PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 3/8 hose
  2. High oil pressure
  3. Drive not trimming out
  4. 496HO Blowby
  5. Threw a blower belt
  6. Single or dual Carbs on a blower?
  7. RPM limits on 3.0L Mercs
  8. I need to add to my intercoms system
  9. Raylar - 496 water leak question?
  10. 500hp carbed 500efi
  11. circulating pump seal
  12. Rpm's are dropping. Please help.
  13. trim pump?
  14. Mufflers or Turn Downs
  15. Leakage around steering arm
  16. tranny's ordrives?
  17. Where to install DANA pop-off valve on 496 HO?
  18. 454 Mag MPI - Black Smoke - Fouling Plugs
  19. upload pics
  20. 496 fault code low oil psi str
  21. Wiring help...starting our new 385 stroker on test stand
  22. HP500 94 oil cooler lines need help
  23. Engine Won't Turn Over
  24. High engine oil temps?
  25. 500HP oil cooler lines picture
  26. 502 rev limit
  27. prop/engine/performance
  28. bellhousings
  29. how much oil -525sc
  30. 496 loss of RPMs
  31. 502 carb linkage
  32. using non marine distributors?????
  33. 454 mpi (no power)
  34. gauge light bulbs
  35. thunderbolt ignition wiring
  36. Help needed again.....
  37. Impellers
  38. piston/head/valve clearance
  39. Racing Oil Filters
  40. Engine temp for a supercharged 502?
  41. hp 500 cam
  42. how much power from mpi
  43. Paging Griff
  44. water problem on 454
  45. Vats shut down at machine shops
  46. Baja Steering Cable
  47. 496 mag HO timming
  48. Need 4.5" stainless tubing
  49. Steering wheel slop
  50. 1988 Chris Craft 312 (kc 460 omc's) Thoughts
  51. Dana Marine OSO Discount
  52. removing the advance in a mallory unilite?
  53. Holley 800cfm rebuild kit?
  54. Max boost w/ stock injectors/fmu
  55. 525 Efi Oil Pan
  56. 1997 502 Mag Mpi - gas pump ?
  57. Really Good Oil Filter Cross Reference Site
  58. avon searider.
  59. Breaking valve springs
  60. loose throttle levers
  61. 98 5.7 Efi
  62. Motor Question
  63. Fuel Regulator Vacuum unplugged ?
  64. hours on new engine
  65. 496 to 500 EFI Swap
  66. piston inspection
  67. Ignition System
  68. HP-500 Manuals in PDF format.
  69. Fuel question.....
  70. Breaking Roller Rockers!
  71. how much power with thru prop exhaust?
  72. help with merctrans rebuild
  73. 525sc - what thermostat and engine temps
  74. Bad gas??
  75. oil filter
  76. Factory to Mini Starter, where do the wires go?
  77. gil exhaust one side steam
  78. 28 velosity 502 sick
  79. 502 rebuild Question
  80. water temp guage issue
  81. What type of sealant for blower bearing plates
  82. 500 EFI searched without clear answer
  83. Rocker Arm Torque Spec ?
  84. Is the timing causing my idle problems?
  85. Weird Oil Pressure Issue
  86. Engine suddenly drops to idle but no codes or warning beeps???
  87. Kill Switch/Relay question.
  88. 454 main bearing clearance..
  89. Water Pressure
  90. 525 EFI Serpentine Belt
  91. Aftermarket temp sender on 496ho
  92. Need Harmonic Balancer
  93. anyone know specs on 525 engines
  94. 454 mag heads different
  95. holley 800 Jets
  96. Blower boost,Merc 600 SCi
  97. Leaking Flange on CMI's
  98. Ignition timing?
  99. Procharger fuel enrichment ?'s
  100. installed crossovers now no water temp
  101. adhesive for fiberglass?
  102. taking resonators out?
  103. Is this an ignition coil issue?
  104. Spark Plug Wires
  105. wiring trim switches
  106. Black transon w/ 500 efi's
  107. FelPro Valve Cover Gaskets
  108. send off computer for tune
  109. SBC valve covers
  110. Tachs adjustments ?
  111. Check valve Issue ?
  112. boat riggers
  113. My 540 lost some power...need some advice.
  114. Leaking oil at cruising speeds
  115. Stereo Questions
  116. crazy wiring, msd
  117. stock exhaust with flappers wanting tips..
  118. best bang for buck on 35ss
  119. Engine Going Cold After Coming Off Plane
  120. Spark plug for 454 Magnum Carb, NGK or Champion or ???
  121. Hesitation problem under load 454 Magnum, I need some idea's
  122. repowering 7.4mpi with 496
  123. Generator in a 35 Fountan classic
  124. 496 Alarm going off
  125. Oil Pressure-how much is too much?
  126. mercruiser 454 370 trs
  127. emi manifold issues
  128. No Spark Question??
  129. imco full hydraulic steering question.
  130. 496Ho, need some help?
  131. Spark Plug electrode burned. Any ideas?
  132. reversion or manifold problem
  133. Gil exhaust with sidemount?
  134. Sticky indicator
  135. Thermostat issue?
  136. fuel gauge woes
  137. Liquify Carbon and Varnish
  138. CMI Headers cracked
  139. Intermittent fuel pump problem
  140. good set of headers for a 454 mpi
  141. WOT problems
  142. Need a good placard....
  143. Eddie Marine exhaust
  144. Mercury Quickleen
  145. Is it over? Ethonal :(
  146. Thru hull exhaust cutout dimensions
  147. Exhaust Extension
  148. Water in bilge problem identified...now to fix it
  149. HELP with fuel rail plugs...
  150. Hyd steering presure adjust at idel?
  151. Tuning update / New issue
  152. BBC Serpentine conversion???
  153. Cmi Full Tails
  154. Any ideas????
  155. most popular dry sump for offshore
  156. Bellows Question
  157. Installed Stainless Marine Exhaust and LOST RPM!
  158. 91 Wellcraft(383's) OR 91 Powerquest(454's)
  159. Alarm sounding on 350 MPI
  160. suggestions for starters
  161. Oil Build-up On Top Of Pistons
  162. IMCO inner transom plate conflicts with steering lever?!
  163. Steering adjustment?
  164. Gear Lube Bravo 1 XR
  165. 454 mag??
  166. merc oil cooler/filter lines
  167. power steering pump replacement
  168. Crane Ignition Box
  169. Another overheating question
  170. spark plugs 454mpi procharged
  171. Pressure Readings On Trim Pump
  172. What's it worth?
  173. Oil pump, HV or standard?
  174. 525 impeller change
  175. ECU Question (MEFI4-A)
  176. 496 ho lost RPM
  177. HP500... What Spark Plugs?
  178. Engine Loading Question
  179. Oil pressure - engine on the stand - I can't search well :-)
  180. Kiekhaefer tabs
  181. 496Ho Code help
  182. Merc part guys.
  183. Engine miss & backfire
  184. help low rpms
  185. Procharged 502
  186. exhaust manifolds
  187. Tired motor ?
  188. Need Recomendation
  189. Adjustion Rolller rockers, and clearence
  190. 34" Center, Tall Decks and E-Tops
  191. Crane 731 cam guys
  192. 575SCi - Alarms going off. WHY? - need help
  193. LCD Monitor screws up
  194. 496 ho plug wires are $500!!! Please read
  195. Plug Diagnosis
  196. Ignition Timing
  197. Volvo Penta Synthetic Oil
  198. Bilge pump switch question
  199. Dual Ram Imco hyd. Steering ..... air in System ?
  200. Any reason a new engine would have less break in oil?
  201. Diacom evaluation
  202. oil setup question
  203. Oil Pan Options
  204. Gentle Wax/Cleaner
  205. LS vs 350Mag weight savings
  206. 454mpi with procharger loses power ,smokes,etc...
  207. Engine temp
  208. Any longterm updates on 496 Mag HO's with Whipples?
  209. Bravo 1 RPM
  210. B&W 72C Question
  211. How Fast Is It??
  212. Science of Synthetic Oil Video...excellent production
  213. Need help/advice
  214. 575 Sc's
  215. What is best????
  216. Risk of fresh water flushing ?
  217. 496 exhaust
  218. 454 wieringdiagram? Transsmision TRS?
  219. 700sci oil filter
  220. Mercruiser Tunderbolt distributor
  221. Need help with electrical gremlins
  222. Merc HP 500 carb replacement??
  223. Who makes this pump????
  224. Help if you can
  225. Are all brovo gimble rings and helmets the same???
  226. Re-program ECU's
  227. GPS Spedo Question ?
  228. lean at high rpm??
  229. Trim Tab gauge
  230. what is the difference
  231. Trim Tab Question
  232. 454 Heads Needed ASAP!!
  233. Engine Stands / Shipping Crates?
  234. Is relocating the oil filter on a 496 possible?
  235. fuel system help
  236. holley 800 carb rejetting ???
  237. Mercruiser 502 Mpi Starter Problems
  238. Vacuuflush/head question
  239. iac valve issues
  240. Best place oil temp sender
  241. T-bolts for exhaust clamps
  242. Ignition breaker size
  243. HP 500 Service manual
  244. Need a special bravo shift cable
  245. Help with hatches not going up.
  246. oil type
  247. Leakdown?
  248. water on spark plug
  249. Corsa Quick And Quiet
  250. Need Best price on set of Lightning Headers
