PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52] 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. electrical issues finding a wiring diagram??
  2. Expected HP increase?
  3. Blown 516....finally getting close!
  4. 454 break in
  5. Anchor question
  6. New Prop starting point
  7. thoughts on a 4.5 crank in a gen vi 454
  8. 1996 502EFI piston
  9. 496 manifolds
  10. stroked 454 to 496 or go 540
  11. 500hp / 502 Mag Heads
  12. Starter or Ring Gear headache?!!!
  13. Merc K-Plane 280 Cylider question
  14. Props in Vs out and shifter ????
  15. WOT RPM, custom engines
  16. Couple Electrical questions
  17. 454 Engines been sitting
  18. Ignition Question
  19. Perma-Lubed Gimbal Bearings?
  20. amsoil (which one to use please)
  21. EGT sensor / CMI headers Question
  22. Canine Lifejackets...?
  23. 496 iac!!!
  24. Another engine oil thread, this time about JD diesel oil for marine app.
  25. VDO Vanguard Gages
  26. Twin engine power steering
  27. Chasing a ghost... Gaffrig gauge question
  28. Swap Shop Abuse..???
  29. Are these old gil's any good?
  30. swapping 380 kplane on 280 mounts?? mods?
  31. cam pro's needed
  32. CFM rating for Merc HP500 Carbs ?
  33. Jet help
  34. Removing 25zx interior
  35. Recomended firewall insulation
  36. camshaft suggestion
  37. Freeze plugs on gil manifolds
  38. Question about 575 SC blowers?
  39. 496HO Freeze Frame... who can read this?
  40. Changing jets in demon carb
  41. Braided stainless breather lines
  42. Picked Up my order from the Powder Coaters Today!
  43. 575sci water pressue gauge mounting...
  44. looking for 500hp efi cams and pushrods in good cond.
  45. Exhaust tips questions.
  46. Merc 330 real hp?
  47. New boat speed questions
  48. 500 hp efi cam in a 454 mag ?
  49. Need help w/ some part #'s!!
  50. NEMA 1083 or 2000 ??
  51. 575sci rear oil draining....Great idea or Stupid idea ??
  52. Opinions on Conventional 20-50
  53. Differences between Mobil 1 15W-50 and V-Twin 20W-50
  54. temp sender questions
  55. 575sci Fuel Pump ? - Upgrading to KE Fuel Pump
  56. 496 manifolds
  57. Electrolosis question (s)
  58. Speakers - Mounting to Engine Hatch. Help!
  59. how bad is this....
  60. Pressure testing etop lights(no tailpipe headers)
  61. Which wire is NMEA on Garmin?
  62. chris craft scorpion won't come up on plane...any ideas?
  63. replacing 2 stick quicksilver contols w keikaffer
  64. jetting quadrajet for new exhaust
  65. What engine do i have?
  66. Feed Back on GLM Aluminum Exhaust for SBC
  67. Sierra Marine Parts
  68. New boat to me what oil and drive oil to use??
  69. Full Hydraulic Steering or Not
  70. High oil Temps
  71. fuel pump for 10/71
  72. "Cigarette" and "Top Gun" script logo
  73. Closed cooling systems
  74. Motor mounts - baja
  75. give us a call with you question and we probably have the part you need.
  76. Anybody deal with Boostpower ?
  77. what blowers to use on stock 330hp?
  78. how to remove hydrolic assist steering
  79. SBC Exhaust
  80. Best pair of outboards
  81. 700 Hp fuel system????
  82. Swivel Pin measurement
  83. 1250 dominator
  84. Brodix head
  85. B&M 250 blower question
  86. Does your bolsters stick up above the gunwale of your boat
  87. marine machine steering parts
  88. Speed with 420 hp Mercruser
  89. Synthetic or Reg. Oil shelf life
  90. Gen VI oil filter bypass valve and block mounted oil cooler valve
  91. Idle Cruisin' with Bravos
  92. HP 500 (Carb) Air Filter?
  93. 496 Mag Serpentine Belt debris
  94. which bravo drive coupler?
  95. Rolling boat cradle...
  96. 496 Exhaust Change - From Dana to CMI
  97. Engine Wire Harness Connector?
  98. Mirage plus vs. Enertia prop
  99. mechanical oil pressure gauge
  100. Temp/Humidity/RPM Rule of Thumb?
  101. Imco Thumper - Opinions???
  102. cooling crossover
  103. 10 year old merc 575sci engines with zero run time, concerns?
  104. 6.2 Rod size
  105. Supercharging question
  106. 509 with M1 Procharger MPI questions
  107. 496HO Advice Needed
  108. motor / HP Identification
  109. 496 mag running issues
  110. Donzi classic volvo outdrive - shortie/holman
  111. Leaking Polylift
  112. Hawkeye in hull Depth transducer advice
  113. Jetting for Holley 750?
  114. pq 290 bimini
  115. Trophy engine change
  116. EFI INJECTOR CHANGE Question
  117. mercury marine alternator wiring
  118. Installing O2 bung in Hi-tek Jacketed Manifolds
  119. Classic speedo's
  120. DPX Installation
  121. Stiff Latham Throttles....
  122. Camshaft Identification help
  123. engine water pressure test
  124. WANTED---Blackstone lube analysis from Bravo drives
  125. Through hull mystery parts
  126. Triple 575 's , XR's & CMI's
  127. Trade Mercury 900 SC's Plus ?$$ For Merc 1075s?
  128. Mark V heads
  129. Formula 292 with Gils
  130. Octane requirements for HP500?
  131. 502 Piston History
  132. For All The Guys Wanting to Build Their Small Block..
  133. Intake screen for 575sci blower?
  134. Safe Guards to avoid reversion/ingestion
  135. Safe Guards to avoid reversion
  136. Help 496 Valve problem
  137. junk in the oil filter????
  138. 3 blade maraige vs 4 blade bravo
  139. Small block & lifters
  140. seven marine efi controller
  141. sunken 38 top gun
  142. Top Speed
  143. Ethanol
  144. 8100 cam swap
  145. Anyone know what these are
  146. bellhousing and coupler
  147. Hawk 525sc ???'s
  148. Hawk 525sc ???'s
  149. 540 Issues
  150. Best Anchor in Lake Michigan, Box Anchor or Fortress for 34ft boat
  151. Dart Big M Head Gasket
  152. Anybody have info on D-TRONIC 7.3 merc diesels?
  153. which stock style exhaust flows best?
  154. Crankcase Cooler - Is there such a thing out there?
  155. Is my boat to loud for Havasu?
  156. OSO party question for tonight
  157. 6.2 383 cranksaft
  158. update on neo oil
  159. Another inconel valve question...
  160. stalling issue
  161. Trans Temp warning
  162. Customizing Transmissions
  163. What should I expect going from 088 to Merlins
  164. Semi-stagger vrs. Full Stagger
  165. 454 to 496 upgrades
  166. MSD bolt on efi system
  167. Any plumbers with nat. gas regulator sizing experience on board?
  168. Dana Monster tab MT-4800
  169. Teague Switchable muffler question
  170. Drive Gear Ratio
  171. How to change Crank Position Sensor?
  172. Best way to fill a 3 3/8" gauge hole??
  173. Exhaust Change fitment questions
  174. do these subs need to be out of phase
  175. Hawk 383 Motors
  176. Gen 6 timing pointer?
  177. mercruiser 5.7L oil pan question? (1 piece rear main)
  178. helm
  179. Ilmor Engines...
  180. does anyone know the grade of stud for latham wingplate studs?
  181. Tachometer Wiring Q
  182. cam specs
  183. 575sc clone
  184. Cam Specs on a standard 502 GM Marine engine?
  185. stainless marine exhaust
  186. seastrainer mounting location?
  187. Need help deciding my exhaust, and finding the best prices
  188. Callenger super v information?
  189. Engine oil coolers
  190. new fuel cell dosen't sit all the way
  191. hard lines for k planes?
  192. computer problem
  193. fel pro mls or cometic...need part #'s please
  194. GLM alum small block exhaust
  195. 525 efi
  196. procharger or whipple?
  197. Will Hynautic H50 series seal kit work in Hynautic H51 Helm?
  198. Crossover/ T-Stat Question....
  199. Water/Methanol injection
  200. changing exhaust
  201. bravo nose cone good or bad
  202. adding captians call
  203. waterpump or watercross over
  204. bbc magnum intake manifold question
  205. plywood for bolsters
  206. Anyone ever use kirker black diamond paint?
  207. Cam question
  208. Do arp head studs clear or hit Stainless Marine exhaust manifolds?
  209. Eddie Marine Tab indicators..
  210. headliner material???
  211. 350 or 383,,, the question.
  212. 496 Raw Water Pump Rebuild
  213. best place to buy oil?
  214. 525 header issues?
  215. gear lube
  216. Boat cam for ls motor
  217. Technical opinion on Procharging my 01' Baja H2X
  218. best place to buy CMI tail pipes
  219. 502 Engine help
  220. Cool marinas to visit in New Orleans
  221. Latham Steering Help
  222. dui distributors
  223. edelbrock alum head opinion
  224. tinned wire
  225. Oil pressure sender
  226. Nova III steering problem.
  227. old style k plane indicator mouniting
  228. tubular risers stock merc manifolds?
  229. Bravo 1 or Speedmaster A
  230. Lathem p/s press. hose replacement?
  231. Marinas and boat shops in new orleans area
  232. Fuel additive
  233. steering clearance
  234. Gen6 509 build, hyd roller, 764hp, 732tq.
  235. howards cams
  236. Whipple throttle body???
  237. 2 circuit to 3 circuit Dominators?
  238. Reducing prop slip
  239. power steering/ hydro
  240. offshore motor plate setup ?????
  241. need to find studs and spacers for latham wing plate to bravo drive
  242. redoing the interior...
  243. Ignition Box Issues and ?????s
  244. reliablity
  245. Looking for Side Mount Whipple Information
  246. Cold air intake
  247. Built in ice box, where to buy?
  248. Fuel Tank Leak
  249. 525 efi fuel pressure question
  250. Camshaft number, what is it?
