PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 502 MAG MPI Cam swap
  2. Still Looking!
  3. Running a boat on the hose in freezing temps?
  4. superchillers
  5. ignition coils
  6. Mercruiser HP425 Gen V Big Block pistons
  7. Did GM sell a 509 block from factory
  8. The trouble with Blowers is:
  9. Stainless exhaust tip flappers ???
  10. What cams will work with stock lifters.
  11. Knock sensors for 502 mag mpi
  12. Another build dyno'd today. Whippled 509.
  13. Compression Ratio
  14. Anyone Been To The Louisville KY Boat Show??
  15. Installing new Camshaft
  16. Nordskog GPS speedometer wiring..
  17. Facebook tech.
  18. 1994 mercury racing hp 465?
  19. 454 cam
  20. The GM/Merc Rectangle port head. Discuss.
  21. morel hyd roller lifters
  22. Pushrods
  23. Who has 575sci TB?? any motor shops??
  24. Big cube n/a combo's
  25. What head should I use
  26. Leaking Trim/Trim Tab Pumps
  27. Engine Guys help (scan tool to use) on 97 454mag mpi's
  28. Diacom software ?? - where to hook up on 525EFI ?
  29. 502's with roller cams have some saltwater spots on them, Replace or run?
  30. 454/502 Mag Camshaft GM # 12551622
  31. 540 Clearances and oil pressure thread...
  32. Identify this raw water pump?
  33. cnc d heads
  34. Piston Mercruiser 496 HO
  35. Machining Fuel Rails
  36. 454 Gen 6 Engine Cam Question
  37. 600SC mechanical fuel pump ability??
  38. Looking to instal a 496 Mag HO where there was a 7.4 MPI
  39. Procharged 502 Mag Oil Cooler Recommendations
  40. Bravo One outdrive
  41. 700hp 540s
  42. 454 rebuild with blower... Pistons and clearances.
  43. Help! - what happened to champion cylinder head co, palm coast, fl?
  44. good rockers for 6000 rpm, 540CI combo??
  45. 525 whipple charged engine weight
  46. Flywheel balancing
  47. Broken xr case repair?
  48. B&M blower identification
  49. noise under valve cover
  50. Need FlyWheels...Internally Balanced
  51. Anyone running Imco powerflow manifolds on ZZ502
  52. TRS Values
  53. any proffestional tile setters looking for work
  54. Prop slip increase with speed.
  55. Oil Pan Swap / Value
  56. Carb vs Fuel Inj?
  57. CMI headers leaking....HELP
  58. anybody with 496 HO using stainless marine exhaust?
  59. Elbow restrictor gasket vs full flow gasket
  60. Would you guys use this?
  61. velvit drive pump
  62. Rubberized spray flooring?
  63. Couple quick questions - piston install
  64. Tuners or Chips?
  65. How many RPM's can the stock 500HP rotating assembly take?
  66. Who is not running 45* valve angle?
  67. In-Control Shifter
  68. Crank to crank measurement / drive centers
  69. Bumpers and ropes???
  70. What oil pan is this???? Gen6 bbc
  71. 87 scarab excel 26 convert to bravo is it worth it?
  72. powerquest 270 laser cockpit
  73. Article about valve angles
  74. New boat soon, 32' BT, 29' Scarab, 31' Scarab, or another Formula??
  75. Piston top displacement stats needed
  76. worth the trouble?? 47 fountain
  77. New carpet for a Cigarette 20
  78. Water preassure in Bravo XR?
  79. Storage of gasoline
  80. conversion i/o to o/b help.... pics... info... anything
  81. Couple quick questions
  82. Grilling go fast
  83. Good mechanic
  84. lightning headers in a 25 Daytona?
  85. Mechanic needed pompano beach area
  86. 502 mag mpi not priming oil??
  87. Turndowns and water reversion?
  88. Fuel Stabilizer or Octane Booster?
  89. Found a 525 short block! What's it worth?
  90. +.300 lifters
  91. Baja 33 Outlaw Parts
  92. Search Tempest - Trojen virus??
  93. The million dollar question
  94. msd
  95. determining oil
  96. EFI 525 rear mounted camshaft sensor???
  97. Merc 700sci hrs/lifespan before rebuild
  98. Roots supercharger intake question
  99. Trouble free 525efi - do they exist?
  100. Different size headers
  101. Blower Application - Fuel Pressure Reg. & Return Valve
  102. 502 Ring Recommendation Please
  103. Good Bad opinion Formula 292 or 312
  104. original motors in a 91 sutphen
  105. Leaking Hatch Rams
  106. Mesa Balancing
  107. HTM oil pressure gauge
  108. Regular or Swept back
  109. Budget 454 Build
  110. 420hp 454
  111. benefits of distributor-less ignition
  112. 454 Repower
  113. 500 efi
  114. Dropping some weight on a HP500 carb?
  115. Any one interested in a boat move New Orleans to Detroit Area
  116. Best Cam Choice - Non-roller 350 with Vortec heads
  117. Steering Wheel rotary circuit switch?
  118. Carb talk
  119. Carb CFM?
  120. Gil Manifold Thoughts
  121. head gasket ?
  122. Going blown have a few questions?
  123. 97 PQ 270 laser wt twin 350 mags to 383 400hp what kinda speed
  124. 350 mag rebuild to 383. oil cooler Question
  125. AN fittings and Stainless braided lines
  126. what's the best clamp on muffler/silencer
  127. Formula 242 drive height.
  128. B&M 250 vs 420 Mega Blower
  129. 2001 Sea Ray 280 SS Engine Question
  130. Low water pickup depth below bottom
  131. Have you seen this exhaust manifold before????
  132. 500HP top end in a 502 MAG
  133. Performance Boating Magazine
  134. 525EFI Valve Springs Concerns
  135. Favorite BBC Rod Thread
  136. Upgrades to Cabin Door and Hatches.
  137. Calling all mechanics
  138. Pulled one of my gimbals and the transom is in great shape! Do I still replace it?
  139. Looking to set up a back-up bullet for the chamber
  140. HP 500 Head and Cam upgrade
  141. Alternates for Bravo drives
  142. 7.4 mpi stock cam specs needed
  143. Can you keep the thermostat and circulating pump on roots type blower motors?
  144. engine adjustment front and back.
  145. Fuel system set up
  146. valve spring bearing
  147. Twin engine power steering question
  148. CMI Headers vs Stainless Marine
  149. Removing Silent Choice Exhaust ???
  150. .937 lifters?
  151. Rod bolts, main caps, and what not.
  152. Best oil filter with sandwich adapter and plugged bypass?
  153. Any suggestions on a bench buffer & polisher
  154. Borg Warner 72C transmission upgrades?
  155. Choosing Valve Covers
  156. Another Omc thread
  157. Smartcraft Alarm
  158. New Holley Ultra HP carburetor leaking fuel from throttle shafts....Ideas?
  159. Hyd. roller lifters to solid roller lifters?
  160. swapping k throttle
  161. NXT Transmission
  162. Piston to valve clearance - 454 Mag short block
  163. Fitch Fuel Catalysts
  164. Best place to order Mercury parts from
  165. Need an Anchor
  166. Corvette C-7 LT1 Engine for marine use?
  167. Silent Choice on a 525 EFI 29' Fever
  168. 731 or 741
  169. Oil pump thread
  170. De-tuning my 2001 ilmor supercat 517
  171. Missing skeg(s) and cavitation plate
  172. 502 mag torque #
  173. Is there any product that softens vinyl (interior)? What is the best cleaner?
  174. Drive couplers
  175. boat length?
  176. Blown head gasket and worn wrist pin... rebuild advise?
  177. Wellcraft scarab cv 7.4 v8 engine.
  178. Pressure checking manifold,headers
  179. Flat vs Roller, Blown 454
  180. Can you make a 502 mpi flow more air?
  181. 525 Header/Tailpipe issue
  182. 1" or 2" carb spacer
  183. Dyno proven 675-700 HP 540CI recipes?
  184. Talk to me about closed loop cooling...any reason not to?
  185. Need Help on Heads on Gen 5 454's
  186. Need Help on Heads on Gen 5 454's
  187. Upgrades to stock 350 sbc
  188. Hawk 502 specs
  189. Bearing clearances, oil weight, and more...
  190. Intake Manifold
  191. Fuel Pump and Filter mounting
  192. Hydraulic vs Electric trim tabs
  193. EFI intake
  194. GoPro Cam Choice. . . .
  195. Carb to EFI
  196. Time to rebuild the 502...
  197. Oil restrictor size hp500
  198. 1976 stinger jet boat
  199. Want more hp out if my 502?
  200. How do i get the air out of my K-280's trim tabs?
  201. Has anyone used the new merc digital trim indicators?
  202. Fountain bilge light - bulb ID
  203. How is compression ratio figured?
  204. Who's going to the PRI show next month
  205. IMCO fuel valve instructions please
  206. procharged 502 fuel system
  207. 540CI builds, MAX RPM?
  208. Bravo or Bravo x3
  209. Midrange and low RPM grunt. Discuss please.
  210. 2011 Sea Ray 240 captain seat cylinder adjustment
  211. HELP i have a gremlin onboard
  212. SB Exhaust manifolds
  213. 8' beam into 7'9" garage door
  214. Antifreeze for Winterize Mercury 700's?
  215. Cam Questions - Little Help/Direction needed
  216. single plane intake vs. dual plane
  217. Blue engine maint?
  218. Top end refresh?
  219. Enine Builders?
  220. 388 hustler that was in the classifieds
  221. Looking for some real out of the box thinking....
  222. another milkshake
  223. What size is this
  224. HP 500 valve covers....
  225. Best way to clean old fuel tanks
  226. ss rod ends?
  227. Weiand 177 or 256, which kits?
  228. Step By Step : Building An 871 Blower
  229. Baja 240 sport (24 outlaw) VS 250 (270)es
  230. Where to buy bolster tops?
  231. Fuel pump
  232. How to tell if its an HP gimble ring or not?
  233. Projected or non with blowers?
  234. Smashed Plugs on fresh re-build, any advice?
  235. Does prop slip increase or decrease with speed? Top speed less than expected.
  236. Smartcraft gauge rigging question
  237. What is this plate called and where can I get one?? SsmII
  238. Antifreeze/Magnesium question. (non boating related)
  239. 1999 vortec 454 yes or no
  240. Anyone change an Oil Thermostat in a HP500 Filter housing?
  241. Circulating Pump Size
  242. Using Marine battery in Truck?
  243. motor oils prefered on performance boats
  244. how to remove gas overflow stain side of boat?
  245. Holley fuel pump safety switch 12-810. 2 bad in one year.
  246. Engine Rebuilding
  247. header friendly sub for r44xls
  248. HELP PLEASE....Thoughts on repowering
  249. Roots Blower Sizing
  250. Engine Pre lube systems
