PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. round port or square
  2. FiTECH Fuel Injection Systems
  3. Old school throttles. HELP Please
  4. 548 compression ratio ?
  5. Engine surges when warm
  6. T-stat/ thermostat housing bypass
  7. Prop help, please
  8. Tach problems
  9. Another reversion thread.
  10. 454 mag mpi timing
  11. black smoke and dies when the secondaries open
  12. Anyone from Lake Texoma?
  13. 4150 to 4500 adapter
  14. replacing cap and rotor - ignition module ?
  15. Delco Voyager for 454 with a B&M 250?
  16. Drive shower length and cavitation.
  17. gen 6 head gasket
  18. Jabsco Pump Parts?
  19. Procharged 555 dyno results...
  20. engine gurus little help please
  21. Kiekahaefer aeromarine controls
  22. Disturbing findings flowing and testing injectors
  23. Senders
  24. Question on cams
  25. Pioneer head unit
  26. mercuiser 383 stroker header assembly any one used them?
  27. Anodes. What material do I need for freshwater ??
  28. Need 525SC clone advise
  29. 500 Bulldog rev limiter
  30. Exhaust manifolds & risers
  31. What's the original application for this filtet mount/ thermostat?
  32. Help!!!!! 280 Silencer
  33. Prop size for a 1988 baja sport 226
  34. E85 With Flex Fuel Sensor Who Is Running It?
  35. Analog Test Tach Connection On 525EFI?
  36. PCM555 ECU memory error message
  37. 1989 SeaRay Pachanga
  38. 454 compression test question
  39. 572 e85 and tbs 250 blowers
  40. Primary header tube size ?
  41. Cmi etop clearance amount???
  42. What oil you guys runnin in your blowers enines
  43. Total Weight
  44. bigger oil filter for 6.2l Merc engines
  45. Nose Cone/B1 vs Hydromotive!!??
  46. What does a 2003 6.2 Mefi Computer log?
  47. kaama boots
  48. #6 Service/Rebuild Manual
  49. Vortech V4 Supercharger set-up on a GenXI 502
  50. Help: issue with GIL manifolds hitting back of Alt - Gen 4 454
  51. 29' fountain what prop to run?
  52. How much horsepower do I have??
  53. contradicting engine specs on spark arrestors
  54. 22 scarab help
  55. Piston Selection Help! Gen VI 454
  56. Is garden hose water flow enough?
  57. Bypass in oil filter.
  58. Gas ported Pistons
  59. Excessive steam from starboard side exhaust.
  60. Mercruiser 454 riser gasket question
  61. Keep Blowing Ignition Circuit Breaker/Fuse
  62. Ilmor MV8 570
  63. Daytona crashbox change out
  64. Intake Runner volumes
  65. Problems
  66. Cmi tail issue?
  67. Where to buy gen 6 7.4L long block
  68. Kiekhafer kplane cable ends
  69. Rod bearings after 9 years
  70. TRS Gimbal Ring Question
  71. K1 tech vs molnar
  72. Mounting external steering cylinders
  73. Window Hatch 2006 Baja 35 Outlaw
  74. ITS steering cyl leak
  75. Vertglas
  76. Anybody doing remanufactured big blocks (specifically 454 Mag efi)?
  77. Bbc starter and alternater wires
  78. Merctrans shift linkage and selonoid???
  79. Water pressure too high
  80. Running "warm"
  81. What can I use?
  82. TRS - Merctrans mount bolt size?
  83. Steering wheel adapter
  84. Teagues take on 650hp
  85. Stained white gel coat
  86. Stud Girdle
  87. Merc 496 Throttle Body Cleaning
  88. Caterpillar Engine Tech
  89. 525sc carb rebuild anybody got a part number ??
  90. 350 MAG MPI swap to 383 Stroker Help
  91. cam gear oiling
  92. F.A.S.T. "Classic" grey box settings...
  93. Help cam timing chain cover- 5.7 350 mercruiser chev
  94. Spark plugs for Dart 308s
  95. will siemans deka short style injector fit mpi 502?
  96. 2nd Gen OMC King to Bravo Swap, WHEN???
  97. Rebuilding a MSD Marine Distributor to use as a Cam Position Sensor.
  98. 525EFI difference in oil pumps
  99. New to me blowers... Trying to guess hp
  100. IMCO extension box hydraulic steering question
  101. BBC side by side spacing?
  102. Put in O2 bungs, but exhaust too wet for the sensors?
  103. Buying a boat and need some advice!
  104. Looking for some opinions on my 454 rebuild & cam that was used.
  105. Power steering unit allows input cable movment.
  106. Ignition Alarm
  107. Map sensor 502 Mag MPI
  108. low boost roots supercharger on 10.25-1 ls5 bbc?
  109. What's my 29 Baja Outlaw worth?
  110. Merc K Plane plastic sleeve around the hinge pin
  111. 1998 7.4 MPI Stalls While Running on Step
  112. RPM to prop for vs dyno chart.
  113. msd 6 off road box on marine motors
  114. power steering issue?
  115. Rant on Dealer and much needed tranny help
  116. Warning alarm help
  117. Micro trim switch??
  118. what years were Gen 1 and 2 EFI's made
  119. Steering slop but not to gimble or pin
  120. 632ci Build Specs
  121. Fuel injector cleaning, I did
  122. Sunsation Dominator hatch actuator
  123. JL Audio any dealers on here ??
  124. Flywheel runout - Do I need to check this?
  125. 525 Headers, NON CMI?
  126. Marine Machine Hydraulic Steering
  127. 9.8 deck 598?
  128. K&n filter 502mpi 1996
  129. Drilling straight holes
  130. Hyd steering filter
  131. 7.4l MPI not reaching full power (MEFI 3 MCM)
  132. 575 Fuel injection solution
  133. What are these amps
  134. 350 N/A Recipes
  135. Fuel Lines?
  136. Galvanic corrosion of aluminum cylinder heads.
  137. installing prop on #6 drive
  138. Headers vs. SM manifold/long riser
  139. what is "the rail system" engine mounts
  140. Another condenstion/ reversion problem
  141. Baja 302 Bilge Pump Replacement
  142. EFI airflow..
  143. Dry Exhaust Question
  144. Port fuel guage pegs full
  145. Bravo shift cable uncoupled
  146. Lifters
  147. Who to go to for new steering hoses?
  148. Batteries
  149. Switching fuel injected for more hp stupid move?
  150. Dominator preference
  151. Spark plugs
  152. Engine Quest Head work results
  153. 31' Scarab Excel, props in or out?
  154. 1988 320 EFI injectors?
  155. Camshaft Selection/Engine Setup
  156. Backup ignition wiring?
  157. Where can I find neutral micro switch?
  158. 502 MAG Idle Problem
  159. Prop Hardware
  160. No beep when trying to start ??? Won't start
  161. whats everyone doing for depth finder?
  162. Plug wires.
  163. Diacom software, PCM-555, whipple stage 1 tune
  164. Piston/Ring Part Number
  165. Engine won't shut off!
  166. Bravo 1 shifts hard into reverse?
  167. Baker / CV / Hardin marine fuel pump ?
  168. Need to lower by 2 decibels ?????
  169. Lenco Dual Ram High Performance tabs, all comments eagerly read
  170. Cam Specs and reversion
  171. Spring maintenance
  172. Aluminum swim platform design
  173. Drilling holes in transom
  174. Dist cap question
  175. Higher octane fuel in our future?
  176. looking for these, Anyone Know where?
  177. AeroTek Marine--- I know... I am sorry
  178. cam ID
  179. Garmin GFS 10 restriction?
  180. Trim Switch Diagram
  181. Supercharged v NA
  182. desk top dyno 5
  183. Pushrod Suggestions
  184. 29' fountain carpet
  185. flywheel and balancer?
  186. K&E 2 pc valve covers leaking all the time
  187. Stellings headers. Orange vs green
  188. Imco Powerflow
  189. Aeromotive Fuel Regulator
  190. Head & cam upgrade for 454mag MPI
  191. 377 Scorpions
  192. Valve cover breathers Push in/Stack type???
  193. Prop slip
  194. RPM Rev Limiter?
  195. Engines get excited and idle high
  196. Folding cleats
  197. Where to buy 350 shortblock?
  198. 525 header Y pipe reduction
  199. mercruiser 502
  200. Power Steering Fittings/Hose Question
  201. 489 build critique
  202. Trim Ram drift while outdrive is removed
  203. Running Surface Mushroom Thru-hull.
  204. Cost to paint hull sides
  205. Gil exhaust cracking location
  206. Reliability and how you define it
  207. What about iridium plugs in a 502 Mag MPI ?????????
  208. Self cleaning parts warsher Made by SYSTEMS ONE
  209. Setup for both in the boat and on the dyno.
  210. Help! Need a new horn
  211. HaxbySpeed
  212. What exactly is the helm unit (with ext steering)
  213. Need advise and Propellers for Arneson ASD 8 25 spline
  214. are these made any more?
  215. 9.6 compression and boost
  216. Where can I get forum help
  217. Mercury universal engine mount system
  218. 496 mag engine coupler
  219. eagle rotating assembly
  220. air diverter ram leaking air
  221. IMCO or Sportmaster on Straight V
  222. Trs drive pump question
  223. Problem with new BDS 871 blower rotor issue
  224. oil leak Blues
  225. Hyd streeing inside hose
  226. Isotta Carlotta Steering Wheel
  227. Nose cone removal
  228. exhaust boor
  229. looking to rent condo or apartment in downtown chicago wrigly area
  230. milodon oil pan question
  231. What is a "Flat Plane" crankshaft?
  232. Off the shelf cam options for marine engines
  233. Cig on board charger
  234. Looking for some dark red marine carpeting
  235. EFI fuel injection intake manifold with front mounted throttle body.
  236. Interior lights
  237. Bravo 1 steering slop
  238. Starting in gear?
  239. 42 stagger conversion performance???? x dimension???
  240. VST or Aeromotive?
  241. whipple oil change
  242. Long road trip to FL tips needed
  243. 800sc
  244. Mayfair external steering kit
  245. Head Gasket P/N for 088 on Gen VI
  246. Switchable Tips
  247. 78 Python 24ft value?
  248. HP 500 rebuild cam question
  249. Drive Lube Reservoir Fitting at transom breakage
  250. 2004 350 MAG MPI cam, ecm upgrade?
