PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 [45] 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Could m3 prochargers make 800 hp on 509ci motors making 640 hp Already
  2. remote oil drain 454
  3. Magnum boat lift
  4. how does 350mpi to 383 work?
  5. Why are outdrives so expensive????
  6. milkey oil
  7. Imco power flow exhaust
  8. Help with antenna
  9. drive and tab cables
  10. 575sci aftermarket thermostat housing?
  11. How much HP are my 540s?
  12. Best way to mark con rods and caps on disassembly
  13. 540ci. Got questions
  14. 28 SleekCraft big motor???
  15. Is it me or the Dealer ??
  16. 489 post mortem
  17. Cam LSA
  18. + 4 mph with AFR heads ?
  19. Instrumentation anywhere you wanted
  20. How much can I change on rotating assem. before I need to rebalance?
  21. Looking at a boat with no title? Can I get a title some how?
  22. 500 efi long block replacement
  23. -18 steel braided line for cooling hose?
  24. procharger set up for 800 hp
  25. Looking for new steering wheel.
  26. Gil Exhaust mod....
  27. TR II or III id
  28. mechanical trim indicator part needed...
  29. hyd. steering & trim tab questions
  30. Why a rounded keel vs a pointed keel?
  31. Full HYD steering hard to turn right only
  32. Trim Tab Questions
  33. Lorequin marine inc open or closed?
  34. 489 hard to start cold
  35. b&m 250 blower carb plate question.
  36. Distributor gear for 454 gen vi crate engine?
  37. How long can a boat stay submerged??
  38. Procharger lossing boost at 5400rpm???!!!!
  39. trim pump resevoir, where to get
  40. Just bought a procharger for my 502mpi need help with setup
  41. Rebuild
  42. Wiring for electric choke
  43. any one used mr.cool oil coolers?
  44. does anyone have any experiance with a 4.37 crank in a gen 6 454 block?
  45. Procharging and boost referencing?
  46. Compression ratio ?
  47. Pro charger pulley measuring
  48. electric hatch actuator
  49. Motor tuining in California
  50. Timing a 1997 7.4 bravo
  51. 496ho IAC
  52. Looking for ECU advice
  53. out drive paint ?
  54. Am I missing anything?
  55. whats it worth???
  56. Has anyone used a Dart 330 CNC Iron Eagle?
  57. Measures To Take When Having Major Mechanical Work Done
  58. Raymarine c80 question
  59. Sound Regulations - What are my options?
  60. dead spot on throttle advance 496 ho
  61. What does it cost to chrome parts
  62. WD-40 on motor for winter storage???
  63. 496 HO wont go past 4300
  64. Questions about a 2005 575SCI
  65. What can cause a MSD to not spark?
  66. question about bravo trim cylinders
  67. Exhaust problems
  68. 1997 31' Scarab Louvers
  69. sidemount whipple kit at local auction
  70. B and M 250 MPI Blower Kits
  71. Latham Steering Function - How can this be right?
  72. Tunnel Ram & 2 4's
  73. whipple fault code 15
  74. Mercruiser 7.4 upgrades???
  75. procharger pulley change question
  76. Mercruiser 420 HP 454 balance questions
  77. 525efi vs 525efi with Whipple resale value
  78. 225 Promax compression
  79. Big gear, Small prop -vs- Small gear, Big prop
  80. What are these connections for?
  81. High capacity oil pan
  82. Which flywheel for bbc
  83. ITS assembly help
  84. bellows leak?
  85. New 489, Runs 10 deg warmer than before
  86. HP ignition
  87. General Mantenance Questions
  88. Selecting a supercharger
  89. What pistons come in a 502 mag?
  90. What brand are these? What are they worth?
  91. Integrated Mufflers?
  92. engine hour fraud
  93. Leading edge lowers for Bravo
  94. imco -2 lower on 25 daytona
  95. Power steering fluid?
  96. b&m 250 blower upper pulley.
  97. Mercury racing 525sc value
  98. Imco Hydraulic steering lines and fittings
  99. Upgraded alternator for a gen v 502 mpi
  100. Confused about total comp. verses octane :/
  101. formula 400 ss hard top?
  102. hardin marine manifolds question
  103. Anyone Scatter a ZZ572 crate engine?
  104. Where to purchase riser/tailpipes for stock 454s thru hulll
  105. Bravo three question
  106. Max,Dayton or MSD box
  107. Should I relocate the "Cool Fuel" system?
  108. MSD6 Box
  109. how much????
  110. How much HP can a 2 bolt block handle?
  111. Power Steering ISSUES!!!! help plz
  112. AVENGER 25 Information
  113. trying to wake up from a 15 yr nap.....
  114. 1996 7.4 mpi Timing question
  115. MSD-6M ignition box
  116. What BB Cast aluminum oil pan
  117. big block chevy valve cover not sealing
  118. Texas 540 Hawk pressure drops after seconds..knock at the back of the engine and..???
  119. Are these risers normal for Gil manifolds?
  120. 1996 7.4 problem solved
  121. Spark plug question
  122. Installing an A/C Water Pump
  123. Knocking pins out of K-planes
  124. Gen VI BBC heads on a Gen IV BBC
  125. 502 upgrade plan.....opintions??
  126. want to put a 10-71 on my 502 motor.
  127. Big Power exhaust systems
  128. Can I eliminate a couple of these gauges? old race boat....
  129. Exhaust Valve
  130. Reduce fuel pump noise
  131. Throttle
  132. Can stabilized gas be re-stabilized?
  133. complete rotating assemblies
  134. Torque specs
  135. Max safe piston/cylinder clearance with procharger?
  136. Ke pump or electric?
  137. Winterizing and intercoolers
  138. 1996 mercruiser has intermmitant spark now
  139. Fountain or Cigarett
  140. Switching from alpha to bravo
  141. Dui
  142. Whipple 2300ax oil?
  143. 496 mercruiser fault codes
  144. Spark plug gap...How much does it really matter?
  145. Fogging out 502/454 MPI's.
  146. 500 efi compression
  147. B&M 250 supercharger 502 454 efi
  148. B&M 250 parts
  149. Can you identify these exhaust manifolds?
  150. "Dry" exhaust and Cam Selection Question
  151. 1998 350 mag question
  152. What risers (height) do I need with a TRS setup?
  153. 1996 mercuriser 7.4 still no spark
  154. piston replacement
  155. Cam part number
  156. Quick engine cradle clarification?
  157. What crank? Eagle, Scat, Calias, Crower?
  158. Tach Problems
  159. Engine sync gauge or?????
  160. Water leak
  161. Crane box Repair
  162. Power trim hoses... LONG... who makes them?
  163. Starting issue 89' 350 OMC Cobra
  164. Stellings Boxes - Leak Diagnosis?
  165. Stainless Garboard Drain?
  166. Gimbal trashed,need hep
  167. Reputable Mechanic in the South
  168. cl find. philly. 93 scarab 31 no mtrs $9k.
  169. 525 oil temp question
  170. Oil Temp Gauge - Not working (496/8.1)
  171. Rod main bearing looking bad after 80H
  172. More power options?
  173. Beating a dead horse with oil!
  174. What performance ignition does everyone run?
  175. Aluminum cyl head question????
  176. 1996 7.4 mpi efi still no spark
  177. Marine stereo units compatible with newer Apple products?
  178. 1996 mercuriser 7.5/bravo3 Interupter switch
  179. stainless bolts for exhaust manifolds?
  180. Find a member
  181. Carb size suggestion
  182. F16 Canopy Weight
  183. How much is a 96 502 mpi worth with 203 fresh water hours?
  184. What is the real story on Great Lakes?
  185. 1996 mercruiser 7.4 efi/mpi NOW NO SPARK
  186. Aeromotive fuel pump change/stock regulator?
  187. Rust Removal?
  188. Engine has rough idle and missing on acceleration
  189. bottom of the scag to cavi plate measurement on a bravo 1
  190. Stereo advice: help me piece together a GOOD system!
  191. will this drain the whole block? BBC
  192. Identify this crank sensor?
  193. Anyone played with diesels???
  194. CMI Tailpipe length
  195. Aeromotive fuel pump change (help)
  196. What do you guys think it will gain?
  197. Bilge heating this winter
  198. Where to find angled exhaust flanges ?
  199. Help!!!need gails # at fountain
  200. 496 MAG HO roller rocker install
  201. Fountain or Baja is the question
  202. Mercury Blue Racing Spray Paint
  203. Bravo 1x drive alignment????
  204. Engine vibration
  205. Replacing Tank on Formula 302 LS, How to do without foam?
  206. Exhaust leak ?
  207. Twin prop rotation
  208. Need flywheel advice
  209. lightning headers
  210. Engine noise help needed
  211. Where to install gauge senders on gen vi
  212. 555 cu in mpi
  213. Can oil pressure readings vary much from one spot to another.
  214. How to shim starter?
  215. Help with new purchase
  216. trailer reg ???
  217. Fuel return ???
  218. How to get rid of porpus 38 Cig?
  219. Comp Cams Rockers
  220. NOOB is it a mag or not???
  221. How many Qts. of oil in A 500efi
  222. 500 bulldog question
  223. Chevy 383 stroker build
  224. 575SCi blower change
  225. Aluminum fuel tank life?
  226. Pump to drain old engine oil?? Which one?
  227. What am I missing? Milkshaked Oil
  228. 3/8 inch fuel pick up tube
  229. Fuel Issue
  230. 454
  231. Fuel Tank Selection Valves
  232. Oil Pressure Sensor
  233. 496 mag ho head gaskets
  234. low fuel cut off switch
  235. Inverted oil filter trick?
  236. winter storage fuel question?
  237. Should I remove the circ. water pump ?
  238. hydrolic steering
  239. Model ZZP what is it ?
  240. NGK "Iridium" plug wear
  241. Converting supercharged 502 to injection
  242. Switchable silencers?
  243. connecting rods
  244. What engine for fast quiet ride?
  245. CMI Header leakage
  246. carb question
  247. Did I burn it up???
  248. Messed up speed-o
  249. VHF radios
  250. Cutting Lexan
