PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. 525 sc valve cover gromets
  2. Does anybody run twin EFi engines with multiple fuel tanks?
  3. I need to paint a couple of aluminum pieces. What is the best spray paint? thanks
  4. used pro chargers in classifieds?
  5. Pyro's and O2 sensors
  6. If you ever cut open a PCV valve
  7. Verados and DTS
  8. Manifolds hit headbolts.
  9. Cockpit Communication Radios
  10. 950hp n/a twins...
  11. Exhaust riser adapter / spacer question
  12. which head gasket Mark IV - cast iron heads
  13. Question on GIL exhaust/turbulator
  14. Trim Tab re-install
  15. Cam selection
  16. modified 502mpi intake on 502 dyno session at my shop
  17. mpi and efi intakes?
  18. Head Gaskets
  19. Q
  20. HVAC question
  21. 1 inch longer head blots for darts
  22. Thru hull fitting for trim cables.
  23. wanted Diacom record file of stock Merc496ho idle to WOT
  24. Boat city prop??
  25. Iron VS Aluminum heads
  26. #3 drives on TRS BOAT IS IT WORTH IT???????????????
  27. Camshaft for Mercruiser Cyclone 440hp
  28. 454 mag piston dome cc's
  29. Gen v fuel pump
  30. GGB muffled exhaust tips?
  31. AN fitting size
  32. Builder used different cam than specified.
  33. K-Plane 280 plug
  34. Mercruiser 377 Blues
  35. Dart big m sportsman head gaskets
  36. 460 Commanders to a Bravo drive?
  37. Question on fuel lines/hoses - non coast guard approved
  38. TBS 871 to BDS 1471 questions?
  39. 1997 7.4 bbc
  40. Marine Lubrication Update Thread
  41. LeakProof
  42. imco extension box question
  43. Effects on cam advance/retard
  44. cutting runner length of 502mpiMag
  45. 6.2 mpi
  46. 42 Tiger adventure begins!
  47. Ge wiz. What am I going to do with all this lottery money. I'm going to win.
  48. why stainless steel rocker arms?
  49. Transom water pickup any advice ?
  50. Diesel offshore racing boat
  51. Input on which roller rockers - BBC
  52. 1990 Guest 2540A charger documentation
  53. 454 Build Help Please
  54. Outdrive repaint what putty can be used ?
  55. Solid roller lifters with bushing wheels whos running them in a high lift cam .750+
  56. Where to buy Transom HD Assemblies? A business is jerking me around!
  57. Mercury 700 SCI & Whipple Upgrades
  58. Merc engine start/control help
  59. SBC cam spec help!!??
  60. For the LS engine lovers
  61. Stock Oil system routing. 420, 450, 500, 525sc.
  62. Will the bi-directional circulating pumps work the same?????
  63. bolster seats
  64. Which carb adapter plate? Merc 454
  65. CFM on the 500 EFI Heads?
  66. average price on removing and reinstalling twin 502s?
  67. Impacts of hitting rev limiter?
  68. Spark Plug Recommendarions
  69. 525sc
  70. Distrance Between Transom and Stringer Mount Bravo
  71. 06 496 Mag exhaust, stock or not??
  72. Best 33c cable?
  73. 93 scarab sprint 18 with a 3.0 lx and alpha1 gen 2
  74. Scat stroker kit quality question
  75. 502 MAG EFI MEFI 3 wire harness
  76. Mercruiser 454 serial number info
  77. Exhaust systems
  78. 350 mag exhaust issue
  79. 525efi - mechanical fuel pump oil change
  80. Clean up engine wire harness
  81. Are Strykers any good??
  82. Change oil and takes longggg time to build pressure
  83. ehuast tips
  84. 2.25 valves too big for 454
  85. 500 efi ecu upgrades what did you gain?
  86. Boat detailer recommendations in North Dallas
  87. HP525 ECM Question
  88. Roller Cam Bearings?
  89. Looking For Advice On Hydraulic Steering!
  90. What's out there for big sea strainers?
  91. Bulldog cam problem
  92. building 375-400hp 383 stroker
  93. K-planes travel question ( angle )
  94. Gen VI oil valve question
  95. Drive height question/Prop Slippage
  96. Read this before posting in this section!!!!!!
  97. 496ho exhaust
  98. Soot on transom after fuel filter change
  99. Battery explodes! Why?
  100. O2 sensor question?
  101. hylift johnson lifters.
  102. Texas Winterization
  103. Need electrical diagram help 03 496 MAG alternator wiring
  104. Liberator 241 engine options
  105. 502 mag high pressure line
  106. Piston dome cc
  107. UPDATE! Water driplets and stains inside SS Exhaust riser
  108. LED Transom Lights
  109. Drives..turn IN or OUT??
  110. Converting an old school Gale Banks Twin Turbo system to modern technology
  111. Need some gimbal parts before installation advice please
  112. need a little 496 winterization help. kinda, and another question.
  113. 500efi power steering
  114. 500 efi engine badges
  115. Milling of an intake
  116. Most hrs on a Gen 1 verado 225, 250, 275 motor
  117. Piston pic.
  118. switchable exhaust tips vs silent choice
  119. Oil Pressure Question... Nothing broken but chasing an oddity
  120. Teach me about Exhaust riser angle Please.
  121. Engine/Outdrive Swapout
  122. 1989 23 nova xl wellcraft side engine vent inserts????
  123. Rods
  124. Need 525 EFI Flush Kits
  125. What's this ?????????
  126. Widebands
  127. Bravo Bellhousing to Inner Transom Plate
  128. File fit rings
  129. Head gaskets
  130. Log to Centerise Exhaust Manifolds
  131. Manley Nextek springs? Anyone?
  132. Procharger boost 91 octane
  133. What type EGT probes
  134. Merc 420 to 525sc in a Formula 242.
  135. Pulling a motor from the flange of a 177 wieand
  136. fountain 33 vs 29
  137. Exhaust issues Gil/bulldog 500 bbc stainless risers
  138. intake suggestions for 365 mag build into 420/450hp
  139. Cross over kit
  140. impulse II cam thread
  141. Milling heads for compression
  142. installing gil manifolds
  143. Torque #'s
  144. pump gas 540...
  145. Cam choice
  146. What do you think about this engine in the calasifieds 1209HP
  147. Dash redo, gauge less options.
  148. Single engine in a Four winns liberator 261?
  149. Getting water to a motor with no outdrive on it??
  150. Melling 10778 oil pump question
  151. Cam question
  152. 525sc cam info?
  153. Ok, we need a new thread: quench
  154. Looking for best Bilge Paint. Can you recommend?
  155. gen 6 555 ci oil pans
  156. Starting motors that havent ran since 2007...
  157. 7.4L MPI Won't Start
  158. Go To Bilge Pump and Float Switch?
  159. Anybody running Gen 1 verado's?
  160. 500efi thermostat replacement kit
  161. Jandsafegard Interceptor Knock Controller - Anyone Using This Product?
  162. Ignition dead on 525sc
  163. Dead ignition on hp500efi
  164. Are HP500 intakes brass lined?
  165. 310 cc heads
  166. Is filling fuel tank really necessary when winterizing?
  167. 6.2 whipple stage 1 ecm reflash
  168. Need A Part #
  169. Detonation Issues - "Why is the Gen 7 496 such a bad platform to build"
  170. cast aluminum merc 8 quart pan oil pick up part #
  171. Water Flow - flush kit vs. lake
  172. 575sci running rough
  173. Will low oil hurt 500efi?
  174. Saginaw to Brazilian actuator question.
  175. 500EFI Intake modification/adaptation to Pro Flo EFI
  176. Water driplets and stains inside SS Exhaust riser
  177. Tuningparts for newer 8.2 Engines from Merc available?
  178. Will a plugged exhaust cause an engine misfire?
  179. 377 Blue Scorpions
  180. Compression test readings
  181. Shifter plate question
  182. 500 EFI fuel pump oil?
  183. Inconel exhaust valves, when do you need them?
  184. Aluminum head corrosion
  185. Procharger fuel system
  186. Do the headers on 2001 500EFI have ports for oxygen sensors?
  187. Spark plug gap with MSD
  188. Carb guys and/or fuel issue
  189. Pulling an engine TRS SETUP
  190. deciphiring Crane gold rockers
  191. -2 Outdrive performance gains
  192. Fountain 29
  193. X-Power Drive
  194. KE lightning top end kits
  195. Noisy clanking exhaust tips.
  196. Power steering pump delete kit
  197. Cooling system
  198. 525 coolant recirculation pump
  199. New to forum. Need help
  200. Merc 8.2 HO Flame Arrestor Flange Diameter?
  201. Boat Lift Question
  202. Power Steering pump delete kit. Gen 6 motor with serp belt.
  203. Locate a PROPSHAFT DYNO in Midwest???
  204. Reality check for repair quote
  205. fuel injector cleaning&testing
  206. rebuild time
  207. Clogged block drains
  208. 500efi
  209. 42 fountain staggered conversion: need exhaust help
  210. WHat ECU to use, Megasquirt 2, Microsquirt, Accel 7 or other?
  211. How many hours on bigger power stuff?
  212. E10 or E15 ethanol blended fuel and aeroquip/earls stainless fuel line problems
  213. Anyone have personal experience with the Professional Products/ Pro-Comp intakes?
  214. Engine alarm Help
  215. 454 making 525-550hp
  216. Lighting Header repairs?
  217. Full Hydraulic Steering
  218. Offshore style engine mount
  219. NLA mercruiser exhaust valve seals
  220. surface drive on a pontoon?
  221. MEFI 3 (16237009) vs MEFI 3 (16236999) help needed
  222. Procharged outlaw 25, no getting power to prop
  223. problem with aftermarket cylinder heads.
  224. 502 pistons
  225. Top end work on blown 540s - what eats exhaust valves?
  226. Inteior Vinyl Surface Mildew Remover
  227. PSE superchargers
  228. Differences between Gil exhaust manifolds and 496 exhaust manifolds?
  229. Electric fuel pump question
  230. Engine builder/ Machine shop in michigan???
  231. Livorsi Control Problem
  232. 496 Stroker...irratic rpm..stalling
  233. Looking at a used boat purchase?
  234. Feedback on Arizona Speed and Marine 575SCi calibration
  235. Crossover pipe (coolant) question.
  236. Out of the box heads?
  237. Price to have motors pulled?
  238. Whippled 500efi refresh
  239. Mercruiser 496 Starter issue
  240. 540 engine vacuum question
  241. What do these bearings tell you?
  242. Sea strainers and blockage ?
  243. 100LL aviation fuel in a Mercury 300x
  244. Rusty bilge water.
  245. Cam Suggestions for a 540
  246. gpm of water to run a mercruiser on hose
  247. How do you test/diagnose fuel injectors ?
  248. Prop Shaft seal in a SXC 4
  249. Engine rebuilders in the Chesapeake region.
  250. 502 efi heads
