PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 454 longer rod & shorter piston OR shorter rod and taller piston?
  2. I think i lost TDC. HELP
  3. Camshaft Identicication
  4. shift interrupter relocation pics please
  5. Best prop
  6. Reversion with Y Pipes in 600sci???
  7. Gen 5 efi system on to Gen 6 mag?
  8. Raw Water coolant pressure question
  9. HP rating for stock GM main bolts
  10. Looking for a big quad 4X4 EFI
  11. Fuel consumption/mileage
  12. Exhaust Manifolds
  13. Aftermarket fuel injector
  14. Which head gasket to use BBC salt water
  15. 502 flywheel removal
  16. SleekCraft Enforcer 28 general questions
  17. Looking for Delphi numbers
  18. Coating for Aluminum Heads
  19. K&n eci
  20. Noise reduction with dry headers
  21. Old Topic New User/CMI 525 water in oil
  22. Help with IAC motor on 575sci
  23. 4.3L Mercruiser lifter rattle?
  24. Mercruiser 454 Mag Gen 6 / Volvo 7.4 GSi
  25. Need help identifying felpro 17201 17205
  26. Ideas for pickups, pressure relief valves
  27. Tilt and trim problems
  28. 700sci Help
  29. GM 188 head question
  30. Plugging floor holes
  31. Wellcraft 88 23XL vs 85 Nova II 26’
  32. 502 MPI to a 500EFI
  33. Cold Start Backfire and other questions about my new build
  34. Final configuration of rebuilding my 502
  35. Oil thermostat
  36. Blocking center oil returns on small block
  37. Mercury 600 SCi wateroutlet Intercooler??
  38. How can you check if your getting exhaust water revision?
  39. Oil temperature sensor location on 454 mag
  40. Steering without motor running
  41. Crane 168731
  42. My tachometer (Faria) does not work (496 HO)
  43. Mercruiser 496 HO, which year model?!
  44. Running Out of Ideas / 2006 twin 496 MAGs
  45. What exactly is needed...b1 to xr
  46. Holley 1250 super sniper is released
  47. Head flow catalog
  48. 454 gen v trimmings on new 502 6 gen?
  49. Intercooler water flow
  50. 525SC max lift with stock pistons
  51. looking for input on performance parts for genV 454 merc
  52. Gaffrig Performance
  53. recomendation for fuel pump
  54. 177 swap to 250 on 525SC
  55. Coolant flow chart for 2013 Mercruiser 377
  56. Who makes a nice NA Serpentine Accessory Drive with Dry Sump
  57. Ferrea Question
  58. Why don't you see more bigger CI Na combos
  59. Mercruiser MEFI ECU Spark Table
  60. 525SC Rebuild Recomendations
  61. Holley HP EFI Data Logs
  62. Mark IV 502 Oil Cooling Questions to 540
  63. Which damper plate to use for 500hp and Bravo
  64. What valve seals for 1990 454 mag engine????
  65. question on removing silent choice or leaving it, whos done it?
  66. Fuel in Sea Pump Gear Lube
  67. Fuel in Sea Pump Gear Lube
  68. What Procharger Should I Use?
  69. Mufflers
  70. Gen4 w/retro-fit roller questions
  71. Flywheel housing and coupler questions, Mercruiser 5.7
  72. Water temp ?
  73. Blower Re-timed?
  74. Running 496 on a stand
  75. Dumb question about new format...
  76. Livorsi GPS Speedo Not Working
  77. Which Cylinder Head ? Brodix , Profiler , AFR , Dart
  78. Lack of bore notching on big $$$ engine builds
  79. ignition coil
  80. Looking for cabin door hatch piece, Donzi 33ZX
  81. How many hours on a 8.1?
  82. Crane, Morel, Comp Hydro rollers
  83. Lower crank pulley HP500
  84. trs skeg
  85. CMI Big Tube E Tops
  86. What is Big Deal w Big Chief Heads ??
  87. Sonic parts washers
  88. 250/420 Blower intakes new?
  89. EFI opinions for SC BBC
  90. Trim Tab wiring Diagram on a 2007 Baja Outlaw 26
  91. Hatch Scoop Direction ?
  92. Gimbal Ring U- Bolt Lock Nut Torque Setting
  93. Changing fuel system on twin 496ho
  94. Please Help! Identify and Value
  95. Idle speed
  96. State of the Industry
  97. Crane 731 vs 791
  98. Timing advise 502 carb DUI distributor
  99. Best book for Mercruiser 525SC rebuild
  100. Factory Mercury rocker arms or Chinese garbage?
  101. Could someone run a desktop dyno on my combo?
  102. Help needed new 468 build having reversion issues
  103. Refreshing my ZZ502 short block.
  104. 454 CLOSED LOOP COOLING Question
  105. k plane trim pump oil cap dipsticks
  106. Mechanical outdrive indicators
  107. 1990 mercruiser throttle sync
  108. Small green fuel hose
  109. Oil Stains on Vinyl
  110. 489 build for 3500lb Donzi Need engine build advice
  111. Thoughts on push lock fittings?
  112. Mercury 844341T02 Mount dimensions
  113. Gil or emi exhuast
  114. Oval or round port heads on 454 330
  115. Best Exhaust Manifold Gaskets
  116. oil cooler size 1000 hp +
  117. Replacement starter
  118. Oil Cooler leaking water into Oil?
  119. Gen V Water Pump Backing Plate
  120. Sluggish operating Lenco electric hatch lift motors
  121. Why do MSD ignition boxes go bad?
  122. Oil Filter Relocation Instructions
  123. Merc Water Pressure
  124. Merc 377 oil change - jelly oil
  125. Oil filter question
  126. Boost!
  127. Dart Big M vs Merlin IV
  128. Alternator mount
  129. moisture meter question
  130. Cam and lifter advice
  131. spark plugs
  132. Exhaust cutouts
  133. Gauges
  134. info on my motor
  135. Procharging 500EFI's
  136. Challenge! Need a 8.1 VP mechanic in southern va or northern va.
  137. 496 fuel tank requirements
  138. 350 turbo tranny help
  139. Advance for 500EFI
  140. Edelbrock enforcer supercharger Eaton TVS 2650
  141. 525SC Pig in a poke *HELP PLEASE*
  142. Superchargers and outdrives
  143. Gen 3 Cool fuel module
  144. Stainless Rub Rail?
  145. 632" Crank & Rods , opinions and reviews wanted
  146. Raw Water / Fuel Lift Pump Toast?
  147. 1990 Lason Senza 250 Spectre.
  148. Who for tail pipes these days
  149. 16 ft 1977 Apollo that needs work
  150. Wtf. Pushrods.
  151. Donzi Classic 18 upgrade
  152. boat rigger needed on the east coast
  153. Auto Meter
  154. TBS blower pulley hel
  155. Gaffrig mufflers
  156. MercTrans II TRS oil leak
  157. 1071 superchargers
  158. Oil pressure drop - need advice
  159. opinions / advice, need a cooler
  160. Seized Trim tabs
  161. New to site and new to go fast style boats...
  162. Anyone heard from
  163. Cat hull vs V Hull
  164. 454 (7.4) Impeller Housing O-Ring Available Separate?
  165. Engine cooling
  166. Howard's cams
  167. 572 vs 598
  168. Merc 280 K-Planes
  169. I want to upgrade the engine mounts in the 2000 Scarab 33 AVS
  170. Lets build a 502
  171. Bolster upholstery
  172. 502 MPI Idle Issue...
  173. Cool test between head volumes
  174. Closed systems, when did the cooling become marginal (oem 496 setups etc)
  175. little upgrade
  176. How exactly does the Merc seawater cooling system work
  177. sbc: comp cams xe262 reversion risk?
  178. Exhaust Tips
  179. Compression Check
  180. Whats the real differences in drive couplers??
  181. MK4-Gen balancer. Any diff?
  182. Scorpion 4014 roller rockers on 496.
  183. 540 build Cam choice
  184. Quick question on motor refresh
  185. B1 Via 454 MPI Vibration
  186. Thanks!!!!
  187. Looking for contact info??
  188. Can someone use engine simulator to help with cam selection?
  189. Boat. Mover
  190. New Boat
  191. BBC valve train
  192. K planes on Convincor?
  193. Hydraulic Steering Kit
  194. Weldon Fuel pump Question
  195. Cover recommendations for Donzi 35ZR
  196. Comp cams Short travel lifters BBC
  197. straight tube to replace cool fuel
  198. Help with misaligned throttles
  199. Blue tooth speakers waterprrof
  200. Thermostat recommendation sbc
  201. 525 sc gurus
  202. 454 Mag HP/torque guess?
  203. 600 ci NA build
  204. Need help locating BBC engine accessory drive kit
  205. Drives won't trim in
  206. 100 psi fuel pressure mercruiser 5.0 mpi
  207. Mercathode Controller
  208. How to Lower Compression?
  209. 2 questions and the plan
  210. GT Performance
  211. blower housing / diesel shop
  212. Blower shop snout size
  213. Dart 525 heads
  214. manually turn crankshaft
  215. 525EFI Rebuild
  216. 525 sc crank pulley
  217. Best Intake for a EFI Build- BBC 598
  218. Best EFI System for Big Block Chevy- 1200hp+
  219. Trim Pump - solenoid or motor?
  220. Exhaust system question
  221. Can't order oil on weekends!?!?
  222. 1989!Baja 226 won't plane out!
  223. Used roller lifters
  224. 38' Scarab boat cover
  225. Diffrent seawaterpumps on Bravo Applications???
  226. Timing vs AFR vs EGT
  227. Any luck repairing heat exchanger?
  228. Anyone have an issue with the Hardin Marine weld in quiet flappers?
  229. 8.1 vs 8.2 mounting
  230. CNP mounting bracket
  231. rigging a boat with #6s
  232. BLP carb main bodies
  233. Silencing Options
  234. Any value in boring??
  235. Best Electric fuel pump
  236. Bravo 1 on XR transom?
  237. Carburetor Video
  238. More oil for Lines and Cooler?
  239. odessa cylinder head
  240. Merc 1000 SC cam specs and Straub
  241. CMI problems
  242. Retarding cam - help reversion?
  243. First leakdown test, what does it mean, exactly?
  244. head gasket selection
  245. Holley Sniper EFI
  246. Which top mount starter to buy
  247. 1999 1952 Bayliner mercuiser power issues
  248. Muffler / turn down questions
  249. 1984 Merc 350 rebuild
  250. Running a thermostat or Not
