PDA
View Full Version : General Q & A
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Any ford guys (flywheel)
  2. CIG6 72 36 ft Blonde 2 fort myers cheap
  3. Vent Lines Too Small?
  4. Transom water pickups and water pressure question
  5. Exhaust manifold gaskets, using actual gaskets or high temp RTV?
  6. 500hp carb jetting
  7. 572 Whipple Quad Rotor Holly HP EFI Tune Advice
  8. Exhaust water flow isn’t equal 🤷‍♂️
  9. Basic marine tune for snipers -
  10. Scam ads with my user name
  11. best aftermarket fuel cooler to replace the factory "cool fuel"
  12. HELP - VORTEC 5.7 #7 Cylinder Rockers lack of oil
  13. Reading plugs
  14. Oil temp gauge not working
  15. Carb size and adjustment
  16. Fuel system advice.
  17. Intake Air Temp Problems
  18. ProCharger Intake Duct Elbow
  19. Oil Pressure Behavior
  20. Pressurizing stat oil cooler
  21. Dart Iron Eagle 308 Mods
  22. Need Stale Gas Pumped Out
  23. Antifreeze vs. RV Antifreeze
  24. 99 Mastercraft w/ corvette motor cooling issue, need help
  25. 502 carb raw/open cooling system and thermostat help
  26. Cast alum valve cover studs
  27. transmissions problems
  28. steering wheel trim. diagram for rotary
  29. 2015 Mercruiser 8.2 - High RPM Issues
  30. Donzi 38ZR Gas Strut
  31. 2001 Merc 6.2L MX reversion?
  32. what brand bronze distributor gear?
  33. ITS drive alignment tool
  34. Holley EFI guys what alternator and how to wire it?
  35. Water flow vs oil flow...
  36. Electric choke hook up
  37. Source for oil temp sender-K64286
  38. Bellhousing studs - Marine Machine Wingplates
  39. Daytona sensor CD1
  40. Mercruiser sniper conversion fuel cooler b4 tb or at return line?
  41. Merc Exhaust Y Pipe removal.
  42. Lathem throttles / Dominator carb/ 33c cable
  43. 7.4 MPI Serpentine Belt
  44. Wiring Diagram for Trim Sender Unit
  45. Voyager EST Timing Curve
  46. Source for Delco D1965A Module?
  47. Intercooler Backflush
  48. New to group
  49. Running a 496
  50. 496 Mag Base Model
  51. velvet drive shift problem
  52. Best exh manifold gasket for Imco Power Flow
  53. Non wood frame for rear bench seat
  54. 496 HO injector flow rates, acceptable?
  55. Catamaran VS Deep V 20-25ish ft comparison
  56. flushing engine
  57. Hose from fuel pump to flame arrestor
  58. 575 dies when put into gear
  59. LS cam question
  60. What is thing called?
  61. Nizpro 450s
  62. I need a new oil cooler...suggestions?
  63. Gaffrig fuel pressure electric wire diagram
  64. IC plumbing - is this crazy?
  65. Adding a Fuel pressure gauge
  66. on board remote oil changing kits??
  67. TPS low voltage
  68. 5.7 Tempest 300 HP from 1987
  69. Multi stage sea pump questions
  70. Most reliable outboards
  71. New flywheel or no?
  72. BBC oil pan!
  73. Contaminated gasoline
  74. "Check Engine" on SC1000 tach
  75. oil pressure issue
  76. Automatic Fire Extinguisher
  77. Bbc all blocks the same?
  78. Gen 6 502 vs Gen 7 8.2L 430hp are the blocks compatible?
  79. Livors Data Tach Wiring Harness And Switches
  80. Cam profile for a stock iron head 509 with Holley EFI
  81. Did I get hosed on these props ?
  82. MEFI 1 ECM problems
  83. prop retainer i have never seen before
  84. Electrical issues
  85. Water flow issue 454
  86. Cam suggestions blown 540
  87. 502 mag vs 500 EFI trim gauge wiring
  88. Electric raw water pump idea..
  89. Roller rocker wear
  90. Fuel Sending Unit
  91. Sea water pump rebuild 525efi
  92. Bravo 3 trim issues
  93. Hardin marine engine mounts for side stringer mounted Vs pedestal mount
  94. Does the top of a 525 intake fit the bottom of a 502 intake?
  95. Holley Hard Lines
  96. Hardin gen 7 sea water pump
  97. Transom housing
  98. EMI thunder exhaust riser questions
  99. Help in rigging 700sci
  100. Where to mount the thru hull engine cooling water clamshell
  101. Finding Trim Pivot Point With Transom Assy Off Boat
  102. 700sci installation help
  103. Certified Labs Mile-Hi Octane Boost/ Fuel Additive Questions..
  104. HP 500 oil cooler upgrade
  105. eBay corsa diverters
  106. LSX Tall Deck Engine
  107. Broken ignition switch
  108. Aluminum cylinder head question AFR enforcer 335
  109. Water pressure gage install on 500EFI's
  110. Long Term Engine Storage
  111. Going from MPI to a carb style throttle body do I need different linkage brackets
  112. dual gauges; one sending unit?
  113. Switching to full closed cooling system
  114. Few questions on how to proceed with engine coupler & bell housing
  115. Mobil one sale
  116. Hydraulic hose type
  117. Best Dry Muffler
  118. Sending unit questions
  119. Steering
  120. Engine stand mounting points
  121. Mercury OB lower unit repair
  122. 496ho coolant leak
  123. headers vs manifolds
  124. Crossover with dummy pulley
  125. Add on hydraulic steering
  126. Mechanical gauges
  127. Reuse oil pan gasket
  128. Barnacle Removal from Gelcoat
  129. Mounting power steering pump.
  130. Hardin Seaward Series manifolds in salt water?
  131. Large inch NA build
  132. Whos the blower cam guy to purchase a cam from
  133. cutting transom hole out
  134. Keeping stereo batteries separated
  135. Nortech 390 vs fountain 39nx
  136. Batch fire injector wiring
  137. How does this oil thermostat work?
  138. Switching from MPI to 4150 style throttle body, question on shift/throttle linkage
  139. Big/Small block MerCruiser O2 sensors
  140. BW Velvet Drive Xtra Clutch-TRS Version
  141. Technique for shifting without engine running?
  142. Is transom flat or have some degree of curve?
  143. Got the milk in the oil any suggestions…
  144. Rotate engine while in storage?
  145. CMI headers
  146. Formula 292 twin 6.2L Mercs no power to breaker
  147. Exhaust wet or dry
  148. Bbc ypipe 1000hp
  149. New Owner 26' Formula w/496. Upgrade ?
  150. fuses baja 250ess
  151. Carb linkage to throttle cable how to?
  152. Rebuilding my 580cid BBC Advises Cam choices
  153. Merling III block oil question
  154. Dart cylinder heads
  155. Two Bilge Pumps/Two Switches
  156. Trim Tab Pump Fuse
  157. Any idea what headers these are?
  158. Holley efi tuning
  159. 9 pin engine and helm harness
  160. Valvetrain Geometry and gross lift
  161. 496 HO valve springs
  162. Rockers for 525 EFI
  163. Mercury Racing Blue Anodized Pulleys
  164. Anyone recognize this tool? Is it even marine related? I have no idea what it is
  165. Bravo XR
  166. Help identifying 502 Magnum 8.2
  167. OK, This is a long shot ... Volvo V-8 270 C-A
  168. Mercruiser wiring harness connectors
  169. Adding trim switches to throttle or helm
  170. Under dash steering box
  171. dynoing with FULL wet exhaust??
  172. Bottom care
  173. Silent Choice seal and air cylinder replacement
  174. Mercury 496 Build- Exhaust/Camshaft Reversion
  175. Got her scoped - Rusted & Locked Up 454
  176. Hydraulic Helms
  177. Anybody know where to get a wiring harness and ECM for 7.4 MPI?
  178. Blackhawk wing plate
  179. Help, wiring an old intercom system power wires?
  180. Imco lower questions
  181. Any Volvo Penta whizzbang ECM experts in here ???
  182. exhaust manifold/riser layout question
  183. Oil Prime BBC
  184. Mercruiser 3.0 PCM-09 Code 3050
  185. Oil and Viscosity
  186. Blown BBC cooling lines from rear of intake
  187. Holley 306 SBF build
  188. 160 Degree Thermostat?
  189. Do I need oil temp gages?
  190. BBC Timing
  191. Can you get 500 hp out of a 454/365 mag?
  192. Wanted MEFI 3 (16236999)
  193. Decal
  194. Merc 741 Cam Source
  195. Cooling system upgrade questions
  196. Who is running pyrometers on their blown engine set ups? What brand are you running ?
  197. Going from 12% underdriven to 1 to 1. What to do on carb jetting
  198. 496 HO IAC valve broken
  199. Aftermarket EFI fuel system to ditch the "coolfuel"
  200. Engine oil in water/blocks
  201. vacuum pumps and whos using them?
  202. Nxt alignment tool
  203. Air cleaner restriction??
  204. Who is going to be first to marinize the MEGAZILLA?
  205. Mercruiser 502 / selecting the right cam?
  206. Exhaust advice...
  207. Taking away your rights to buy performance parts.
  208. 69 Mach 1 tires/gear ratio
  209. Fuel Pump Questions
  210. 700sci prelube after engine rebuild
  211. Head bolts 454 MPI
  212. Measuring driveline centers on twins
  213. Volvo 8.1GXi and Merc 496HO... Same camshafts ???
  214. Sensor identification
  215. Innovation 600's??
  216. Marine Machine steering fittings
  217. Thunderbolt V Ignition
  218. Cooling water without the seawater pump
  219. Gale Banks manifolds
  220. Gale Banks manifolds
  221. Cigarette 42X fresh water flush
  222. Latest episode of Engine Masters (flex sensor)
  223. Mercury ITS and Gimbal Ring replacement
  224. Bam 1550
  225. Bottom paint
  226. Baja 302 Bilge Float Switch Replacement
  227. No power to cool fuel pump.
  228. Sealing screws in cockpit floor- Sealant?
  229. Edelbrock Pro-Flo XT EFI system BBC in a marine application
  230. Water pump - leaking oil?
  231. Cannot get blown 454 to start.
  232. Running boat out of water
  233. Holley 8896-1
  234. Scan tool
  235. Pro Systems Carbs
  236. Gil/Hardin Shifter Brackets
  237. fuel electric and mechanical
  238. Best choice rocker arms
  239. Crane 139741 cam card
  240. Pink anti-freeze contains denatured alcohol?
  241. Alternator Woes
  242. 496 MAG HO - Service Manual
  243. Torque roll
  244. Cig, Sutphen, scarab, sonic or Formula?
  245. PSI 8.8 liter / 550ci ???
  246. Rev engine to check plugs
  247. Valve Spring removal tool for HP500 Carb?
  248. Deep-V Bow thruster installation
  249. Shifter problem
  250. oil leak on new rebuild
