PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. best place to purchase all my refresh parts
  2. procharger
  3. Best oil and sparkplugs?
  4. Hull Design???
  5. Would you change anything in this combo? 509 SC Carb
  6. Gaffrig Speedo
  7. Losing coolant above 3500 RPM
  8. Exhaust Blocking Plate question
  9. lightning headers
  10. What cam is this?!
  11. crankshaft .0025 from front to rear ?
  12. Do freeze plugs ever just pop out?
  13. 496HO & Water Pressure
  14. Fuel pressure system initial setting Qustion
  15. What heads for a Whipple project?
  16. cmi E tops
  17. 96' 502 E.F.I. L.H. rotation motor
  18. Active thunder or sonic or 28 sunsation, your pick
  19. Weber carb rebuild
  20. Verifying Fuel Preasure at the rail, needle bouncing all over the place!
  21. another trailer axle question
  22. Lifter Adjustment
  23. CMI Headers
  24. EMI thunders
  25. Carb Fitting
  26. Kieth Eckert Manifolds make more power than CMI Headers
  27. Merin 1-043 heads
  28. foot rest
  29. Yet another winterizing question
  30. emerald coast poker run 2006 video
  31. Alpha Drives???
  32. Need advice converting to thru-hull exhaust
  33. Raising Prop on Bravo 1
  34. Whipple stage 1 system for 496 mag!
  35. Intercooler strainers
  36. Pipe thread sealant?
  37. Bravo III Gear? & Merc 250 HP?
  38. Merc standard steering cable connection???
  39. Drilling a Bravo
  40. Alpha transom assy. vs bravo assy.
  41. Replace spindle on axle
  42. Arneson rocker?
  43. Rudder boat
  44. Engine Starts And Stalls After Sitting For 1 Hour
  45. Options other than Livorsi???
  46. 1988 Bravo 1 Drive
  47. Comp cams magnum lifters 887-16
  48. CRANES new shaft rockers
  49. Raylar BCK-103 Kit Installation
  50. Mercathode, Is it required?
  51. Thanks **** Tryce "Mr. Gadgets"
  52. Teague Custom Marine 1080 Quad Rotor
  53. Small block chevy marine performance book
  54. Any one need a Engine Drive package? 7.4/bravo
  55. Fuel Pressure Gauge??
  56. Tyler Crocket
  57. cmi headers
  58. roller rockers on a 330
  59. Best 1991 502Mag Refresh
  60. Best way to drain water out of my tanks
  61. Having some work done-$$ sound fair?
  62. 496 Mag Surge?
  63. where is garys 32
  64. 500 efi heads and cam
  65. Captains call install questions
  66. Reversing rotation B1
  67. best exhaust manifolds
  68. best way to pressure test exhaust
  69. In-Control Equipment Throtles
  70. Please help with flywheel ID
  71. Best brand of exhaust tips?
  72. My 330 on Roids - Final Results
  73. switching drive ratios
  74. Anybody using Pure Power oil filter ?
  75. How much HP to a rack steering system?
  76. IAC response time
  77. SSM#3 drive questions
  78. duo prop?
  79. switching from MEFI-1 to MEFI-3,4a,4b
  80. Mercury smartcraft vs. Livorsi Smartcraft Gauges?
  81. 575's..... 89 Octane?
  82. IMCO to BMAX conversion - question about Steering
  83. It's winter - ur bored - help me out
  84. Bravo compatibility
  85. aftermarket manifolds
  86. How to tell the difference in drives?
  87. 496HO adjustable timing chain/sprocket set
  88. Help!!!! Water in Trim tab Piston
  89. power steering hard at idle
  90. Remote oil cooler install....
  91. gil marine oil cooler
  92. Chad Hill - SS Upper Shaft(Bravo)
  93. Blower on HP 500
  94. 6.2 upgrades
  95. 496 az speed +marine engine upgrade kit?
  96. bbc heads for blowers
  97. EFI525 dyno data anybody?
  98. HP required to beat a cat with a Vee
  99. Baja 23 Outlaw Performance Data
  100. Theory: Blower or SC on heavy boats?
  101. Transom leak, exhaust block off plate?
  102. swap and sell
  103. 420 Mega Blower Rebuild
  104. Finish my 509
  105. Value of Boat??
  106. Odd Dyno results
  107. Auto engin question.
  108. CMI E-tops on a 500 EFI
  109. What Hydraulic Roller Lifters to Run in A Dart Block?
  110. Volvo Penta 496 or not??????
  111. Fuel Pressure Regulator
  112. lab finish Bravo 1 or Mirage plus for top end
  113. Rear Seal Replacement without removing crank?
  114. bmax
  115. I can never win!!
  116. Stellings drive shaft cushion
  117. CMI 496 Sport Tube Install
  118. check my engine builders cam choice
  119. Theory ... water flow
  120. computer help
  121. cam drive water pumps
  122. Bravo 3 Xr
  123. Merc 6
  124. Switchin corsa quick and quiet to captains call
  125. Trim Tab Indicator Install
  126. thoughts and opinions pantera or sunsation
  127. T sat housing
  128. Pre Lubers
  129. used 500efi vs 502/496 & upgrade now
  130. Cam timing
  131. Volvo DPX drives, Yes or no??
  132. Boat sales tax
  133. steering cable
  134. Enough batteries???
  135. SCE Titan Copper headgaskets ?
  136. 500 hp specs
  137. Flame Arrestor Labeling
  138. What cam ?
  139. Which exhaust flange gasket?
  140. Fuel Pump Advice Needed:
  141. Cam specs for 650cid Donovan?
  142. Dash Harness
  143. supercharging 454 mag
  144. Water Reversion
  145. 500hp carb to 525 EFI??
  146. 38 Fever Drive Set-up
  147. salt water and my new trailer
  148. New 731 Roller or get a Custom Grind?
  149. tall decks
  150. 500 Efi Whipple 2.3
  151. Cockpit Flooring?
  152. Muffler removal = H.P. gain??
  153. It's Cam Time!
  154. 454 / Alpha FWC retrofit
  155. T-Stat Housings
  156. Who Makes The Better Cam
  157. Where to run Water pressure line on 496HO
  158. Melting Intercoolers
  159. 454 mains bolt torque
  160. Bravo Alignment Tool
  161. When to Freshen Up 525's
  162. Need powdercoating info
  163. Optimum air / fuel ratio for marine engine
  164. Bravo I to XR
  165. trim come back here !!!
  166. EMI or lightning headers?
  167. EMI or thunder marine headers?
  168. Comments on Scaarb 33 AVS
  169. 500 hp refresh and build up
  170. Help with new boat choice, ?? Scaarb, Top Gun????
  171. Mass Flo efi system
  172. Valve spring install help.
  173. ?? on steppedhull vs non stepper
  174. Motion 30 /Spectre 30
  175. connecting rods
  176. Gaffrig Guages
  177. sEA WATER PUMP DRIVEN FUEL PUMP
  178. Distributor Gear
  179. hydraulic steering too slow
  180. Main Bearing high performance or standard
  181. Rinda Diacom and Innovate LM-1 Survey
  182. Need Vinyl Decal Replacement
  183. 496 base with HO computer
  184. How hard to install a Retro Roller Cam?
  185. Scratched Headers- What can be done?
  186. two stage water pump
  187. Speed Limits on ICW
  188. 540 to 572 How much Boost?
  189. Need SHADOW CAT help (T2X)
  190. What Blower belt for a BBC, 8/71, w/intercooler
  191. check this out, tell me what you think?
  192. engine block I.D help
  193. Ron Potter ?
  194. compairing out drives
  195. need decals for my opti
  196. Hone finish question
  197. #3 speedmaster question
  198. new raw water impeller..now difficulty priming
  199. Sea pump pressure
  200. Timing 454 Mag MPI
  201. steering hub?
  202. Looking for performance exhaust/headers..source?
  203. Cobra 357 Sea Viper
  204. Overboard dumps
  205. Best price for 496 ho
  206. power steering
  207. Measurement Needed
  208. Blower Cam Advice and Help!
  209. Cam choice help
  210. Dumb question about steering
  211. Where NOT to buy marine parts.
  212. 502 Dimensions
  213. Flame Arrestors???
  214. Shrader valve size?
  215. Char-Lynn Kits
  216. Washer sequence for Ziegler Hydraulic Steering
  217. Donovan Aluminum block
  218. Water pump question
  219. I Found Out I Am Having A Boy
  220. Coupler ?
  221. Marry Christmas from New Zealand Guys
  222. 496/cmi/coarsa/whipples
  223. Bravo/Blackhawk parts interchangeability
  224. 26' Ex-Race Boat - anyone recoginize
  225. Procharger Rolloff Hesitation and Fuel PSI
  226. Gen 6 guys...roller lifters
  227. BlackHawk, good or bad??
  228. Max timing for 496
  229. Thermal barrier coatings
  230. Trim Tab rams Needed
  231. HP losses from Bravo 1X drive
  232. Engine block temp
  233. Arneson Rocker Plates???
  234. 525 MAP Sensors
  235. 496 H.O. Buildup
  236. Huge problem with 5200
  237. Slip ?
  238. Trailer Plug Wiring Colours-help Please
  239. Got the BMAX's mounted
  240. How Much !!!!
  241. 29 Scarab Question
  242. 500hp to 525's swap
  243. Merc 496 GURU Question
  244. #6 SSM Tool Set
  245. Looking for a used Bravo Gimbal Housing
  246. Fuel rail question
  247. Gimble ring rebuild
  248. Black Thunder
  249. Guess at HP gains from HP500 carb/intake package
  250. good battery location???
