PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Intake air temperatures with blowers.
  2. Thermostats in a blown application?
  3. procharger innercooler problems
  4. Off the shelf Cam- Dyno results
  5. Will Ported 308 Dart Iron Eagles work on a 565CI or even 582Ci motor?
  6. Testing fuel tank
  7. Will Ported 308 Iron Eagle Dart heads work on a 565?
  8. Bravo x to Bravo XR exchange?
  9. Help with trim tab installation (correct angle)
  10. Need prop selection HELP 99 Python.
  11. mercruiser power steering issue bravo
  12. Identifying a cam
  13. Electrical help!
  14. Bleeding Air from my hydraulic steering
  15. TPS Voltage for idle on a 525 efi?
  16. Sierra oilpan?
  17. Let's talk ignition
  18. new to owning a boat got a boat that needs love coming
  19. NA 555 build CR
  20. 496 starter bolts?
  21. clearence issues with 20.5 sport skier 496 need help
  22. Trim tab angle question (how high is high enough?)
  23. Water pressure issues!
  24. Boat stalls out around 3000 Rpm
  25. HELP! 87 wellcraft nova wiring schematic needed
  26. sierra extreme lower shift cable - know issues? mine broke
  27. Trim solenoid question????
  28. Jesel Belt Drive, Crank turns Cam and Belt Stationary
  29. 502 Dead Stalls above 2400 RPM - Need Help!
  30. Jesel cam belt drive in a marine/endurance application.
  31. 2005 525 starting issue
  32. Strange drive noise
  33. Holley 800 DP running rich at idle - causes?
  34. Which one?
  35. Proper cam choice. What does it mean?
  36. Spark plug gap confusion, 502MPI
  37. 575SCi
  38. Has anyone used Ethanol Shield?
  39. Add on steering issue. Please help!
  40. Have I been Hoodwinked?
  41. Need Help with Location of Thermostats in 500 EFI
  42. Lazy RPM on 396 stroker chevy
  43. carpet
  44. Trim pump fluid?
  45. looking for piece that goes on back of m3 procharger
  46. 496 ho surging/rough idle
  47. need mechanic, cape canaveral area
  48. 1997 2.5 260 EFI idle and start issues
  49. Filling gear lube reservoir
  50. Brand new quick fuel carbs engines won't run
  51. Need help identifying a motor - 572 or 454?
  52. clear (dry or glazed) plug fouling??? Stumped....
  53. Steering cable and helm upgrade, has anyone used the HPS or EXTREME (seestar teleflex
  54. What are symtoms of power steering pump going and/or not working well??
  55. Mysterious oil leak. Gen VI 502 crate motor
  56. West Coast Offshore - Anyone know anything about them?
  57. Any speedo tube fixes
  58. Bravo Rattle - Alignment Woes
  59. 502 injectors
  60. Stainless marine Water pressure test pressure?! Help!!'
  61. Installing a dual relay assembly to speed up my actuator (confused on switch wiring)
  62. 500 efi noise re-visited
  63. Is there a special alignment tool for this coupler?
  64. Working on solving water pressure problem
  65. Ignition issues 420 merc
  66. How do you stop reversion?
  67. 3k RPM+ Bogging Issue '96 7.4LX MPI
  68. Stanless Steel Welding- in Northern Indiana
  69. 2007 Suzuki DF250 milkshake
  70. Comp Cams - Issues with rocker arms, premature failure.
  71. smoking gun clear youre messages
  72. Question on aftermarket exhaust and risers
  73. 525 upgrade question
  74. Exhaust water flow question?
  75. water pressure problem
  76. any jet ski tech's here
  77. sunpad hinge
  78. 496 manifolds on a carbed 454
  79. New Gen 7 540 forged shortblock offering!
  80. Drones in Zaks bay NY
  81. NGK 5673-7 or -8?
  82. 496 HO coolant?
  83. O2 sensors dead after short use???
  84. Dual helm steering problems
  85. Fuel presure on 496 ho
  86. Drive wouldnt lower or raise
  87. Aeromotive Fuel Pump - Losing pressure
  88. Performance problems
  89. 496 HO won't run above 4100 rpm
  90. Need Starter Advise gm572
  91. 500 efi will not rev beyond 4300 rpm
  92. 575sci running rough
  93. Another 496 alarm thread!!!!!
  94. Whipped charger
  95. Marine grade wiring?
  96. taking mild thunders advice
  97. rotella oil
  98. water pressure too high
  99. 496 Mag HO WInterization Questions
  100. Alarm wont stop sounding ? Any ideas why ?
  101. What are my cam specs?
  102. Another Reversion issue with Gil Risers
  103. Convert 496 H.O. Mercruiser to MAG
  104. 500EFI starts to fall flat after 2500rpm -Anybody?
  105. Oil change with oil cooler under motor
  106. $200 Mechanical survey saved me 15k!
  107. 496 fuel injector problem
  108. shift cable end
  109. Help with Corsa Exhausf Baffles!
  110. New hydraulic steering install hooking up rams
  111. Bleeding hydraulic steering
  112. 383 Small block with EMI Thunder and +3" stainless risers, Cooling water flow
  113. New Hydraulic Steering Install - No Pressure and Other Rigging Questions
  114. 525EFI question
  115. Hydraulic steering return line
  116. First time poster with possible spun hub
  117. What are these?
  118. Filling Outdrive with Gear Oil using pressure?
  119. DUI Timing adjustment help..... and MSD parts interchangeable?
  120. A couple 575 sci questions
  121. Carb size
  122. is this a good cam/set up for my 454?
  123. Crane 741 in a 500 efi
  124. Camshaft
  125. engines guys chine in please
  126. Gaffrig GPS Speedometer
  127. Smart Guys - how about a 500HP budget recipe?
  128. 496 Mag Heat Exchanger
  129. Kodiak big block exhaust manifolds any good?
  130. Hydraulic steering set up..
  131. IMCO Fuel Valve/Tank Selector Problems
  132. exhaust elbow tube extensions - slash cut questions
  133. Will this boat have water reversion issues?
  134. Best source for SS Rub Rail?
  135. Performance distributors Ignition timing
  136. zero effort control parts
  137. Holley EFI - global file for 598
  138. Newbie needs advice on which boat
  139. 575sci refresh
  140. Holley EFI in a boat - Doesn't Repeat
  141. 88 Baja stalls at high rpm
  142. 454 Magnum cooling issue
  143. Stbrd Motor will not crank over!
  144. some 4150/4500 dyno info
  145. would you notice 100 more ft.lb. torque
  146. Hydraulic steering Opinions and advice
  147. 500 EFI limitations?
  148. Bravo U-Joints - Older Drive
  149. Water pressure bypass
  150. 496 issue - loss of power to fuel pump?
  151. TRS anodes
  152. BBC 555 dart vs rpm intake
  153. Question for MegaSquirt users
  154. Spark plug wires
  155. 496 ho intermittent stalling above idle
  156. Need help - What head gasket for Chevy 350 bored .40 over.
  157. Easy buddies on the drive - what grease
  158. Mercruiser Aluminum 496 manifolds with out water rail worth $450?
  159. Hatch Actuator Issue
  160. Thunderbolt IV ignition problem
  161. One riser hotter topic
  162. Leaking Gil Sea Strainers
  163. Is there any fairly easy upgrades I can do to a 454 efi 385hp magnum?
  164. Who makes cast iron oval port after market heads?
  165. Livorsi Trim Question: Goes down, trailer needed for up
  166. 500 efi rebuild?
  167. 2011 verado 300 help, vibration when in drive
  168. Pertronix ignitor III ignition opinions
  169. Best Price on sbc GLM aluminum manifolds and risers
  170. Refreshed and are now ready to install
  171. 496HO Fuel Filters
  172. 500EFI Dies after 30 seconds to 3 minutes
  173. Can Oil Pressure Gauge be used as Fuel pressure Gauge?
  174. Speaker boxes
  175. MEFI 1 350 issues
  176. kiekhaefer throttle rebuild.
  177. Cherokee Power Boats (26' "Dylan")- Anyone know anything?
  178. Hydraulic Steering Fittings
  179. Will 496 mag DTS-box work with ordinary wire gas-trottle?
  180. BBC - Blue Print Blocks
  181. What are people using for under platform swim ladders?
  182. 496 ho won't start
  183. Help, mercruiser wont rev
  184. whats the best way to trim both drives with one switch?
  185. Drive trim
  186. 1 1/4 ID hose
  187. msd?
  188. Replace two handle Gaffrig control with single handle?
  189. Boat sunk, salvage
  190. EFI question - non boating
  191. What engine needs 6,000,000cfm to operate?
  192. 0-35psi or 0-60psi water pressure gauge?
  193. Fresh Water Cooling plumbing with Stainless Marine Exhaust
  194. Where can I find odd ball SS studs?
  195. Where to mount water pressure sensor on 496?
  196. Oil pressure gauge not working
  197. amazing the things you catch when you surf craigslist too much
  198. Questions about coupler/motor mounts/alignment
  199. 95 454 EFI horsepower
  200. Gauge Pressure Style Help
  201. Superchiller water flow testing
  202. Can you rebuild a HP500 power steering pump
  203. Boat cover north jersey?
  204. 88 four winns liberator bogs under throttle
  205. Internal Flappers
  206. ISO rubber feet for Fountain bench seat
  207. 500 efi vapor lock
  208. Contemplating buying formula sr1 311 as first larger performance boat.
  209. Gil Question
  210. Anybody running a LS engine with cast manifolds- need to know engine width
  211. Mercury hour logging
  212. High performance piston rings
  213. X dimension and props
  214. Replacing Impeller - Just the impeller or entire assembly?
  215. 500EFI cam, what valve springs
  216. 35 Fountain with rotten transom.
  217. 500 EFI fuel pump - intermittent problem
  218. 500 EFI valve spring replacement
  219. Mounting an Aluminum Swim Platform
  220. Merc 496HO Fuel Pump GPH?
  221. Lift install
  222. Merctrans drain plug size
  223. Engine oil dipstick options
  224. How far? Exhaust from flapper!
  225. Where to buy parts in Atlanta GA???
  226. Motor Mount Options
  227. Lower shift cable tool 91-17262
  228. K plane hose end size question
  229. port a potty / pump out conversion?
  230. QV4C Valve Lash
  231. Difference in engine voltage while running
  232. 177 blower bearing.
  233. Backfire through carb
  234. 502 MPI-- no power to cool fuel pump!!
  235. AFR Gauge question
  236. Any generac techs here ?
  237. J- bolt clamp
  238. Irridium plugs for a 502 MPI motor???????
  239. Rocker roller coversion for 502 - push rod length? - need valve train expert
  240. Need $10k in mercury parts- looking for best deal
  241. Vorec 350 rings
  242. Jetting help
  243. Valve springs, valves and push rods
  244. Fighting Reversion - We've been doing it all wrong
  245. Steel or AL flywheel, and HP coupler
  246. Stainless Marine/ Wet to Dry conversion
  247. Cross over with low temp has t stat and bypass
  248. Thunderbolt IV Problem
  249. round port or square
  250. FiTECH Fuel Injection Systems
