View Full Version : General Q & A
- ProLine heads??
- life expectancy of a HP500 Belt???
- F1 Sutphen prop
- Whipple or AS&M
- exhaust
- Oil Cooler Plumbing
- Rtech Big Gun Debuts in Doller Offshore booth in Miami
- Alignment help
- What would you do ! with a 38 Scarab!
- XR Input Shaft Seal
- Blower Ratio for Boost
- holly carbs
- Velvet Drive Catch Can
- Silicones / 3m
- 502 Valve Springs
- trs drives
- best supercharger for 496ho?
- crossovers on a 502 mpi?
- blow box legality,,can I make one??
- 8.1l Gm/vortec Engine ?
- lab props
- Subs
- Bravo I RPMs ?
- 500hps
- mailman////////// RPM
- expected mph gains?
- 454-502 & 500 EFI Dist-cap & Rotor #
- 25P Mirage Plus PN Question
- Blown 25 Baja ?
- BBC L-29 vortech heads price??
- Top 10 Newbie Mistakes
- 420 hydrolic vs. hyd roller teague
- Engine Popping
- disc brakes ?
- How should I sell the B1 lower??
- Hydro Lock Exhaust Problem
- Spark Plug Gap for 454 mag
- Tuning Merc EFI
- Aluminum Boat repairs??
- Scarab3mdc
- Jim V........... RACE BOAT PROP
- bravo one limits
- Marine wire source
- which outboards to trust
- 330 on steroids?
- procharger 12 rib crank pulley wanted and carb advice
- 496 HO mag - Whipple or Procharger?
- Outdrive service?
- is 50ft vee too heavy for XR's?
- Replace, rebuild, refresh blower motors?
- Lifespan of headers
- prop help?
- Cleats
- ZOONFUN where are you?
- Best Oils
- Bravo 1 temp sender?
- Where to mount engine, tranny, p/s coolers
- Velvet Drive Transmission clutches warped
- These valves OK w/supercharger?
- Shifter cables
- what spark plugs with blower
- Structural Fiberglass guy in Chicago Area
- Whats involved in De-Fogging?
- Bravo gimbal housing question
- 90 degree Sea Water pump
- Prop Safety
- cost for trailer axle?
- Solenoid Dump Valves needed
- Cam/Heads/Exaust
- 500 cam #
- Life expectancy of a 2000 502mpi??
- What SBC valve springs do I need?
- Merc Oil Filter Study
- stuck in reverse
- Where to buy 'Perfect Seal' sealant?
- 502 mpi AZSpeed Upgrade
- what blower on 640 cu.in
- MRD 700hp blower motors
- MEFI 3 plug pin map
- 500 EFI bad fuel pump
- 502 Mag (root, whipple or Centrifugal)
- Problem Areas? GM Crew Cab Dually
- 540/572ci with stock 502mpi injection
- imco shortened drives
- How complicated is it to bebuild a Rochester Q-Jet
- Outdrive toe-in/out
- skeg guard
- Plugging holes in transom?
- GM 4x4 problem????
- Less timing at idle = less reversion?
- Anyone have a Procharged 496 HO?
- More TRS Trans questions
- info on whipple 525 efi
- Anbody install Aftermkt Cruise Control on your Truck
- Trim switch on steering wheel
- Valve cover breathers..
- 1999 L-29 vortech or Merlins
- 502 mpi vs 502 efi
- procharger
- Dual batteries - different type??
- seats
- Valve Cover Breather Hose
- 496 MAG secrets?????
- New motor --- need help from the pros
- Trans rebuilt on a trs
- Vortech
- Merc Combination Oil+PS Cooler
- anyone know where to get good pistons at a nice price
- repainting/reassembling lower drive units
- Eagle h-beam rods
- alpha ss drives
- 496 HO Oil Leak!
- OT Just got some DVD
- Hey cobra Marty - onboard Dyno Q's
- Johnson Outboard
- Scarab I Deck Hatch
- Speed with a 377 6.2 small block??
- 7.4 compression ratio
- Alternatives to Corsa Q&Q"s?
- Fender rack / holder / storage
- cadorette
- K-Planes angled or level?
- "standard size" of exhaust?
- Closed cooling???
- 351 Ford Ski Boat Question
- Impellar question
- Kamma surface drive
- Exhaust manifolds
- formula for finding compression ratio????
- 1977 cadorette 19 foot
- What should I expect when my drive gives up?
- Bravo 1 to XR
- X-dimension
- Hydraulic Steering
- Factory 502 MPI Cam Secs?
- High Altitude Boating Power Loss
- Installing Generator in cruiser
- What type Sending unit is this?
- Big Block Buildup
- Closed cooling?? how do I do It??
- Cost to replace rubrail @ LOTO?
- Fel Pro part # help
- SBC Exhaust Selection
- O/T Adding 2 More Bunks To Boat Lift
- IMCO or Sportmaster Shorties ???
- does arizona speed and marine 575sci upgrade kit work?
- KE Exhaust Testing
- camshaft advice
- Distributor Rotation?
- Flywheel???
- Ron Hill Prop???
- Rtech Supercooler for HP500EFI introduced at L. A. show.
- 496 mag VS. H.O.
- Who is running a sportsman 2 head?
- Are TRS and small Bravo shaft props interchangable?
- Plumbing intercoolers? No pump?
- Vinyl Graphic Guru KC / LOTO area
- Lash Caps
- Gaffrig Gauge Question?
- 454 bored and stroked to 496 vs. stock 502
- Paint brands ??
- What header would you buy IF
- Flywheel
- Spam
- What compression ratio should I aim for in a 350?
- Spraycore hulls
- Anyone know about 1990-91 502 mag Difference
- Need Prop Guru Help
- Exhaust Diameter
- Closed cooling / Electric Water Pumps ?
- Anti-freeze leaking from 496
- Has anyone swapped out a 7.4 with a 454 mag/502
- trs drives
- Engine Water and Oil Cooler Plumbing
- Flywheels for TRS Drives
- exhaust
- Plumbing New CMI Elbow Tops?
- Volvo Drive Noise
- Bravo X drive's
- # 5 drives vs # 6
- Please Recommend Best Alpha Drive Shower
- 500 EFI's - 10:1 Compression
- Getting rid of silent choice?
- HP500 Valve Seals
- Antennas
- Desktop Dyno
- MerCruiser Exhaust Diverter Air Cylinders
- Towing
- Carb selection
- holley ??
- 1999 28 imp viper
- Speedmaster Two Drives
- How many impellers do I have to change ?
- rev limit
- Sleek Craft Enforcer 30
- HP500 rebuild cost?
- Intercoolers
- Trailer Brakes
- electric water pumps?
- wire harness question.
- Engine coupler replacement in twin 350 28zx Donzi
- Cutting Guide Plates
- 86 baja 220 force
- Bolts For Exhaust Tips???????????
- trailer??? "bunk"
- Can I join the trailer queen club?
- MacDad260, DD2000 results on cams
- Outdrive swapping for even wear?
- Trim tab mounting position?
- Nosecones...Are they worth it?
- Rockers
- Herring props for a Promax 300
- ? thunderbolt IV for HP500 carb
- Hardin Marine - Cyclone Shorty Header
- exhaust tips
- What kind of heads for a SBC 350?
- Bravo 1 Question
- Arizona Speed & Marine Mercury 575 SCi Boost Kit
- crossover pipe w/ bypass
- 28zx 502 Blue Print Bottom?
- Not Technical, but need help
- prop nuts
- Mercruiser engine swap? cost?
- Herring Props?`
- Prop blowout. Any sugestions
- nova 1975 repower 400 SMALLBLOCKs
- Boat leaning
- Qjet carb ID?
- Which Mirage Plus hub?
- Found the squeaking pulley...
- anyone regognise this
- Hull Blueprinting
- exhaust question please help
- Ok, how much HP can a TRS drive handle
- Acylic Windscreen Fix
- XR vs. Teague XR
- How many hours out of 350mags?
- 350 engine removal
- 4.3 engine swap
- Compression for 1998 350 mag mpi's with 330 hours
- Mach props?
- Carb selection
- Whipple 496 Ho
- Compass Repair
- cam specs on 496 magnum
- New motor leaking oil how do you deal with the chev dealer
- Keikhafer tabs
- Houston Propeller or Mercury Racing
- Thunderbolt IV HP question
- cabin doors
