PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. how long at what rpm
  2. Odd 575SCI and tachometer problem
  3. horsepower happy: How much?
  4. Water in Hydraulic Oil
  5. Did I blow a trans?
  6. Changing gelcoat color?
  7. Who makes this Trim Tab?
  8. Electric Bolster not working
  9. trim cylinder hyd line leaking
  10. alarm going off
  11. Drive Vibration?
  12. 502 Mag EFI vs TBI
  13. 502MPI with low oil pressure
  14. MPI Wire Harness
  15. High Oil Pressure - Help!!!!!!
  16. Will thunderbolt 5 ign. work in a IV??
  17. won't come out of the water
  18. OMC 460 Cobra exhaust risers
  19. Gear change in Bravo??
  20. More Horsepower Please
  21. Whats A Good Rpm Range?
  22. Exhaust Holes Through Transom
  23. How common are gelcoat cracks in a boat?
  24. Powder Coat Drive ?
  25. question on Merc alarm system
  26. Dart vs Merlin
  27. Oil for 525EFI
  28. I Recommend Teague Marine
  29. Engine modification
  30. Want to swap Bravo III for I or Blackhawk
  31. Check both drives while repairing bad one?
  32. Rebuilding a 28' Apache?!?!?!
  33. Air Pump For 1991 Corsa Mufflers???
  34. Mercruiser EFI
  35. Navigation Equipment Recommendations?
  36. Class Rules for A-Class in mid-1990's?
  37. Mercury 496 Mag HO question
  38. Broken Cavitation Plate
  39. Mild Horsepower
  40. Plumbing a mech fuel presure gage?
  41. Milling heads and notching bores
  42. CMI braided hose question
  43. Engine doesn't start. (454 MAG Stock)
  44. Attention KAAMA drive experts!! Need prop help
  45. Best Drive tow in or out settings
  46. Too small of cam?
  47. bravo1 lower gearcase VS. rock pile...... help
  48. How hard to change low water pickups to regular?
  49. Need 7.4 Long Block
  50. Rebuild or upgrade components 454 HP420???
  51. 502 carb jetting
  52. 502 Long Block $$
  53. Stelling
  54. 502 MPI VST Check
  55. master blaster
  56. LH prop on a RH drive?
  57. Looking for Alpha Inner and Outer Transom assembly and complete Alpha drive
  58. Mirage Vs Mirage Plus.
  59. prop suggestions ?
  60. HP500carb/Max power RPM
  61. Solution for Head Gasket troubles- Blown or N/A
  62. Oildyne pumps
  63. weber carb rebuild?
  64. where do you guys buy parts for a tune up?
  65. Room at Cumberland for Poker Run
  66. Fooling the computer...fuel & water temp?
  67. 04 29 fountain 575 blown xr is it just me
  68. need 2x V6 or HP modules for ThunderB IV
  69. Salvaging My Sunk Boat- What Should I Save?
  70. clever props
  71. need help finding the right prop
  72. AFR heads: Anyone else interested in buying?
  73. Crusader 502?
  74. Propeller Advise 292 Formula
  75. Fed up with Dominator, any ideas on where I can send it ?
  76. Supercharged Engines of LOTO Shootout
  77. Low water pick up with a nose cone... How about a screen?
  78. Bravo from TRS conversion, What is needed?
  79. Water pressure increased... Help.
  80. #4 cylinder failed 3 times in 3 rebuilds on 502zz
  81. MerCruiser Rev Limiter?
  82. 496 block, What head will fit.
  83. good luck to our friends in Florida
  84. HP500 carbs on a 450HP/454vortec JETS??
  85. zz 502
  86. Houstonprop help, I just smoked my prop
  87. The advantage and disantvantage of mounting engines close
  88. Bending water supply hose
  89. Idle step down kits
  90. Mercruiser 7.4L Harmonic Balancer ??
  91. can I run without flappers in y pipe with crane cam?
  92. TRS Drive Fluid
  93. Bravo XR stuck in FWD??
  94. Has anybody flat spotted roller lifters w/synthetic oil?
  95. How wide is the old style 2.5 cowling
  96. Murphey's Law,oil rings don't fit!!!!!!!!!!!
  97. Status of Shoreline Trailers
  98. Pfaff or Teague or ?
  99. where are flappers located in y pipe?
  100. HELP...One motor burning alot more fuel???
  101. What is oil pan capacity on Mercury Bulldog?
  102. how to tell top ring with NO instructions??
  103. what would a starter tooth sound like?
  104. High HP engines stalling when placed in gear.
  105. speedmaster 3
  106. Popping through the exhaust
  107. This winter's project
  108. 600 lbs less, almost same speed.
  109. stumped on rattle?
  110. Reversion (again)
  111. 502 EFI dying after reaching warmup temps
  112. converting from a bravo1 to a xz
  113. HP500 (carb) Exhaust
  114. supercooler
  115. Who has the BEST dyno?
  116. Transom Mounted 1 1/4 Pickup (pipe)
  117. What Drive 850 HP?
  118. Looking for Upholstery in Houston, Tx
  119. Can anyone help me find a Merc part # f/ 575SCI part?
  120. Dual water pickup with high x demension?
  121. Sending Units
  122. Oil by pass valve GenVI
  123. fair price for m3 prochargers???
  124. Yet another trailer brake thread....
  125. Mpi 502
  126. superchiller for 525sc
  127. Bravo hesitation when shifting into gear????
  128. Clean-up Special
  129. KILL (barnicle)BILL?
  130. Bent Crank ??
  131. Can't get the friggin ink of my sunpad!!!
  132. F/S Bravo 1 24P Prop
  133. Engine remove and replace
  134. Help Crane Cam.what Is It?
  135. Went 96.2 and blew the outdrive
  136. What actually happend when I reversed oil hoses??
  137. Tach Problem
  138. Gimbal Bell Housing Repair....Opinions !
  139. hot off the Mill iol cooler mtg brkts
  140. What props work best on TRS's?
  141. #6 prop loosens
  142. WOT Speed and RPM Loss
  143. Custom Electronic Panels
  144. Drives - Paint or Powder Coat?
  145. Still up in the air about heads
  146. Remote Oil Filter HELP
  147. 500efi spare parts??
  148. Pro's vs Con's...Conventional vs Synthetic
  149. EFI Gueru's
  150. Bravo 1 drive oil change procedure
  151. Top Gun transome angle
  152. Prop advice/5 blade
  153. Rebuilt Engine Help Needed
  154. Mounting of power steering cooler
  155. Anyone ever shorten a flame arrester?
  156. cam choice?
  157. amazing salt vs fresh
  158. speedmaster prop diameter?
  159. x dimension on twins
  160. OK! Ok! Ok!
  161. I need the wirring diagram for a gps speedometer
  162. Mariner Optimax 150 to 175 Upgrade.
  163. need a ZZ502 camshaft.Part#12366543
  164. Repairing Gel coat????????????????????
  165. 502/500hp Through Prop exhaust
  166. Installing MSD Ign.
  167. Guage and supplier of Marine grade wire
  168. Correct prop ?
  169. TRS to Bravo Conversion
  170. Seeking Spare Ignition Module
  171. Procharger pullies
  172. 500HP carb clone
  173. Dirty Drive Oil
  174. Overheating problem
  175. engine pre oiling systems
  176. Needs some help here guys.....
  177. 525sc cam specs
  178. Gaffrig starter lockout switch where...
  179. Carrera 24 fuel tank/removal issue.
  180. MSD high vibration coil
  181. 28 Profile Cat
  182. More HP for HP 500
  183. pro charged 502 mpi w/high oil temp
  184. Lots to Learn!
  185. 496 still poppin at idle????
  186. Merc Silent Choice Problem
  187. Oil Temps / Pan or Cooler?
  188. Cams and Desktop Dyno
  189. HP 500 Missfire and Sputturing
  190. Gil Exhaust Air Pump-Circa 1994?
  191. 708-cubic-inch, all-aluminum engine for marine use
  192. Corsa Captains Call
  193. Houston Prop?
  194. Have Twins And Ya Loose One ?
  195. Converting Wet To Dry Headers
  196. 502 Mag cam change?
  197. TRS Parts
  198. Motor Running Hot...Still.. Circulating Pump?
  199. Can I run my CMI tube top headers dry?
  200. Oil Filter Study
  201. Quick and Quiet too Loud
  202. good outdrive shop around CT/LONG ISLAND area?
  203. Trailer won't back up . . .
  204. Charging system??
  205. Motor Overheated, will a loose hose clamp cause this?
  206. Now What?
  207. Water Circulating Pump--How do I Test
  208. Water pressure gauge conversion to elec.
  209. Bravo XR's?
  210. SC600, PFM,Superchiller kit, wanted
  211. Has anyone changed out a race fairing ...
  212. Add On Hydraulic Steering?
  213. desperately seeking Gen VI flywheel for cast crank 454/502
  214. oil pres. issue, advise needed
  215. Transporting your boats
  216. stupid question
  217. changing throttle/shifter controls
  218. Oil Thermostat
  219. 500 EFI Modifications ???
  220. Need help in determining if this 377 Cubic inch will work in boat
  221. bravo gimbal bearing removal
  222. How Hard Can It Be?
  223. Raylar Upgrade
  224. Engine Knock ...
  225. Paging Glassdave....
  226. Swimplatform options
  227. Motor running too COLD?!
  228. Sonic Cavitation
  229. Prop Questions and lift
  230. Fuel gauge quit working....
  231. 327 to 355/383 ???
  232. How accurate is this ?
  233. Whats the next step
  234. Drop Down Bolsters
  235. Driver Bolster blows fuse
  236. Pair Of Used 25p Mirage Props For Sale
  237. "Newbie" salt water flush question
  238. #1 Alpha Impeller Installation...And Now No Forward
  239. Prop Advice. ,,,,,,,please
  240. mefi 3
  241. What size prop????
  242. Merc Sterndrive failure - Alpha One
  243. 496 HO compatibility with 1989 454 Mag
  244. Bypass Valve
  245. X dimension?
  246. understanding prop pitch?
  247. How do I get ~450hp out of Merc 454 -95?
  248. 40 seconds to get out the hole
  249. plug wire looms
  250. Extension Boxes with a Pad Bottom, Notch Transom
