PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. need a bravo measurement
  2. Speaker cable
  3. Ujoint drive shaft angle
  4. 800 SC's...?
  5. Buying new long blocks -best source??
  6. Bearing Question
  7. Old Style Windshield Replacement
  8. New guy – West Michigan noise/Lightning Dry Headers vs. Stellings or CMI
  9. Interior Disassembly
  10. BBC Valuation Questions
  11. K-Plane Installation Template...
  12. CMI E-Top Lites with Silent Choice
  13. CMI Sport Tubes for 496
  14. Slight "roller tracks" on camshaft
  15. Dana Flow Torque exhaust
  16. Cost of an XR/ITS system?
  17. Wanted: Wing plate for Bravo1 Drive
  18. Water Pressure #s
  19. Best Location For Pop Off Valve
  20. which hvh carb spacer do i need
  21. Gen + small block ??'s
  22. Tall Deck
  23. Pitted gears in XR @ 75 hrs??
  24. SSM 3 Maintenace Items?
  25. Ingenius Software
  26. oil pan gasket
  27. Mercruiser Trim Pump
  28. Motor head guys - need some help on a timing question
  29. Stellings Extensions, Drive Height and Shorty lower units
  30. HP500 EFI Closed Cooling Upgrade
  31. Crankcase Ventilation question
  32. Fountain Triple 525SC's
  33. Bravo 1, 2 and 3 transom assemblies
  34. Cam guys plz help
  35. Gen 6 rocker arms
  36. hydraulic steering - what do I need to know?
  37. 305 sbc
  38. Spline Grease
  39. 496 guarding system
  40. SOLAS approval for KPM PUMPS
  41. 28-32 boat - Single 525EFI VS TWIN 496 HO's
  42. Wanted: Looking for Yamaha hydradrive
  43. Hardin marine distributors
  44. boat lists under power. drive alignment problem?
  45. Best Dash Guages????????
  46. Seawater Strainers
  47. crazy gauge?
  48. TRS Drives
  49. Hydraulic Steering
  50. procharger carburetor
  51. Black transom
  52. Muffler Advice
  53. Upgrade for Bennett Trim Tabs
  54. Differences in 1986-1987 and up 350's?
  55. ARP Head Bolt Kits
  56. 330/454 Bravo 1
  57. Alcone Motorsports
  58. Wanted: Wing plate for Alpha Drive
  59. carb size and jetting
  60. Horsepower per 100 RPM Question
  61. small block roller conversion
  62. Octane Booster
  63. OK . . what the he!! is this thing?
  64. Check computer hrs on 525's
  65. K&N Flame Arrestor Elements
  66. why did my rear thrust bearing surface go out?
  67. Prop shaft adaptors
  68. cracked head on 330hp 454, replace with 049's???
  69. Imco Lower gears
  70. Pressue relief valves?
  71. Outdrive questions
  72. What does it weigh?
  73. Smartcraft transom assembly
  74. big block I.D
  75. Need Help With Switch Wiring
  76. What sparkplus to run in AFR heads
  77. CMI tailpipes
  78. 26' To 30' Single
  79. drive alignment w/ imco boxes
  80. vortec intake
  81. Pulling Bravo outdrive, whats the secret???
  82. Plastic 1/2 hole wedge for Bravo...front or to the back ?
  83. Headers for HP500 Carbs w/ silent choice?
  84. anyone with a sunsation 28 with 525
  85. Mph increase question
  86. New Manifolds for my Donzi
  87. Anyone have pair of New Merlin heads.
  88. Altenator
  89. More SBC Upgrades
  90. Information on 525sc's, carbarated.
  91. Alpha and TRS
  92. ignition --timing
  93. k-plane(trim Tabs)
  94. Bad back/seat help
  95. What can I expect?
  96. IMCO Shorty case observations....
  97. exhaust temps
  98. How much to refresh pair of HP500's?
  99. 5.7 question
  100. Calling GOODT
  101. Performance manifolds for SBC
  102. Hey dodsonartic1,
  103. Whats involved in installing larger valves?
  104. Zero Effort Throttles
  105. miami boat show, need help??
  106. chrome plating?
  107. Types of motor mounts?
  108. Small Block Chevy upgrades
  109. Speedmaster Tranny Question
  110. 7.4L MPI Timing Issue
  111. 502 short blocks
  112. Expected Horsepower Increase From Through Prop to Through Hull?
  113. Air Fuel Ratio Gauges
  114. 496 Exhaust restriction picture
  115. Merc 700SCi New at Miami Show
  116. Cam and reversion comparison...
  117. Engine Break-in
  118. IMCO Gatlin Exhaust
  119. 305 swap to a 350 or 383?
  120. oil pan clearance to engine mount
  121. Left over Parts?
  122. 525 Water Impeller
  123. Max HP from a stock 454/502 Carb Intake
  124. Boat lift
  125. the new and improved ask JC PERF thread.
  126. OUTDRIVE MAN and anyone else, King Cobra cone clutch??
  127. Exhaust advice
  128. fuel injected 350 vs fuel injected 454
  129. Help - New Guy
  130. AAAARRRGH!! Milkshake AGAIN!!!!!!!
  131. oil coolers
  132. Engine Reputation
  133. HP 500 Carb Octane
  134. Scan Tool ?
  135. Header discoloration
  136. billet speaker covers
  137. 12v TV's
  138. Upgrade Drives for More Speed/Durability
  139. small king cobra drive
  140. Installing Transom
  141. Can I add power steering??
  142. Tourgue Engineerng exhaust manifolds????
  143. Merc Part number help.
  144. How do you remove Mercury 3000 throttle controls
  145. 454Mag alternator belt
  146. CMI Tailpipe Preferance
  147. Bulldog Main Bolts/Nuts Torque....
  148. A little advice
  149. ??? Replacement of Trim tab indicator cable
  150. Switch
  151. Running Hot? (32ss)
  152. Bravo Water Inlet
  153. Merc 700/600 sci.
  154. Need help to convert outboard to Bravo - 36ft mono
  155. 300 - 320 hp offerings
  156. Drive & crank life
  157. head gasket
  158. Merc500EFI/500Buldog
  159. 1000hp drives!!!
  160. gasket set to re-build 1998 7.4MPI W M1 Procharger
  161. Beede Gauges
  162. Exhaust Question, Again
  163. Merc Power?
  164. double post, sorry
  165. Mesa invite to Boat Show
  166. Salt vs Fresh Speeds
  167. real silent choice with y pipe OR switchable muffler tip
  168. Blower Motor Timing Help
  169. Remove U-Joint Bellow
  170. Shim kits....For gearcase swap
  171. Shorty Results.....Anyone?
  172. Starting Project(again)
  173. New Boat to me anyway
  174. 26' Formula
  175. thermostat
  176. 575SCi blower question
  177. how to convert 4 wire "mono" alternator to one wire?
  178. I shifted boat into reverse and it went forward!!
  179. Ever Clean Out Your Boat?
  180. How do I resize...and post pictures???
  181. Cmi E-top Tail Pipes
  182. 500 efi or 525 efi in formula
  183. CMI header repair
  184. 454 mag questions
  185. oil leak merlin 3"s
  186. Thermostatic oil cooler?
  187. Sideways Carbs?...discuss
  188. Disassembing speedo
  189. engine flush kits
  190. Outdrive stand and lift homemade no welding
  191. Stainless Marine Manifold and Salt water
  192. How much HP with a mechanical fuel pump?
  193. ProMax 300 Harness Assy
  194. Oil cooler and fuel pump
  195. Wind away
  196. 496/bravo flush
  197. AN vs. JIC Flare Fittings
  198. Cylinder head CC question
  199. Blower motor measurement
  200. Merc 575SC fuel requirements
  201. Stupid Question about Roller Lifters???????
  202. anyone have install instructions for procharger M1 for 454 mpi
  203. Hitek manifolds
  204. Dyno results - supercharged 525EFI
  205. Spray glue for vinyl upholstery???
  206. imco powerflow plus
  207. No. 3, 4 & 5 SSM
  208. Need Help! Can I use a Felpro 17048 Head Gasket on a Gen 6 Motor?
  209. 25 Ol filter ? please help
  210. SBford heads
  211. intercooler cores for blower shop intercoolers
  212. Technical Experts Needed
  213. Transoms
  214. How to use drive pressure tester?
  215. Drain Plug
  216. Whipple Color Change
  217. rebuilding trs drives
  218. Tall Deck
  219. New exhaust question
  220. New Boat, Set Up Opinions
  221. Tech Tip..... Polishing Aluminum
  222. water pressure help
  223. Purple Dock Lines
  224. spark plug type?
  225. Pocket Porting
  226. 502 EFI Intake Limitations
  227. Dual Batt isolators...
  228. Trailer serial number location?
  229. Pricing used stuff
  230. 500EFI Throttle Body Size?
  231. Thermostat
  232. Prochargers, What's the real deal / draw backs ?
  233. S/B chevy heads??
  234. Redo my drives??
  235. Changing MPI to Carb on Gen 6 - Need Electric Fuel Pump recommendation
  236. Guage senders
  237. Ingenious Marine software
  238. roller rockers 502 mag mpi
  239. BBC Intake question
  240. AFR BBC Heads
  241. Rebuild Gimbal - Special Tools?
  242. Bravo 1 Wing Plate
  243. Latham steering?
  244. oil pans cat style
  245. Amazing, simply amazing
  246. Cross number 5 and 7 plug wires
  247. 454 magnum id
  248. Water in bellows?
  249. Project complete
  250. 365 Mags gen ?
