PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Engine alarm constantly
  2. Bravo one to XR advice needed
  3. Timing covers
  4. Newly Rebuilt 502 EFI rpm race from 2000 to 3500
  5. bravo bellhousing problem
  6. Tilt helm on a older style non-tilt helm..
  7. Marine Aire Won't Prime
  8. Garmin fuel flow sensor vs SmartCraft/MercMonitor vs ???
  9. 540 build underway......help appreciated.
  10. electrical gremlin in my 96 502 scarab 26ft
  11. Tach stuck Loose connection ?
  12. superchargered 502 mag leaking oil into intake
  13. 2000 H2X with 7.4 mpi issues
  14. Installing Shore Pwr/Bat charger in Center Console
  15. 454 mag. breaking up at higher RPM
  16. Donzi Stereo Advice
  17. 496 Fuel Pressure Regulator
  18. EFI tuning question
  19. Help w/454 Gen VI
  20. Thunderbolt Tests
  21. B&M 250 issue
  22. Stainless Steel exhaust tips
  23. Performance Exhaust
  24. 540 or supercharge ths 454?
  25. Difference in shift cable adjustment tool
  26. Temperamental 454MAG w/wipple
  27. Hey guys I need some advice on some work I had done on my boat
  28. MEFI programming for altitude???
  29. Question about Mefi1 (linked)
  30. 454 mpi cuts out under load
  31. Knock sensor code
  32. Need 86 Pachanga 22 parts! Where?
  33. Searched for Answer About Starter Issue and Didn't find my Same Issue
  34. 496 Mag HO intermittent missing
  35. searching and searching
  36. Performance Chip
  37. Help with Power Steering Actuator
  38. 502 oil blow out
  39. vortec timing
  40. Engine swap help
  41. motor never gets over 115 degrees. ok?
  42. Fuel question
  43. mechanical trim gauge
  44. Fuel/stumble issue..
  45. water temp gauge
  46. Alternator and wiring questions
  47. My Engine Saga any advice would be helpfull
  48. 460ci b&m 250 boost setup?
  49. Best large oil filter?
  50. Carbs: Edelbrock vs. Holley
  51. Swap 1 engine w/ twins??
  52. opinion on replacing y pipe shutters
  53. 525sc dominator 1050 carb question
  54. 2001 454 MPI Hesitates on Take Off
  55. Stuttering at idol and black smoke.
  56. Where to buy gaskets 502mpi?????
  57. Blue drain plug thread type?
  58. Will these exhaust transom rings work?
  59. Elevated copper in oil
  60. stainless marine manifolds seem to be getting to hot....any ideas guys?
  61. 525EFI headers on 496HO??
  62. Water circulating pump 454 v belt verus serpentine
  63. First Time Boat Owner..just add $$ Right? Impeller disintegrated...
  64. Mercury Racing 600 Compression/ Leak Down Results
  65. starboard K-plane not working
  66. Cause of my reversion
  67. Wideband O2 lean spikes
  68. Trailer Bunks?
  69. sound level- On stand vs in boat
  70. Performance gains from advancing timing?
  71. HELP with prop selection
  72. Belt ID
  73. Alpha Nose Cone
  74. 454 oil pump pick up
  75. Oil pan gasket changed in the boat?????
  76. Digital GPS battery replacement
  77. Merc 420hp
  78. Chevy 2qt oil filter number
  79. Bilge Pumps
  80. Carb question HP500 blue engines
  81. TBI vs Rail EFI
  82. blown 502 video
  83. Formula 242 exhaust help needed
  84. Sea water pump
  85. joey anselmo
  86. Clamp/Slip on switchable mufflers...
  87. Clamp/Slip on switchable mufflers...
  88. SSM3 drives, how do I ID PROPS??
  89. 502mpi please help quick question???
  90. msd coil compatible with stock system need help
  91. Another spark plug thread
  92. Need twin 350 Mag MPI help
  93. Gm vortec marine engine...
  94. 454 mag mpi won't idle
  95. Hose and fittings for 454 mag thermostat
  96. Silent Choice, Captain's Call
  97. Tuning ?
  98. Mobil 1 oil?
  99. 502 Low Oil Shutdown?
  100. power plants?
  101. bennet tabs/ K-plates
  102. 496ho ?
  103. GM 3.0 L4 Piston ring difference
  104. Windshield for eliminator boat
  105. T-Stat ?
  106. 454 cutting out some times
  107. 2nd ign module went out in couple hrs again!!
  108. Gen 5 to Gen 6 flywheel ???
  109. oil cooler and oil thermostat ?
  110. Tall Deck vs Regular Deck
  111. 500 EFI Flywheel?
  112. HP500 raw water pump plumbing help
  113. Bravo one upper gear housing noises
  114. 575sci Super Chiller and Aeromotive fuel system.
  115. 500 efi wiring/ trim tabs
  116. Coupler Vibration?
  117. Repairing outdrive gear case chip?
  118. trim gauge problem
  119. Gas grilles
  120. looking for speed
  121. MCM525SC Cutting out
  122. Testing fuel pressure 350 mpi ?
  123. bravo transom assy
  124. Exhaust help
  125. 3.3 Whipple MEFI problems
  126. torque specs
  127. Wheel bearing grease removal....
  128. crossover with thermostat setup
  129. Need help identifying a merc ignition system plus a few other things
  130. gil risers vs. headers
  131. Mercruiser 7.4 MPI motor problem
  132. 7.4 MPI (1998) fuel line fitting to fuel rail specs?
  133. Q on procharger fitting in Baja 272 year(2000)
  134. Small Block Intake,, Which One??
  135. Yet another SBC jetting question
  136. PBM hyd roller lifter preload?
  137. Upholstery questions new backing and vinyl
  138. where can i buy all new hoses
  139. Seat pedestals
  140. so now what.. MPI ECU bad.
  141. Any prop suggestions?
  142. mid 30 footers in big waves
  143. Dyno/River testing
  144. Bravo 3 on Thunderhawk 43
  145. Electrical Problem with macerator pump
  146. silverado 6.2 or denali 6.2 owners or opinions
  147. Need help with 1986 21 scarab 1
  148. shopping for a boat
  149. Another Jetting post
  150. Will I gain anything with this exhaust swap?
  151. What props do I need? 1990 27.2 Formula SR-1?????!!!
  152. 350 build
  153. 500 efi motors won't idle
  154. Twin Engine Grounding
  155. is this good water press. psi?
  156. guide plate ?
  157. 15 hp Mercury 4 stroke idles rough
  158. Lovett Pumps
  159. Oil pressure gauge all over the place on both engines, help?
  160. Gaffrig Throttles, keep backing off while cruising
  161. 496 HO - Stalling issue
  162. GoPro HD hero Camera
  163. 502 temp gauge and overheating issues.......help
  164. 525SC power valves & base timing
  165. water in oil
  166. Steam Pocket
  167. 500 EFI Backfire and drops rpm in rough water
  168. 454 Mag stroked to 496 w/ProcCharge what carb
  169. Anyone ever heard of these??
  170. Engine noise through stereo.
  171. 350 mag
  172. what auto oil sending units work with merc guages?
  173. 525 fuel issues
  174. Bravo 1 steering shaft replacment?
  175. 502 EFI same fuel injector keep getting "stuck" open?? pics, Baja, DVX
  176. VST return
  177. Gen X CMI headers
  178. 525efi oil in water
  179. Where can I buy Stainless Footrest....
  180. Need help identifying TBIV ignition modules. Pics included
  181. 454 build with pics
  182. SBC intake manifold
  183. Oil Pick up for stock pan
  184. What weight synthetic oil should I run
  185. Mounting a steering wheel
  186. GM Performance Engines 454 -vs- 502
  187. Who has a good 575SCI tune?
  188. Gaffrig switchable exhaust install help!
  189. Dry Exhaust and Prop question
  190. 502 to 540's
  191. valve size and rejetting
  192. If you have the time, would this part number work for alpha one gen 2 drive. Prop #
  193. Min. Oil Pressure
  194. Mercury Offshore Series Props?
  195. Need help with fuel not priming with a new tank on an outboard
  196. When to rebuild 454 Magnums and Baja 322 fuel consumption?
  197. dry risers thru the transom. pros and cons
  198. 496 Kill Switch
  199. Lost a Prop
  200. Mercmonitor?
  201. Yes another 496 soot question... But Please Help Anyway..
  202. Starting issues with Merc 900SC's
  203. Need Air Flow in Open Cabin..suggestions?
  204. running two gps's
  205. 1993 38ft Scarab
  206. anyone running whites performance motors?
  207. Bigger carb advantage over q-jet
  208. hydro steering issue in reverse
  209. Prop size on 265 force?
  210. Risers getting to hot.
  211. Starter Slave Solenoid Location on Merc 496 Mag
  212. Drive Anti Fouling Paint - Any Favorites?
  213. torsion axle issue????
  214. 20 outlaw constant buzz/beep
  215. new boat, 1985 excalibur
  216. mild 454 upgrades?
  217. 90% or prop not dialed in
  218. new 502 pics
  219. I need a 2002 29' Baja Outlaw Anchor Lid
  220. Corsa Captains Call Diverter plate breaks common?
  221. Engine hatch seal
  222. Possible fuel problem?
  223. Why not a crate engine (anyone)
  224. Polylift problems
  225. HTM SR24 Wiring
  226. dry sumping engines
  227. 454 Mag Spark Plugs
  228. where are you taking your water press readings from?
  229. what causes a new ign module to go out?
  230. Teague Platinum XR drive or merc xr upper
  231. Hook in hull question... 320 Baja Force
  232. Drilling vessel voltage level: Choose between 11kV and 6.6kV?
  233. air fuel ratio on a blower motor?
  234. Need Help 24' Superboat
  235. fuel pump failure? ??
  236. Anyone heard of boat angle causing oil pressure problems?
  237. what spark plugs for my motor
  238. looking for a boat
  239. Where to buy VDO fuel sender?
  240. Quick starter help on 502
  241. Bravo Three lower unit bearing retainer removal
  242. Twin turbo setup
  243. Electrical Problem...Need help ASAP :/
  244. Small Block Chevy --Larger Oil filter ?
  245. single carb vs efi same horsepower... upside?? downside??
  246. rub rail insert.... what is the secret to installing??
  247. 1989 scarab elite 21 383 stroker
  248. Oil recommendations- no flaming please
  249. thunderbolt ing
  250. 454 Mag, 365hp - getting RPM's but not the speed?
