PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 [95] 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Bellows question
  2. Rebuilding A Tired VP Engine
  3. Crossover Go-Fast
  4. Can I keep my 496HO from starting?
  5. Hardin Marine cyclone shorty headers/ Gill manifold replacement
  6. RAYLAR, anybody have there kits/motors
  7. Mark IV vs Gen VI Flywheel mounting..
  8. 502 Mag --water in #3 cylinder
  9. Winterizing
  10. Who makes the best cordless impact?
  11. Whipples on 6.2 MPIs & Bravo One
  12. 502 efi upgrade
  13. 496ho procharger
  14. oil filters
  15. 525 CMI , Hose from header to tail pipe ?
  16. how can you marinize an aluminum block
  17. retorque heads
  18. head studs sealers
  19. HP4 Remote filter mounts
  20. Drain plugs...
  21. Oil TSTAT Actuation Temp??
  22. Fastest Single Engine V Bottom?
  23. Advice on fuel pump
  24. 4.5" stainless exhaust tips or just stainless pipe
  25. Water Pump 500 EFI
  26. Special thanks to some great supporters....
  27. Brava 1 to Bravo XR
  28. 420 HP cam specs??
  29. Electricaql Help
  30. Piston Failure Modes 101
  31. do i need to run a drive with reverse rotation
  32. Whats the differance
  33. Vinyl Work
  34. Best place for parts?
  35. Help with Diagnosis needed.
  36. khs powerboats
  37. 502 Fuel pump issues
  38. Somebody must know.....
  39. Tear the mutha down
  40. head studs spec.
  41. crane gold roller rockers
  42. Timing Gears for 454's?
  43. XR Drive oil change w/ WPM steering
  44. Hypereutectic w/ Boost
  45. Camming a 598' for endurance and torque
  46. 496 HO's, Procharger, VS. Whipple. VS. Raylar?
  47. CMI ETOP tailpipe conections
  48. Need Cool Fuel Relocation Kit P/N: 861637A
  49. Blower Cam Choice
  50. Best Book or DVD on Transom rebuilds
  51. Hull crack-HELP
  52. Trim Control Brushes
  53. Merc Racing Indicator Head
  54. Mechanical Fuel Pump 500 EFI?
  55. New Interior
  56. How much space is needed?
  57. Fresh Water Flush Kit
  58. Water reversion
  59. smoke / soot from one side of engine?
  60. New 496 slight oil leak
  61. How do I know what headers fit?
  62. Batteries, isolators, inverters, etc...
  63. Magneto Distributor
  64. Broken pistonrings! what caused this?
  65. what fuel pumps to use??
  66. 496ho procharger
  67. Vinyl Stickers?
  68. J+r Marine Gimbal Repair Or Merc???
  69. mechanical engineer
  70. drive fliud
  71. plug vs drive line gimle
  72. 2000 500 HP w/whipple question
  73. Outboard question for small CC fish boat.
  74. 1996 502 Efi
  75. belt dust
  76. meltdown
  77. 350's to 454's
  78. Gil Exhaust
  79. Tired 454 Magnum
  80. 2" shorty fitment
  81. retrotek??? anyone know?
  82. fluid damper
  83. what size of blower do I need
  84. Idle Air Control Motors
  85. 350 Marnum cam I.D.
  86. Volvo D3 Diesel
  87. How to tell a 454 Mag from 7.4 liter
  88. When to rebuild 525SC motor ???????
  89. need more speed
  90. fuel problem question
  91. Anybody know a formula for this equation???
  92. distributor
  93. need a pair of hp 500 roller cams
  94. How much more horsepower will I get
  95. Latham Marine reservoir adapter
  96. How long is gas good for ?
  97. compression on 2000 500 HP EFI
  98. MEFI 3 and Auto Xray
  99. HP boat security.....
  100. # on Motor , what is it? 525SC ?
  101. 500efi Heads
  102. GM 6.0L small block marine engine
  103. How to winterize a whipple blown motor?
  104. 1990 Scarab 21 Excel 454 Bravo
  105. 502MPI alarm
  106. exhaust questions...
  107. compression test
  108. Tachometer Gremlins
  109. #6 Drives....need advice
  110. power windlass
  111. Merc 525 gaudian mode question
  112. Fountain Questions
  113. How can I fix this? Shift cable housing stuck inside my Bravo bellhousing
  114. 502 MPI rebuild
  115. Need Hp525 Cam
  116. Which way does oil go through the filter? Center out, or outside into center?
  117. 24 volts for my hatch actuator
  118. prop...good buy?
  119. Extension boxes, TRS???
  120. IMCO Steering question
  121. Fuel Tank Pick up
  122. Outdrives, trim out different speeds.
  123. Depth Sounder location
  124. control box trouble
  125. Oil Synthetic or Stock? Marine or not?
  126. Oil Filter for 454 Magnum 1990 Carb??
  127. TRS Trim Cylinders
  128. Acceleraton from blower and carbed motor?
  129. Rock the Bay 2007.
  130. GM's Engine Oil Supplement
  131. Mechanics in Baltimore area?
  132. outboards?
  133. Starboard power steering pump mount BBC??
  134. Stuck Valve ???
  135. CMI E Tops looking for 2 sets
  136. Formula Silent Thunder Ladder
  137. House water pressure
  138. Raw Water Strainer Leaking
  139. 525SC Serial Numbers ???
  140. source for clutch plates
  141. GPS Speedo Install ?
  142. 550 hp 454
  143. Merc 500's.....
  144. Fuel and water pressure connections 454 MAG
  145. Everything but the cam
  146. Secure hoists in Slidell....
  147. Rev Limiter/ MEFI 3 computer question
  148. "Wanted " Holley / Canfields aluminum BBC Head
  149. Bling to the dash
  150. Need bottom injector o-ring/seal in a bad way
  151. Trim tab upgrade
  152. need engine measurement
  153. Onan Gen Set??
  154. trim pump mount
  155. Need 16 Rib B&m / Holley 420 Pulleys
  156. Info on a Kazoo jet boat ?
  157. Merc outboard Tech advice needed
  158. Fogging a EFI
  159. 502 Mag MPI (VST) surges and stalls
  160. Exhaust Tips-?
  161. wierd problem / noise
  162. Does anybody have the EVC spec for the ZZ502 cam?
  163. engine differences, 330, 400, and 420 hp
  164. FasTech Differences
  165. Octane required
  166. where to buy: High flow 140 thermostat?
  167. any info on a '83 20' eagle marine inc boat
  168. Sell platform or install on older boat?
  169. Best Oil for 496 HO's
  170. 454 mag carb ignition module????
  171. Crane 731 or 741
  172. Eliminating TB-V rev limiter??
  173. Volvo Y pipe
  174. 500 EFI Cam Questions
  175. 7.4L mag MPI tops out at 3900 - Troubleshooting?
  176. Distributor
  177. KE Water Pump - Can I add Another Stage?
  178. 500HP Question
  179. 496HO Break in
  180. is it water?
  181. Jumpy oil pressure - just rebuilt motor???
  182. Merc overheat codes
  183. Questions for Whipple guys!
  184. Questions for the Engine mastermids???
  185. Low oil pressure
  186. 7.4L Mag MPI RPM / MPH - prop slip?
  187. merc 502 mpi vapour lock ?????
  188. Looking for Bob from austin TX
  189. Replace springs How many hrs?
  190. 70's Magnum Marine
  191. stock 400 cam upgrade question.
  192. Need a Gen 6 502 block
  193. Reversion issue using ZZ502 Cam. Anybody shed some light?
  194. 496 Mag to 496HO
  195. Intake issues, air & coolant leaks
  196. 496ho with CMI exhaust
  197. how many hours before rebiuld on 525
  198. Merc 575 TBI question
  199. Internal tie bar.
  200. Water Crossover with or without bypass??
  201. Larger injectors for 502 mpi
  202. 500 EFI question
  203. 383 longevity question
  204. Gen VI 454 to Dart BIG M Comparison
  205. merc 525 efi motor's need a new home
  206. Does Alpha Drive have enough water pressure?
  207. 496ho or 502??please help
  208. Camshaft for 496 gen7
  209. Raw Fuel from exhaust when we stop...?
  210. milkshake oil and holds 15lbs in crankcase
  211. 496HO v. 525
  212. 496HO v. 525
  213. 454 rebuild question
  214. Battery charger and stereo amps
  215. Procharger help needed...
  216. new or re-manufactured???
  217. Whipple reliability????????
  218. Cougar CUB need info for max performance
  219. speedo problem
  220. 2000, 502 mag minor upgrades
  221. Whipple pulley?
  222. 350 MAG MTI vs 383 MAG MPI
  223. 1987 454 mag 330hp??
  224. GenVI oval intake on MkIV rect heads?
  225. front cover / oil pan seal
  226. Which plugs
  227. no water pressure?
  228. Need 502 Ignition Timing Help
  229. Need power steering pump cap + reservoir
  230. looking for bravo trim cap spanner
  231. trim cap spanner wrench wanted
  232. Pre Lubers
  233. Any Volvo experts? 5.7 Gi vs 5.7 Gxi
  234. Mercruiser 502 Gen VI
  235. Merc 525 EFI Merc 575 SCI
  236. Can I go faster?
  237. First Oil Change
  238. Add on hydraulic steering - what is it?
  239. Dry Sump Benefits?
  240. Vesselview available yet?
  241. which oil pump to use?
  242. Outboard mounting height...
  243. 500 efi to 540 efi conversion ANYONE TRY THIS???
  244. Fitting on lower maniflod?????
  245. windscreen
  246. Best Gauges/ Indicators
  247. Reversion with mild cam???
  248. Identifing an HP500
  249. Steering Problem ??
  250. 575 SCI fuel filter?
