PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 [168] 169 170 171 172 173 174 175 176 177 178 179 180
  1. Future engine compared to current.
  2. Need help with a 4.3 v-6
  3. bravo 1xr
  4. Compression Ratios?
  5. Keith Eickert Headers
  6. Bravo drive -left hand rotation
  7. Best paint / gelcoat?
  8. Headers
  9. Changing the oil in a 32' Fever - Whats the best way to get the oil out?
  10. Tie Bar Sizing
  11. gear lube
  12. Anything else?
  13. what size k planes???
  14. what prop?
  15. New 525 Hp in older boat?
  16. How Cold?
  17. Adjusting rocker arms?
  18. Quicksilver single engine control on e-bay
  19. Should I spend money on exhaust to wake this engine up?
  20. mega blowers
  21. SBC Cam ?
  22. Mercury or Yamaha O/Bs?!
  23. fuel delivery
  24. Ext Box
  25. HP 450 Questions
  26. Intercooler Installation?
  27. Anyone ever deal with Boost Power???
  28. Supercats 130-150 mph, prop rotation?
  29. New Cam for 502 Mag
  30. Windshild or Windscreen
  31. Merc 420 spec's ??? What is it??
  32. the most for the least!!
  33. Help with head choice needed
  34. Custom Mounts?
  35. aluminum connecting rods ?!?info req
  36. ratio?
  37. is it possible: 20 hours non stop 3000rpm turning engine..
  38. 7.4L MPI Questions
  39. Smallest Engine/Outdrive combo
  40. What the $ell is a sea pump?
  41. N-Ter Cooler Chiller Kit for Superchargers
  42. 454 cid 330hp -- want more HP
  43. tiller arm?
  44. removing a 12" ext box
  45. Fuel Pressure gauge installation
  46. looking for performance&calculation software
  47. how to calculate blown engines carburation?
  48. 500 Efi
  49. 575 specs
  50. K-Planes or not???
  51. Batteries in an older Cigarette?
  52. Problem with Volvo 5.7 motor! Need help BEFORE Key West
  53. Blackhawk steering bracket
  54. Portable Ignition and Gage Panel Cart
  55. painted gearcases vs. "naked" g.c.
  56. Greasing the lower unit/drive components
  57. Advice wanted on winter engine maintenance
  58. FUEL line hoses will not fit
  59. need info :tunnel ram advantages and disad.
  60. Diesel Performance ???
  61. Vibration
  62. Fuel gauge sender - suggestions
  63. Silent Choice
  64. what is the reasoning
  65. how can I tell what engine I have
  66. ProCharger, Whipple, etc..and spark plugs question
  67. Nasty Looking Oil....problem?
  68. Which intake manifold should i use? single plane or dual plane
  69. Power Bolster Actuators
  70. OMC to Merc??
  71. spacer
  72. drive showers/BRAVO 1
  73. Small un seen little things...:)
  74. Heads Mark V or VI fit IV block?
  75. Stelling Boxes on my Formula 302
  76. Gasket sealer for Exhaust Manifolds.
  77. Who has EMI SS silent choice risers
  78. Old Skater
  79. Big block vs small block
  80. Boat trailer VIN locations
  81. '86 Checkmate Starflite/ '89 Johnson 225
  82. ON-BOARD-DYNO Pictures
  83. Engine balance - Cast vs forged
  84. Pro Topline Cylinder heads
  85. Lake Norman, pref engines
  86. MPI or carb
  87. hydraulic steering
  88. another hp500 valve spring ?
  89. How hot before warning buzzer on HP500 EFI?
  90. looking for breaker
  91. Questions and Answers for Magazine, Dennis Moore
  92. Which electric fuel pump for 1000hp?
  93. Oh Oh, is this a problem?
  94. How to remove Baked on exhaust grime?
  95. Group Discount on Vortech Superchargers (Procharger guys can read this too!)
  96. Explain Drive Shower
  97. Arneson Surface drives
  98. hp estimation-help needed
  99. do I need aftermarket heads for blower application?
  100. camshaft question
  101. Where do you connect water pressure gauges?
  102. What motor oil?
  103. fuel pressure tap?
  104. 502+250 Supercharger=questions
  105. Fairing Project
  106. Whipple Charger or Vortech Supercharger
  107. 256 or 177 blowers
  108. Zero Effort Controls
  109. need some valve spring assistance..
  110. Baja HAMMER owners INFO WANTED
  111. Water drips between head and Block...
  112. 'powder!!' octane boosters
  113. Another winterizing question
  114. Engine alarm died on port engine
  115. measuring X ????
  116. Alarm / Buzzer wiring on HP500 EFI
  117. Alpha One drive oil leak?
  118. forged piston OIL consumption
  119. Oil on the intakes?????
  120. looking for fuel log (large)
  121. Jayl13, how's your engines??
  122. Surface drives...
  123. Good, honest advice wanted.
  124. EMI or CMI EXHAUST???
  125. what amount of boost is optimum with pumpgas on 8.25:1 cr BB?
  126. carb?
  127. Johnson 225 outboard impeller replacement???
  128. Aftermarket oil pans?
  129. EDDIE MARINE EXHAUST (color)
  130. clarion changer
  131. Starter Problem...Please Help!!
  132. Lower Michigan Guys!!!!
  133. Port Velocity??.... Dennis Moore
  134. oil pickups on a new pump, weld or not?
  135. The Blower Shop's 250 blowers on stock hp500efi's
  136. what is the diff. merc III and merc IIIA SSM ?
  137. Char Lynn Hydraulic Helm
  138. Need a great rigger....
  139. Need Help on Sea Water Pump Rebuild
  140. Spark Plugs
  141. Crank mounted WaterPump bracket?
  142. Crank sprocket timing marks?
  143. Redline Oil
  144. Compreesion Test
  145. Exhaust Question, LONG, inputs please................
  146. Steel Tower for Bravo 1
  147. Pulse Drive
  148. Trs Stuff
  149. Loss of RPM
  150. Need Help To Id Block
  151. How often do you change your motor oil?
  152. whats faster
  153. XR Outdrives vs. XZ
  154. Stern lift w/ nosecone
  155. ProCharger Guys, quick question...
  156. Fuel Pressure Bleedoff
  157. Centrifugals and Screws, CompRatio vs. Boost and Detonation?????
  158. Prop mods for bow lift?
  159. Blowing Motors
  160. 502 Internals
  161. Synthetic Oil
  162. Help... I want to winterize myself
  163. Big decision
  164. Trim Sender
  165. Idle quality of blower motors
  166. Extention Boxes on a 42 Fountain?
  167. Hot Info!!- Globe Rubberworks Impellors
  168. HP500EFI Mods.
  169. EMI S.S. risers vs. alum.
  170. small block mods
  171. What oil in the cylinders for winter?
  172. Fellow Martini Owners
  173. Propshaft height and rotation on 30 cat???
  174. Tiller Arm Seal Help Needed
  175. Bennett Trim Tab Indicators ???
  176. We have hydraulic roller lifters
  177. 1994 Baja 260 towing question.
  178. Polishing stainless
  179. Cross-over kit
  180. Airflow Question TomCat ?
  181. 454mag Efi Short Runner Intake?
  182. Detonation - what is it, what causes it and what stops it?
  183. Mirage 21 Pitch Prop
  184. Gauges dieing
  185. Can't find a water leak - 402 Formula
  186. Good Prop shop
  187. 1300 ft. lbs torque turbo engines
  188. #6 drive question
  189. Water pump problem...
  190. Need 572 tall deck blocks
  191. Four Winns Liberator/OMC 502 EFI??
  192. Shortened Bravo Lower Testing and Upper Steel Tower
  193. Oil change set up ?
  194. Camshaft Timing?
  195. Cryo-treatment????
  196. hp confusion-cylinder heads
  197. Pressure Testing Imco exhaust manifold
  198. Hopp'in up my 330's -inexpensive route
  199. Cost of a refresh for hp500
  200. procharger questions
  201. Heavy Boat
  202. Angle milling heads
  203. Where can I get flush kit?I
  204. Uggh. I may have ruined my rebuilt motor with wrong OIL weight
  205. Relocating Drive Fill Bottles
  206. need a picture of a HP500 EFI circuit breaker\ignition relay bracket
  207. Exhaust
  208. Bravo rebiuld question
  209. Aftermarket Exhaust? Worth It? Product?
  210. need to know where to buy a 1/2" fuel pickup tube
  211. Crank Seal Color Code??
  212. SBC intake info needed...
  213. How do I get powdercoating off of EMI's
  214. Valve cover breathers and Vortec flame arrestors
  215. Superchiller or Whipple intercooler?
  216. Predator Carbs
  217. Eliminator garage scene
  218. Raw water pump, which fitting is the inlet?
  219. mercruiser trans
  220. 502 MPI Upgrade
  221. headers?
  222. help please dont understand what is being asked
  223. Camshafts explained?
  224. aluminum head recommendations
  225. Looking for sm. block manifolds
  226. moisture in storage???
  227. Fuel Tank pickups
  228. cam specs on an 87 350 mag
  229. Crower Cams?
  230. Steam in exhaust - Whippled 502
  231. Outdrive Oil?
  232. Winterizing problem and GRW impeller update...
  233. Valve cover breathers
  234. What pistons do you have or want?
  235. 22' Scarab deadrise?
  236. how many hp do you think is reaily-reaily causes no problem on a std bravo-1
  237. Header bending and assembly questions
  238. Swapping from a 502 to a 496 HO
  239. Winterize / storage question.
  240. How long will motor run with.....
  241. carb tuning for both speed and ski
  242. Looking for a Blackhawk Drive
  243. How many of you rebuilt your own bravo???
  244. TRS questions???
  245. twin turbos on a 510
  246. big m block stroke
  247. anybody using land&sea bravo extension kit?
  248. which outdrive to run??
  249. Hey ForrestC....
  250. have a first-gen 502 block.what max crank stroke can be used with this?
