PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Any Mac tool dealers on here?
  2. cold water cold air cold motor
  3. fuel additive
  4. Need a little more POWER!! Help!
  5. 502 re-power options
  6. Compression test results and Gen V 454 Mag / HP425 Differences
  7. suggestions on pwer ugrade wanted
  8. Twin Drive alignment
  9. Gold Digger
  10. valvetrain geometry check - do I need shorter pushrods?
  11. Donzi 38ZX Electrical Questions.....
  12. 2 BOATS, same price, different years, 525sc or 500efi need input
  13. gfs 10
  14. 330 Hp to 400 HP
  15. How to check fluid levels??
  16. New Boat trying to guess HP
  17. Spare tire bracket
  18. Help With Engine Id.
  19. Westerbeke Genset
  20. 350 Mag cutting out at WOT
  21. oil lines
  22. 525 oil change frequency
  23. Amsoil 5-30?
  24. Who makes the best labbed prop???
  25. emi vs stainlessmarine exhaust
  26. thermostat housing change
  27. K-plane pump switch wiring
  28. Whipple vs. Procharger
  29. Buying boat, need to confirm engine hours on "fresh" engine
  30. Stereo
  31. vortec head valve covers
  32. Thanks OSO
  33. Gauge Issues
  34. Which heads are better
  35. Back flow valve for innercooler
  36. 330 hp Stock Exhaust Manifold Swap
  37. merc engine wiring diagram
  38. Lake's near Dayton Ohio for test ride??
  39. Alternator Size?
  40. 454 build horsepower?
  41. fuel pump vacuum
  42. Opinion needed.
  43. Motor Rebuild ?
  44. Is this what I need
  45. 400' X 60 ' pole barn ?s
  46. Port side outdirve & K Plane pump, No Power!
  47. Removing scratches from my windshield
  48. hub kit
  49. Reassembly: 454 Mag Mpi
  50. Stereo issue with amp
  51. Carb Spacers
  52. 500hp efi fuel psi
  53. Steering Centerline/ Crank Centerline
  54. Scorpion rocker clatter
  55. Alignment tool fo Imco box
  56. Mounting a Thru hull transducer 88 Baja
  57. Steering wheels
  58. Easy way to identifiy a 351 vs 302?
  59. imco lower
  60. Moisture In Oil
  61. Another one for ya
  62. Opening engine compartment w/ no battery!
  63. steering hub adapter??? Help
  64. got ripped off on some parts and machine work, need advice..
  65. Holley Carb choice ?
  66. gear lube reservoir alarm not working
  67. OSO timing out quickly
  68. 1.8 roller rockers
  69. Non skid
  70. My Header dilema continues
  71. Alpha rear engine mount bolts
  72. transom mounted water pick-ups
  73. Closed Cooling Heating Question
  74. Big Block Oiling Question / by-pass valves
  75. 489 with only 14 hrs compression #s
  76. McLeod Design?
  77. Mechanical speedo
  78. Looking for Bravo One X Decals
  79. Subwoofer box Dynamat lining
  80. Bolt removal - bellhousing to transom
  81. Propane Powered
  82. Someone Please explain this to me...
  83. need help 90 31' scarab excel stringer bad
  84. Any stereo/audio wizards out there...?
  85. boosted tuneups
  86. Muffler removal help, and NEWBIE to site
  87. 2 Warning Beeps on 496ho???
  88. Lenco's vs. K-Planes
  89. Race Pump fuel pumps
  90. Sea Strainers , Brass, Bronze or SS ????
  91. to lube or not to lube
  92. Fuel Flow Meter - HELP
  93. 292 Formula Fastech 400 + HP
  94. paging Fogducker..
  95. gps antenna
  96. Holley help/ twin 750s/5psi boost/roots
  97. Does anyone know where I can get two of these (pic)
  98. Put-In-Bay info
  99. manual fuel pump
  100. Solid Model of a Top Gun
  101. Single or twin fuel usage?
  102. Do Corsa mufflers cause any RPM loss?
  103. Stereo popping with trim adjustment
  104. Saginaw P/S pump GPM Flow rating?
  105. More prop testing and results...need advice
  106. Sea Mounted Fuel Pump Block Off
  107. Holley 800 vs 830 for 489
  108. High fuel pressure.
  109. CD Player remote question
  110. White chalky residue on exhaust manifold/riser
  111. Compression Ratio w/ 4lbs boost at elevation?
  112. Mobil 15W-50
  113. Question about Bravo Drive
  114. where to buy marine carpet
  115. Good place for rear seat/sunpad within 150m of Austin?
  116. Block casting number
  117. Water to whipple Chargers
  118. Scoop location?
  119. Old Volvo fuel pump
  120. Weird oil leak?
  121. 38 Fountain Port no power
  122. Water pressure sender
  123. PSI Blower Carbs
  124. 496 sea water pump question
  125. 502 Bad Intake Valves WHY?
  126. fuel in seawater fuel pump housings?
  127. 1999 HP500, MLS without surfacing?
  128. Engine shipping crates?
  129. Break in limiter - Verado 350 sci
  130. Low oil psi 454 500HP
  131. Need help with drive height
  132. Oval exhaust tubing
  133. Tapping/ticking noise
  134. Engine ticking
  135. supercharer compatibility????
  136. warning alarm
  137. help needed: 502BBC engine problem
  138. Mercury Racing Oil Filter Cross Reference
  139. Interior cleaning products??
  140. What oil should I run?
  141. GPS/Depth Finder Combo Question
  142. Teague VS Imco
  143. Correct blower size for Gen VI 540?????????
  144. engine mods to a 502 BBC expected H.P gains?
  145. Anybody have lorance
  146. 1.8 rocker on 500hp
  147. hydraulic steering valve question
  148. 188 or 088 heads
  149. 502/450 hp gm blocks whats the mystery ?
  150. Are these heads to big for my combo, Merlin iron 345 CC runners
  151. Trouble aligning engine (350 sbc)
  152. Transom bearing and starter.
  153. best price for anodes?
  154. Lucas Gear Lube anybody use
  155. Fountain fresh water tank pump
  156. carb for 502
  157. HP500 Buildup questions
  158. 502 mag 450hrs on a boat i may buy
  159. Rub rail screws
  160. Scarab 22 Gas Tank Fitting
  161. First Poker Run
  162. Nordskog
  163. best oil for 525sc?
  164. STEREO Advice
  165. 3rd tank for boat lift location
  166. Hydrualic steering cap
  167. Polished Stainless Steel Bolts For Exhaust Tips
  168. Boat radio circuit amperage
  169. ESC Module availability
  170. lightning headers
  171. Cam and ignition question
  172. prop for a 24x7 hull
  173. Any good mefi tuners around LOTO?
  174. need help
  175. 502 EFI System Problem
  176. I need to replace a window on my boat, where do i begin to look?
  177. Gas questions
  178. Rotella 15W40
  179. How much boost would you run??
  180. Another K-Plane ?
  181. Blower Size on Mercury 900 SC's??
  182. Decent OTC head cam combo
  183. Part number for GEN VI timing cover gasket?
  184. Buying used headers
  185. powdercoated out drives?
  186. Remote Reservoir On Hydraulic Steering
  187. 500HP how can you tell it is a real one vs. a 454 painted blue?
  188. GIL or CMI Headers for 500HP??
  189. Get roller cam or Alum heads?
  190. new radio an amp
  191. Kill Switch
  192. Morel lifter noise
  193. Silicon on bravo transoms or not
  194. Belts for HP 500?
  195. Mallory cross reference
  196. cam card
  197. HP 500 EFI (in 20.5 cougar sport skier)
  198. Anybody with Lincoln Welder Resources?
  199. Identify This Steering Mfg.
  200. Switching to captain's choice / call from the corsa quick and quiet 50/50 muff system
  201. 10778C oil pump, which pressure spring?
  202. adding shoot through depth transducer???? where to place it?
  203. K-Plane Pin!!! Stuck!!
  204. #7 cylinder 0 compression
  205. Holley 2 circuit or 3 circuit for marine application
  206. Where to plumb this small fitting on Hardin/Gil 9" Riser?
  207. Mefi-3
  208. are these 454=440 cyclones
  209. exhaust
  210. HP500 carb onn a 489?
  211. head choice
  212. Oil Extractor
  213. Bravo XR, LH or RH failure rate
  214. dry joint exhaust ???
  215. SUPERCHARGED 588CI 1050 or 1150
  216. Merc exhaust elbows - stainless vs iron
  217. Opinion needed on a 496 cam
  218. Should I Be Worried??
  219. Crankcase Breather for Merc 490HO Oil Fill Tube?
  220. Thunderbolt V
  221. Analog Tach reading off
  222. repower a baja
  223. Two Stupid Questions...
  224. Rockford Fosgate Marine Speakers???
  225. Baja V8 swap
  226. HP 600SC. What am I buying?
  227. hp500 cap and rotor
  228. guesses on power?
  229. Engine Hours
  230. Adjusting Idle on a 600SC
  231. Finally narrowed it down, what you do you think
  232. hp500 oil and filter change
  233. Bravo 1 to XR shorty
  234. stainless cable 33c k-plane cable covers??
  235. Promax 300's snapping alternators off..
  236. 525 one side hot
  237. Pachanga distributer and coil
  238. Kicker Marine
  239. gen V gen vi block swap
  240. Clicking,tapping noise after shutdown
  241. 94, Merc 454 Mag water pump.
  242. Issues with 496 CMI Sport tubes??
  243. Stereo amps in bilge
  244. powerquest 380 bow lift
  245. Valve covers and roller rockers
  246. Power Steering issue....
  247. Best oil pan gasket??
  248. Wet Sounds equalizer and IR repeater????
  249. how much of a cam with 496 manifolds
  250. New install of sea strainer?
