View Full Version : General Q & A
- Which Gauges Do You Recommend?
- Small Block rebuild
- Fogging fuel injected big blocks for winterization
- Melting flappers and exhaust hose
- Water Separator/Fuel Filter
- Straight bottom V's X dimension
- EMI exhaust
- mercury oil filter
- Cam and Lifters
- marine carb selection
- Cigarette Gladiator
- mercathode
- drill size
- extention box
- info on aftermarket FI for 7.4L 330hp
- Ilmor Upgrade
- need help. 502 mag mpi
- speed hungry
- Questions about valve guides
- No Fire on a 540's
- Boat storage- shore power
- Help, question about an HP500EFI engine
- Poor idling SBC
- Engine alarm speakers/horn
- Boat stands/carts - where to buy?
- Gimbal Repair
- good intake for dart heads ???
- Tunnel Extension?
- XR Lower Gear Question?????????
- 1075 Merc what piston rings are used in it.
- Oil and Water Temp Gauges
- Biggest HP on pump gas?
- 598 vs 632 PROS CONS
- do iac's help with idle?
- 496 Sea water pump question
- Hey Griff!!!!!!!
- 454 mpi more hp?
- XR / Imco vert shaft nut came loose
- Detenation Lesson Learned 620 Teague
- Jesel belt drive installation
- Ethanol
- Fogging Oil ?
- Looking for
- Need 575i Weiand Blower
- merc 1075 sci
- morel lifters
- 800 holley ???
- Drive options for a 38 T/S Top Gun
- Dry Sumping Motors
- SBC 383 Roller Valve covers
- Shopping for 35 Motion trim tabs
- paging Griff
- msd or crane box ???
- building a 454
- Polishing & Balancing Props
- winterizing a Sea Doo GTXS
- Pulling a 525EFI ?
- 525SC pulley's on ebay
- cam for 500hp carbed
- Help W/ Set-up
- freshening a 454
- Morel lifters
- Cracked prop
- stand off box
- Distributor for Dart Tunnel Ram
- Aluminum or cast iron on exhaust elbows?
- 502 carb intake selection
- rm builder
- winterizing a Honda aquatrax
- Lifter Valley Screen Kits??
- leakdown test
- Inverted Oil filter trick??
- Mobil 1 Special... for what it's worth
- Looking at boat with 502's
- Opinions on Headers
- 10W-40 Amsoil Marine Synthetic Motor Oil
- Crane HI6M box Question
- 525s V 575s
- nonadjustable to adjustable rockers
- Gear Ratio...1.36 or 1.50 ???? Which would be right for me?
- Sheered crank timing gear key
- 850-900hp what you think?
- 2" Shorty on a 26 Sonic
- Looking for input on RacePumps.com Pump??
- 525 cam specs
- Ebay Scammer
- need an engine builder
- hydraulic steering kit needed ???
- Fuel line size?
- seawater fuel pump ???
- Remove Engine
- Alum. Heads
- I need help with jetting and PV (509ci, 8-71, dual 800cfm, 825HP)
- Merc 502 Oil Cooler, Rear Mounting
- Time to add the whipple & Raylar parts to the 496HO
- Identify motor parts?
- merc part #
- Winterizing 454mag
- Closed Cooling
- Livorsi mechanical indicators
- Break in oil over winter storage period?
- 20 teeth broken off of my cam gear!!
- upholstery protection in storage
- EZ source for CMI gaskets?
- Gen VI oil cooler adapter
- Throttle and Shifter controls Checkmate 25 convincer
- Anyone try spinning a 350 mag mpi backwards?
- Anybody ever had this occur?
- 525SC question
- External Steering: Full power assist or manual helm?
- Blower recommendations
- how big can i make a bbc merlin block
- best fuel line hose prices / heat exchanger
- over heating issue 500 efi
- dennis moore book
- 1 melted piston
- Stereo remote cables
- Smartcraft boat w/525s
- 496 Raylar Upgrade questions Opinions Ray?
- ? On Triple's Prop Rotation
- 496Ho Oil change ??
- Who has the fastest V-bottom boat on OSO
- water in oil, compression test question
- Just getting my rebuilt motor back, engine oil thoughts.....
- Fuel Problem
- help WINTER time for Ilmor V10-
- Value of HP500's
- Why is bottom paint slow??
- Large c.i. naturals with downturns...
- 502 spark plugs
- Injector ?? 496 chevy(2004) quick, easy
- Water in cylender
- Oil / power steering cooler
- Oil Line Size HP500efi??
- Header Question
- Strange Thing Happened - Port motor won't shut off with Starboard key on & vice versa
- Looking for big exhaust tips?
- 502 with low compression
- Oil Filter Relocation on 496
- Stainless Marine Exhaust help
- Anyone know about this 37
- Power steering pump
- Dana Marine refuses to sell replacement parts
- Chargers
- Autometer GPS speedo
- Bravo transom Decal
- oil line routing
- merc racing blue engine paint
- 575 SCI Oil Pump Pick Up
- roller lifters
- carbon on pistons
- water in block
- 2007 Mercruiser 525 efi
- Highest Naturally Aspirated Torque? BBC
- CMI switch from IMCO cast Header?
- oil filter change
- Rocker arm geometry
- 496HO Fuel Filters
- 500 efi swap
- timing cover
- Trailer brake questions!
- dean gelner or raylar question . please...
- Brackish Water
- Brackish Water
- Paragon Transmissions
- Can you winterize a boat without starting the engines
- HP850 SCi....Boost?
- Quicksilver Digital Diagnostic Terminal
- Thoughts on 502 roller cams?
- Diesel Engines
- 871 questions
- Late 502 mag mpi
- which way does an oil filter flow?
- intake manifold gaskets
- salt water block cleaning
- 1.35 vs 1.5 ratios
- Putting on a new set of heads...
- 502 water in the oil help!!!!!!!!!!
- Perelli flooring
- 496HO Question for PMC555 Experts
- 525 SC service questions.
- oil cooler size,inner cooler plumbing
- base timing vs timing tables on mefi 3 or 4
- coupler
- Going synthetic
- thermostat housing
- Ohc Bbc?
- overseas shipping
- Water Pump type comparison?
- Reason for 0 pressure
- Mercury496HO
- 575sci Head Gasket ??
- Exhaust system ???
- More EFI to Carb Questions
- 540 engine builder
- timing cover
- Hydraulic Steering Question???
- Bigger Oil Cooler for 502MPI????
- Why doesnt anyone share tech info??
- Merc. 700SCI 600SCI Fuel Injectors
- Interior v.s. exterior steering mounts?
- Drive lube Testing
- x-dim - Improper Lingo?
- Quad Whipple Acting Up
- please help 502 water problem
- mechanical advance for my slow boat
- 502MAG EFI Synthetic oil
- Surveyors - Chattanooga
- cam selection
- head studs and bolts
- Who does extrude honing ??
- Sucking antifreeze through the drive
- Tach and Oil Pressure Flucuates 500 efi
- Alternator
- Remote oil filter block adapter ?
- Merc engine specs.
- aeromotive fuel pump
- Mechanical Fuel/Water Pump Leak/Fix??
- 500 efi oil temps
- Mercury 575
- new engine/blower combo no boost update
- roller lifter jam
- 575sci High Idle Question....
- Water temps (carbed 500HP) !!!!!!!
- sea water pump housing for fuel pump needed
- 496 Oil Pressure
- circulating pump
- crane 168731 hydraulic roller springs
- Replacing impellers
- Merc 525 Code Question
- Oil pressure drop??
- stock Merc 502 efi cam , do i need different dist gear?
- Exhaust Diverter Leaking
- Low vaccum - Can't find the leak - Anybody have advice?
- broken spark plug
- Short flame arrestor HP 500
- 496 ? Plug and Play help
- Differential Diagnosis on ignition brain
- HELP need GPS molex pin colors
- 502MagMPI conversion to Carb
- Inflatable Life Vests
- ZDDP replacement coming
- Royal Purple 15W-40
- Oil temp to hi, 540 w/blower
- The highest ZDDP Synthetic I can find
- Shell Rotella T
- Kendall 20W-50
- GM EOS Break-in additive
- The best ZDDP break in additive I can find.
- The best conventional 40wt I can find.
