 +20 build
  131. Need Hydro Hoyst, Air Dock for 38' boat
  132. 604ci Nortech motors
  133. Deleting cooling hose merc BBC
  134. Need Crand HI-6M instructions
  135. Impeller and hose trouble with Hardin pump
  136. 496 crank kit, quality & fair priced kit for home builders. Help
  137. transom straps
  138. 1996 formula 27 sr1 graphics
  139. Hull issues
  140. Bandit motors
  141. Help identifying engines
  142. Manifold Longevity
  143. hp 500 carb question
  144. Oil Pressure
  145. anyone know this guy on here
  146. SSM Exhaust
  147. Hynautic Steering Question (Not smooth when wheel turned)
  148. Transom Plates
  149. Arneson Drive traits
  150. 1981 Scarab S Type 330 TRS. Outdrives can easily move either direction not running.
  151. Premature main engine bearing failure mystery
  152. Lobe separation
  153. AFR 300 magnum prices
  154. Needing help with h i n #s help help
  155. Teague 825 EFI Vs Merc 525 Supercherged Stage 1 Whipple
  156. Whipplecharged 540 maintenance
  157. blower height above crankshaft
  158. Professional Motor rebuild question...
  159. Converting to closed cooling
  160. Oil pressure sending unit mounting orientation
  161. Question on bravo gimble
  162. distributor gears.
  163. Converting EMI Thunder wet passage riser gasket joint to dry.
  164. Magic 28ft Deck Boat 525 Whipple Upgrade
  165. Pulling 330 TRS Engines tips and tricks been awhile 81 scarab S Type
  166. Hey Full Force Tim
  167. Daytona
  168. Supercharged 540 Camshaft
  169. Overheating 350 in 1977 scarab 300
  170. No wake zone low speed miss
  171. Manual oil temp control??
  172. Gen v 454 merc mag efi cracked block, replace block or entire engine??
  173. Help - Need parts for a 7.4L/454ci GM Delco Voyager EST Distributor
  174. When should heads be rebuilt/serviced with closed cooling ???
  175. Please help! 89 Johnson 90hp
  176. Who wants to play
  177. rocker studs bb gen 6
  178. Sonny Leonard Engines
  179. Battery boxes
  180. 525 intake manifold vs 502 Mag intake manifold
  181. Manifold question
  182. Cam question (Whipple 500efi)
  183. Solid roller lifters?
  184. DO cool fuel lines go bad? Got a kink in one of mine.
  185. Drive and Tab cable length for 81 Scarab s type.
  186. slop in throttles 81 Binnacle mount single lever twin throttle shifters
  187. Better option for Fuel Filter/Water Seperator?
  188. Stem Pocket Lines on 502 MPI Intake
  189. 6.2 mercruiser valve springs?
  190. Machine and weld exhaust
  191. Any 28' Powerplay or 29' Phantom experts??
  192. Silicone hose for exhaust?
  193. Compression ratio
  194. Hydraulic vs hydraulic roller.
  195. is there a gas grill website like oso ?
  196. SBC cooling question?
  197. 496 MAG ECM on a 496 MAG HO??
  198. Bravo 1 496 Mag Exhaust Riser Question
  199. Solid roller adjustments or check intervals?
  200. Hp3 GM racing 2005 525 motor
  201. Pro comp bbc intake min CSA vs 454r min CSA and minimum to maximum differences
  202. Valve cover differences
  203. best vinyl conditioner
  204. Bravo Drive oil cooler-Drew Marine Cool Swirl
  205. Thumping idle
  206. Swim platform for a Switzer 24SS
  207. 525sc Rebuild
  208. roll off work on...
  209. 525 Fei Crankshaft
  210. Ignition
  211. how much power can stainless marine take
  212. Where can I get a small piece of Corinthian riviera red carpet
  213. Rebuilt HP 500 carb motors
  214. Anyone know these shifters?
  215. Mercruiser 496 Fuel Pressure Regulator-2004 Cool Fuel
  216. Anybody had your fuel pressure guage pegged?
  217. Scorpion Rockers... good, bad?? ugly? long life??
  218. tranny cooler plate....how hard?
  219. Aluminum head valve seat material??
  220. Mercruiser cyclone 400 manual
  221. Dana marine exhuast
  222. Replacing cylinder heads on a 500efi?
  223. Tips for Pressure Testing Headers
  224. -12 bungs
  225. 28 daytona eliminator and procharger fitment
  226. Dart block oil temp
  227. Stainless marine exhaust Q
  228. Alpha Cutout Switch NOT Working
  229. NA pistons
  230. Low speed cavaition, what would it feel like ?
  231. Bravo III prop nut
  232. What's the difference between 35-16595Q and 35-16595 and WIX 51515R
  233. Why don't boats have multi-speed transmissions?
  234. Replacing valve body on steering arms at transom anyone done this job tips?
  235. Verado 350 rigging manual.
  236. Mayfair extension box
  237. Daytona Ignition data logging. Engine tuning.
  238. Hard start 540 whipplecharged
  239. Quick question
  240. Mercury 520 / 540 / 565 opinions
  241. milkshake on dipstick... what now?
  242. Too much Bow Lift.
  243. Do all Merc Racing oil filters have ADBV?
  244. Internal tie bar???
  245. Vinyl Wrap?
  246. Winterizing?
  247. Getting reversion and need some advise
  248. Corvette boat conversion...any info
  249. 3.0 L 250hp EFI Mercury outboard
  250. Are Sea Strainers Necessary In My Situation
