PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Cometic Gaskets
  2. Very long exhaust question
  3. prop testing procedure?
  4. Rpm and Horsepower limits TRS?velvet Dr.
  5. electronic ignition ???
  6. Boost didn't drop?
  7. More drive ??
  8. 502 MPI problems
  9. Battery Rundown
  10. Aftermarket Pulleys & Scat Crank?
  11. Gaffrig Red-Line gauge failures
  12. Help with my Vibration
  13. Fuel Tank ?
  14. Dumb q about speedmaster drives?
  15. Oil Pan bolt torqe?
  16. Props
  17. Oil Filter for HP500EFI
  18. Calling all cigarette bullett owners
  19. Mercathode.... Should I pull the plug?
  20. NKG Source ?
  21. vortec +ariz. speed and marine kits?
  22. MEFI3 Stock 2001 502 Fuel pressure
  23. T-Stat ?
  24. porpose problem
  25. props again
  26. which procharger???
  27. changing valve springs
  28. Spark Plugs
  29. Water Pump
  30. Outdrive leaking
  31. DYNO Results
  32. K&N filter system
  33. mercury dist. cap for 1998 502 efi?
  34. trailer brakes dragging
  35. 98 454Mag questions on HP upgrades
  36. Bottom paint/coatings
  37. pulleys
  38. EFI computer memory?
  39. Plumb Perma-cool Thermostat
  40. How fast will it go?
  41. imco shorty
  42. Hydraulic Steering Question
  43. Back on the Dyno
  44. Re rigging a 30' Oceanpacer...
  45. out drive lube leaking
  46. 500hp valve adjustmens
  47. Houston Propeller RULES!!!!!!!!!
  48. How do I post pics of my boat on OSO
  49. No Spark
  50. acceleration of a 2-stroke engine
  51. Another Prop Question
  52. Stereo problem
  53. Max Hp for Alpha & Bravo
  54. speed master #3
  55. Help quick...No drain pug in lower unit!!!!!!
  56. Keel Roller
  57. cam selection
  58. Adjusting Float Level
  59. HP500EFI's at 200 hours: anything special need to be done?
  60. Question for Air Cond. techs
  61. Holley 850?
  62. FireRing Gasket? Merc Manifolds
  63. What sealant to use? K-Plane to transom?
  64. adding shore power
  65. hp500 valve springs
  66. Mud ingestion ? . . . lo-water pickup
  67. 454 Mag Intake Manifold
  68. Whipple Stage 2 Kits
  69. Shorepower question
  70. mercruiser 525 sc install
  71. Galvanized Steel
  72. Merlin heads on hp500efi???
  73. Lexan cover sheets
  74. 2001 454 mag
  75. Paging Scott72
  76. 500efi's How many hours can they go for?
  77. TRS steering problem
  78. any electrical whizzes out there?
  79. Stainless/Braided Fuel Hose & Fuel Pressure Guage
  80. drive showers, thru hull exhaust, oil
  81. Thru hull tip sealant
  82. Crossovers
  83. bravo hinge pin
  84. Running LEAN
  85. Drive Question..
  86. Bravo 3 corrosion problems-long but worth it-
  87. HP 500 Plugs
  88. Gear Ratio / Prop Pitch Question
  89. Need help-can't get over 4400 rpm after upgrades
  90. bravo 1 gear set change ?
  91. nortech 38
  92. Cool Fuel ?
  93. K-planes not working
  94. Help Quick!! Gapping plugs and can't find my gapping tool!!!
  95. Adding cup to a prop...
  96. Changing fluid in Bravo I
  97. 32 Fever - Captains Call malfunctioning
  98. Trim-in-Handle switch problem?
  99. Can I add the standard water intake holes to my LW pickup drive??
  100. Can an intake manifold be "decked"
  101. Water pump bypass
  102. Where's my A/C?
  103. props with a 1:36 gear Bravo 1
  104. Trim Gauge
  105. smell of synthetic oil
  106. Prop pitch, speedometer
  107. Cavitation plate for bravo.
  108. Lifter noise and oil weight/qty??
  109. Gimbal Bearing Replacement
  110. Rotating engine by prop??
  111. No Fuel Pressure
  112. Trim, blower and bilge pump problem, any ideas?
  113. Drive couplers don't need no grease!!
  114. labbed prop vs exhaust system ?
  115. help! cracked heads?
  116. Power Steering
  117. alternator noise[bearing]
  118. Mich noise level ?
  119. TRS shimming questions
  120. Intake Centerline Position
  121. Changing to new style exhaust shutter's... WTF?
  122. vortec superchrger ?
  123. New member of the broken drive club..Need Advice Quick!
  124. EGT and Fuel Return
  125. Adjusting valves with engine running?
  126. Zincs for Kaama
  127. Engine flush valves
  128. JE Pistons compare to SRP (75F)Pistons
  129. Oil Pressure Switch Please help
  130. Checking Injector
  131. Effects of not enough timing advance @ idle
  132. 454/502 Mag MPI (Gen VI) Replacement Camshaft
  133. Correct way to time a TB 5 for max performance?
  134. AN fittings angle
  135. mercruiser 525 sc
  136. Revolution 4 vs Mirage plus
  137. Mechanical Fuel Pumps
  138. How to refinish Kiekhaefer controls?
  139. Diesel in Gas
  140. Imco Valve covers
  141. Octane for 525 sc's
  142. Embarrasing....Need SBC Firing Order
  143. 502 Identification
  144. What kind of engines do I have?
  145. Corsa Muffler removal with 5200, Sucess
  146. Question for MBAM, or anyone who knows...
  147. I'm relocating my oil filter/question?
  148. SSM III-IIIA
  149. Trouble starting 496 Mag
  150. Anybody thrown a rod? What to expect?
  151. Autometer needle
  152. 502 carbed spark plugs
  153. what spark plugs on 454mpi 2000 385hp?
  154. Pyrometer's
  155. 35 Fountain Help
  156. Yamaha drive conversion. to Merc ?
  157. Weber Carbs
  158. Fiberglass Nose Cones TRS?
  159. Kaama Surface Drives Slow to Plane
  160. Exhaust Risers
  161. 502 File Fit Rings
  162. Dumb question about engine building?
  163. Battery charger / maintaining
  164. Gas Tank Vent Question...
  165. Electric Fuel Pump
  166. K&N Oil Filter Application?
  167. zinc based primers
  168. Low H2O after pump change
  169. Fuel Pressure&Oil temp Sensor
  170. Gelcoat spray gun
  171. Carb to EFI conversion questions?
  172. Diaphram Bilge Pumps died again
  173. Fiberglass cutting
  174. Increase pitch or add a blade?
  175. What HP will Merc stock exhaust support on a SBC?(Paging Dennis Moore)
  176. Merc 600sc?????
  177. best place for trailer brake parts
  178. 500efi,where To Tap In For Water?
  179. Hot spots in headers
  180. Outdrive Oil
  181. Crossover vs. Circulating Water Pump
  182. Twin Outboard hyd steering?
  183. HP500 Mystery
  184. Vibration issue at 3000+ RPM's
  185. Bravo XR "minor" particles on drain plug
  186. Oil Pump Question
  187. 502 merc
  188. royal purple
  189. Best Hull support location from boat lift bunks??
  190. trim ring gaskets
  191. engine pulleys
  192. big ci bottom end
  193. TRS to SSM3???
  194. Turning motor by hand-trouble signs?
  195. rust in exhaust ports
  196. X Dimension
  197. Oil - Synthetic vs Petrolium w/HP500's?
  198. Stern lifting vs Bow lifting
  199. Hyd. Steering A Special Thanks!
  200. Drive Corrosion
  201. Gimbal Ring Repair With Stainless Swivel Shafts
  202. No Water temp???
  203. [B]HELP PLEASE[/B]-EGT dropping off #2 Cylinder -
  204. Stainless Hose Covers
  205. revolution marine exhaust
  206. Lab Finishing props ?
  207. Boat wiring color codes (edited) PRINT THIS OUT!
  208. How much extra HP to spin and IMCO drive?
  209. gel cote coloring
  210. Houstonprop
  211. Powdercoating?
  212. $$ savings on merc. anodes!
  213. Who are the Best Supercharged Engine Builders?
  214. exhaust tip silencers
  215. Hydraulic Steering Remote resevoir
  216. Question about Mercurys 900sc
  217. Engine is on the Dyno!!!!!!!!!!
  218. How to keep Aluminum from Coroding
  219. OSO Discount
  220. More stereo questions
  221. Paint for gauge rims
  222. Opening-up exhaust holes in transom
  223. Gen. VI Cam??
  224. Torque Spec For Lightning Headers?
  225. Yamaha stern drives?????????
  226. Crank trigger pickups
  227. Getting the boat off trailer
  228. Stereo Amp question
  229. Aeroquip, Earls or Russell Fittings
  230. blower shop 250
  231. 1987 260 mercruiser info needed
  232. Cd Players In Boats
  233. Dyno Abbreviations
  234. Saltwater Questions
  235. Thermostatic oil filter adapter
  236. Speedmaster #3 to #6 drives conversion
  237. Never winterized!!! Now what should I do
  238. upgrading fuel lines?
  239. helm parts question???
  240. Bleeding power steering Dos and donts
  241. DUI vs MSD Ignition
  242. aftermarket manifolds
  243. 540 bulldog
  244. Leaky Water Pump
  245. Alpha steering, what wears?
  246. HP500 cam choice
  247. CMI Problems
  248. Help! Pilot bearing - Do I need it?
  249. Cam ?
  250. Blower ?????
