View Full Version : General Q & A
- Tabs leaking water in bilge
- want more mph!! fountain 27-baja
- Can I remove Port power steering pump and hoses???
- Suggestions for plugging y pipe after thru-hull conversion?
- Dumb General Engine Question!
- Knocking Noise from Borg Warner??
- GPS max speed ??
- Question about alternators
- 496 HO neutral and reverse question
- mushroom around SS Exhaus and transom
- Metal tube style swim platforms
- Boat Transport from GA to Pittsburgh PA
- Trim Pump Solenoids
- Is 80 psi okay
- 525 SC Carb Flooding
- 496 oil in coolant
- 2 more questions on the 500
- Help Please~bravo / Engine Alignment
- anyone have a Merc trim wiring schematic
- Risers on an HP 500
- will a #5 lower bolt to a ssm#3a upper?
- Water pump failed or cloged??
- Merc power steering fluid leaking - Help!!
- Prop problem
- 7.4 310 H.P supercharged ?
- Broke my drive!!!
- How to identify 3A from 3 drive
- 99 2500 suburban hard starting, 454
- emergency engine hatch access?
- black soot back boat
- small blisters
- Delco Oil filter PH1218
- Throttle Position Sensor
- How to straighten a bent skeg ?
- Clamp on mufflers
- Mercruiser hp 500 or other big block Merc motors
- Edge Trim
- Compression Test Results?
- Whipple for HP525
- Hole in exhaust hose, 496 HO
- 454 mag problem
- battery charging
- Fuel pressure increases using race fuel
- Ignition mounting
- 496 Mag Ho Help
- Remote oil filter ?
- NACA DUCTS-anyone know best location?
- cam size
- A slightly different 7.4 question...
- Supercharging Hp525efi???????
- Hyd. roller lifters Gen 6
- What size injectors on 496 MAG?
- Popeyes Racing Team
- Carb Floods When Hitting A Big Wave
- Anyone know where mercstuff.com is
- trim pumps - ebay
- Kachina 30 Drone
- Bomar Hatch
- 502 broke- starting over - need assist
- big block sadness
- bravo clunking sound
- Awesome 26 with twins - Which way do I rotate props??
- so slow?
- more cam or less prop?
- hydrolic steering hose blow out?
- air problem
- clunk when shifting in reverse
- Mercury transom mount water pickup ????'s
- 1'' drive spacers
- Bravo 1 Prop hub 835258a2???
- Why Are My Batteries Connected?
- Got a big oil filter onto a '96 454 MAG!
- Bravo shift cable adjustment ? tool ?
- wondering if anyone can help....
- Need 1 Merlin 310 head, #3003
- More Help--Battery Lug Sizes
- Oil temp or oil pressure - gauges?
- Alpha one upgrade
- Fuel tank float gets stuck on empty???
- MSD airgap spec??
- can 2 1500 watt inverters be wired together
- Best way to transport boat??????
- who is running inverters for a/c powered acc.
- HP500 Valve Springs..How long should it take to change?
- Battery Cable-Wiring Question?
- Fastest After Market Lower ???imco/bmax Ect.
- 454/420hp REBUILD Compression
- Need a good upholster !!!!
- Looking for in expensive aluminum headers for a 7.4MPI
- dash redo
- What happened to the outerlimites 42 carbon fiber at Loto?
- Twin turbo vs. blower/ supercarger?
- Looking for Hyd Steering
- MX 6.2 MPI (320-hp) torque
- Engine Flush
- Drilling Stringers
- gimbal bearing problem??
- HELP 525SC problem
- Some new bling bling....
- Ignition system help
- What is a good motor build for a 7.4MPI/Procharger M-1
- V6 Ignition on a V8 Blower motor? Why??
- How many cubes
- coil bad
- 496 HO cruising RPM
- Teague Platinum 1.36 or Bravo 1 XR 1.50?
- Pushrod lengths for AFR Heads
- beeping alarm won't shut off
- Trailer Problem, Levelers between axles arent working
- looking for BBC heads casting #990
- What heads can be used on gen IV motor
- help with old merc eggbeater, T2x ? anyone
- leaking oil
- 500HP Carb - LOTS Milkshake Oil! Help!!
- Need some help.. kinda boat related!! New well, no water, boat wont run on the hose!
- Impeller pieces - Backflushing??
- Fuel Pressure Measurment
- Exhaust tubing hole
- high pitch noise from my 525 efi???
- torque specs
- Engineproblem
- OUtboard/Inboard
- Water pump?
- where 2 mount my water pressure sender?
- procharger - headgasket where do they fail?
- Wierd Overheating - HELP PLEASE
- I was stoopid. Did I do any harm?
- Jet Boat Exhaust ???
- Bravo stuck in gear
- New Member: Formula Problems
- where should i prop based on dyno #'s and cam??
- depth finder
- New Base Motor
- Easy way to get boat off trailer?
- Water in #2 Cylinder
- 496 500 hp 525hp
- twin 350 mags one is popinig
- REX Manifolds BBC
- drives loose
- Hydromotive Q4
- Degree of dead rise???????
- extension boxes??
- Fuel lines
- Exhaust Manifold Question--fitment
- 496 mag vs. 496 magHO
- Oil in exhaust
- Drives trim at different rates???
- Boat Broke Every Day At Lk Winni!!!!!!
- Help, Drives won't trim up while moving!!!
- Lost
- Battery Cables--Custom/Hand Made???
- 454/420Hp down on power.
- In need of some help!!
- Engine operating temps, what should they be??
- Looking at a Baja with a 500HP motor..
- lost top end after power valve change??
- Marine Radio Cover??
- Help!!! Correct 525 fuel pressure
- Tachometer and ignition problem ?
- Gen. keeps stalling out
- ? for the electrical pro's
- Mercruiser 496HO ECU reprogramming
- Looking For A New Subscription ?
- 454 Mag MPI fuel problem
- what type of speed can i get ??
- 24' Liberator cat.......Looking for info.
- red junk coming out of fuel log on 502
- torque specs
- ?Brad Smith Racing Engines phone #
- RACEPUMPS.COM (fuel pump) anyone tried one???
- Gasoline Additives
- Simple quick question
- HELP with SBC total timing
- Trim Switch???????
- Exhaust ?????
- B&G Racing Computers
- No water out exhaust
- Motor keeps quitting??
- trim pump reservior
- System 1 Filters
- Blown xr drive
- Blower problems
- looking for hatch inserts
- My buddy's 502 problem........
- Plumbing question
- prop shaft bearing preload
- "Old School " outboard question !
- Trailer Weight
- 6 pole rocker switch???
- Steering wheel loose & clicking sound???
- extension box?
- motor heighr on Scarab
- Need '97 454 mag balancer/crank pulley: WTB?
- Konrad Drives , prop cavitation ...
- Why do I keep toasting starters
- Reliability 496/502
- Help - Low fuel pressure on 575SCi in a Top Gun
- voltage meter jumps to max
- TRS install
- Volvo F series Due props.
- changing drive ratios
- wahoooo i got my headers to fit. sweet!
- need a 2 of mercs h2o pressure relief valve
- Prop help.
- Power steering hose Question
- Power limits to bravo 1
- Extrude honing
- Square bore on a spread bore?
- Stringer Question...
- Msd issues ?
- HP rating for a 1990 OMC King Cobra??
- Whipple, Yes or No?
- Crate Motors
- need gas sender
- Fixing Toung Weight On Trailer
- Cycling water temp
- lightning header
- Boating and perseverance
- oops
- Boat leaking...can I seal gimble housing without removal??
- Any hidden h.p. in 310 MPI's
- BBC heads and Esco exhaust
- Where do stock head gaskets fail with a procharger
- Trim Pump Problems
- looking for drive showerfor king cobra
- How to test outdrive ?
- Sources for high-performance-theme fabrics?
- 2005 Merc 6.2 Horizon Low RPM
- Bravo 1 X skeg repair
- Hydromotive props
- yo d-hlaw
- Painting drives while on boat?
- Got my Oil Analysis!
- Bravo 111 Drive Help
- Engine problems
- Procharger experts needed
- who sells raw water pressure releif valves
- my new raw water pick up, whatcha think?
- New 502 and it sucks!!!
- predator boats ?
- any riggers care to give some FREE advice?
- whats the thinest exhaust gasket for bbc?
- Whipple
- Question for the cam guys
- Should we ask oso for a "room" dedicated to lubrication?
- yo, old school guys who made these headers
- holy crapola...my exhaust won't fit ???
- prop question
- Cam and reversion
- Hull issue? Torque issue? Weight issue?
