PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Oil valve relief 500 Efi
  2. 500 hp big block chevy
  3. backfiring through the carburetor???
  4. tune up kit
  5. Cone Clutch and Lube Question
  6. 496 Sputters on take off....
  7. valves
  8. Any 502 MPI Experts?
  9. Fuel pick ups
  10. Looking for person to dyno.
  11. 496 mag shuts off going down the lake
  12. Power Steering Pump Retorfit
  13. Compression test questions
  14. Recommendation for IR temp gun
  15. would this 540 be a good buy?
  16. Fuel injected 525SC
  17. 496 mag buzzer / alarm
  18. alpha / Bravo manifold differences
  19. Fel pro head gaskets BB
  20. Loads up at idle
  21. 454 Mag MPI Horizon?
  22. need a hei distributor for a 94 502 EFI
  23. Will these headers fit?
  24. U.S. Engine Inc.
  25. 540 merc bulldog build?
  26. Bravo Gimbal Ring Maintenance
  27. Camshaft for 350
  28. First Post hello's!
  29. Guys with BOOST, what mech fuel pump??
  30. What water pickup to use?
  31. stainless manifold plumbing ?
  32. log vs center rise exhaust
  33. Street 350 engine
  34. over heating issue and need help....my first poker run this weekend!!!
  35. 496HO Fuel Pump Cross Reference
  36. IMCO Exhaust flaps
  37. Knocking sound when cranking
  38. Procharger idler bracket/ modifications questions
  39. Cam Specs for a 525 EFI
  40. High Fuel Pressure - Carb'd BBC
  41. cheap prop vs expensive prop
  42. 454 Engine missing and cutting out under load HELP PLEASE
  43. low fuel pressure
  44. Is it bad for a boat to sit un used?
  45. 496mag HO problem
  46. New 502 carb woes.
  47. Torque to the port side really bad now..
  48. Hydro vs solid cam
  49. Dual 4's or single on B&M?
  50. Holley 850 help
  51. Mustard tree stain on seat, Help
  52. Muffler help needed
  53. Lowrance Depth Gauge
  54. 96 500 HP Carb Cap and rotor
  55. Correct plug for stock 454 Mag MPI?
  56. What Carb Do I have and need
  57. Speedo Faded on every used boat?
  58. Any idea how this wire shorted out?
  59. trim tabs
  60. VST EFI pumps
  61. whipple pulleys
  62. mirage to mirage plus conversion
  63. what is a good prop slip number ??
  64. Good place to test vacuum on 454 merc?
  65. MSD Pro Billet 8560 problem...
  66. Which prop?
  67. need some marine blower cam help. engine builders inside
  68. impeller and housing
  69. Need some jetting help
  70. Teague Fuel Filter Housing
  71. Bennett hatch actuator
  72. JL Audio 7.7
  73. Need Help With 540 Merlin
  74. oil cooler ?s
  75. threw hull pick up what bonding glue to use?
  76. Bravo 1 XR Upper to Bravo 1 Lower
  77. gen 4 heads on gen 6 block can i us stock rockers and push rod
  78. New water/gas separator engine wont start
  79. 7.4 mpi cool fuel
  80. how many hours before rebuild?
  81. Amsoil remote filter head
  82. zz502 - what is the largest bore size without heat problems?
  83. Lifters??
  84. Upgrading TRS Motors
  85. Rob Schooping/htg Motorsports
  86. excessive priming a 454 to start after sitting for weeks ?
  87. Stelling Extension boxes
  88. Neutral safety switch cant find
  89. RPM's have dropped from 4800 to 4200 at full throttle
  90. Flame Arrestor: Stock or K & N
  91. 3 to 4 blade question.
  92. Forgot plug, turns over, won't start?
  93. Trim Control on Throttle?
  94. What fuel for 502EFI MAG?
  95. Spark Plugs
  96. Roller Lifter life
  97. intake manifolds
  98. Aeromotive A1000 sounds like war!
  99. Making a350 a 383
  100. 350 Mag engine miss
  101. Exhaust help
  102. holley jet sizing.... curious what others are running
  103. opinion 383vs454
  104. 598 Engine Build
  105. 525 Fuse
  106. 496 MAG IAC mounting location
  107. Intake/head port mismatch
  108. best oil for 575 sci blowers
  109. Water Blockage in Bravo 1 Lower?
  110. Building 350 MPI any help
  111. Looking for used 27 dayton
  112. 575SCI water in cylinders
  113. Alpha y pipe and block off plate bolts and o ring
  114. Polishing aluminum valve covers, what to use?
  115. Oil-line hookup on my Gen V HP500.
  116. trailer help
  117. New help with a few issues on new motor install...
  118. Risers too hot?
  119. Supercharger help
  120. K Plane and Extensions Box?
  121. Merc prop defect in casting?
  122. 502 efi problem
  123. Loss of speed over 3800 rpm
  124. ignition timing/super charged
  125. After Market Fuel Injections
  126. Battery/Wiring/Switch Question
  127. Exhaust exit help on Baja 226 Sport
  128. 454 mercruiser ex manifolds
  129. MEFI 1 xdf file
  130. Power Steering Dump Cap Replacement
  131. trs drives
  132. Rebuild kit for 9780s carburator.
  133. Powered Stern Light...
  134. Please help! Complicated reversion problem
  135. 525 sc intake manifold
  136. Varnish And S##t In Fuel Tank Cleaning
  137. Ignition timing, idling woes, Opinions of what to trouble shoot?
  138. Use Rev Limiter or Let Carbs Limit Revs?
  139. 502 Stroked to 547 - Oil Cooler Suggestions
  140. Nav light switch is hot
  141. 115v AC wiring help. With diagram
  142. setting cam endplay with cloyes 2 piece timing cover
  143. hydraulic fluid
  144. Adding an oil temperature gauge to a 496
  145. 565bbc numbers
  146. Horsepower vrs. Torque
  147. pros and cons of bravo three
  148. would anyone be able to give me some eyes in clinton, mo
  149. 540
  150. 502 water pump which hose?
  151. Tab Pump Issues
  152. best water pick up for cat stepped hull
  153. Help Water in oil... Alot
  154. Bravo 1.65 gear sets
  155. what cam and prop fot 454
  156. Weak valve spring symptoms?
  157. Prop hitting drive??
  158. Merc 454 carb to 496 HO?
  159. donzi 26
  160. Mercruiser Starter Switches.
  161. 502 Inectors
  162. Weird issue
  163. cam help... 496 bbc
  164. boat not wanting to accelerate off idle formula 242 ls 502 mag
  165. Hallett 300
  166. Mag Vs HO engines
  167. 496ho gremlins strike again
  168. HP500 procharger..how much boost ?
  169. Fuel pressure regulator?
  170. yellow corvette c6
  171. 460 Ford Berkley Jet
  172. 525SC fuel pump part #
  173. Low Hp Air or Exhaust
  174. 2001 28 td daytona
  175. Eickert Oil Pan /oil Pump Set-up
  176. Staggered Engines
  177. 525 Problem
  178. Wiring diagram
  179. Tips or no?
  180. 496 Crank sensor intermittent? no code?
  181. Goto 540 or Tweek out the 489
  182. bravo coupler
  183. 97 bravo one specs
  184. Sea Strainers
  185. 600 sci fuel pressure too high
  186. Anybody Notice?
  187. boat stall
  188. Fuel flow problem. Help!
  189. 502 water pressure
  190. 454 submerged in salt water
  191. Bulldog 420 hp Tempest Sport 32'
  192. need a ecm
  193. trim problem
  194. Trim Probelm
  195. 454 mpi overheating or not????????????????
  196. 496MAG to codes, but wont run W/O
  197. Sand T stake
  198. Diesel Power
  199. ocean marine a/c unit wiring diagram needed please HELP!
  200. 496 MAG HO ECM Mods
  201. Old Ethanol Fuel – Add Fresh or Just Burn it?
  202. Prop washers
  203. Intake and Carb ?
  204. anybody heard of this company or have any experience with them?
  205. 454 mpi overheating
  206. tachometer issues
  207. Gen 4 max bore??
  208. Looking for 502 MPI Roller Lifter Help
  209. E-3 plugs in a 454
  210. Hin Manufacturer Question
  211. 502 hydraulic roller problem??
  212. hotboatjet
  213. Q-jet jetting question on modified Mercruiser
  214. PowerBoat P1 Driveline Torque Sensor Device
  215. Hardin Marine stainless steel sea pump with the cross over
  216. Installing oil coolers on a smallblock alpha, crossover set up
  217. 502MPI - Odd IAC and spark readings
  218. Bravo water pickup hose inside the transom assembly ??
  219. 454 Mag Mpi Issues
  220. edelbrock heads vs peanut port for 454....
  221. 502-454
  222. k-plane trim limit..
  223. Innercooler cores
  224. Engine Guru's - Need help-Take a look
  225. ezstriper , part number please ?
  226. power steering cooler leak?
  227. 525 Efi
  228. Mercruiser 350 Bravo, ignition timing questions
  229. 454 rebuild help please
  230. sea strainers
  231. Engine hatch hinges and removal
  232. 575 upgrade
  233. Bolster pump leaking
  234. Rockers coming loose
  235. donzi zx 28
  236. 350 Sci Verado problems?
  237. Boat darting right randomly
  238. Which Heads for a 496 Stroker
  239. shorepower battery charger shuts off after 24hrs
  240. 502 Overheating --- help
  241. imco or sportmaster lower unit vs xr lower unit
  242. Crack in Sportmaster Lower
  243. Weird metal markings on 300 ProMax
  244. 502MPI - Intermittent Crank, No Start
  245. 500HP max RPM
  246. marine circulating pump versus automotive
  247. Adjustable fuel pressure regulator
  248. short in ignition?
  249. altenaor ?
  250. sunblock stain
