PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 [167] 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Updated 300x gearcase?
  2. Battery Question !
  3. gear drive instead of timing chain..
  4. Having trouble finding the exploded diagrams for K-planes?
  5. Question for GeoGraphics INC
  6. Buffing Imron?
  7. More Questions about drive showers
  8. Need Advice-Clear Coating My Boat
  9. gear ratio vs. prop pitch
  10. 38 top gun and big power
  11. drive shower mounting
  12. Plug color
  13. Trailer bunk replacement question.
  14. Gimble Housing
  15. Standoff boxes on awesome cat?
  16. Multiple Battery Charging
  17. To notch or not to notch?
  18. Blown fuse or worse?
  19. Hinge pin plates for bravo 1
  20. Mercruiser pn# needed for k-plane
  21. how to rig a 30' cat with a single drive
  22. Superchiller Plumbing
  23. What Manley valve is this?
  24. Is my water circulating pump dying??
  25. HELP!!!!! No Sea Water
  26. Kaama Drive Ujoint Seperation
  27. HP500EFI and Whipples: Change gears or props, or both?
  28. Question about tips
  29. 502 MPI rebuild
  30. Two To One Splitter Gear Boxes
  31. Stupid human trick. Sold trailer, boat is on it..
  32. dana marine
  33. Info on Whipple Supercharger Systems
  34. spark arrestor base
  35. Bravo XZ drain plug washers (or not)
  36. 4 blade stern lift....why?
  37. Aftermarket exhaust acc. bracket question
  38. Help me identify my motors!
  39. Qusestion on 350MPI
  40. To Boost Reference or not to Boost Reference?
  41. Need Lambo V12 service Specs...
  42. Gen 4 vs Gen 5 or 6
  43. AN fittings and hose sizing..
  44. trs drive max hp
  45. Prop Guys
  46. GL-4 or GL-5 for Bravo's
  47. SBC Vortec Head Upgrades
  48. A question for the PROP SHOP PEOPLE...
  49. Simpleton question on mech fuel pumps
  50. RPM Limits?
  51. 1996 7.4 carb intake gaskets?
  52. HIGH COMPRESSION normally assperated
  53. Small block head porting question for JimV or other porters.
  54. Blowers
  55. v6 headers
  56. Bravo Wing plate prototype
  57. Lathan Marine rams & mounts for TRS
  58. O2 Sensor
  59. modifying headers
  60. CMI vs Gill
  61. what distibutor?
  62. Need some help - How high is too high for water pressure?
  63. Resetting 555 Mercury Codes?
  64. Bilge Paint
  65. B-max/xr
  66. cam selection help
  67. Saltwater Engines
  68. xr drive ex box and a drive saver.
  69. A little more power from 454/502
  70. 468cid vs 454cid.. How much HP difference?
  71. Pulleys for 500HP
  72. procharger
  73. XR Pinion Gear Wear Problem??
  74. Seeking Bare 454 Block
  75. new engine in the future
  76. Bulk Head fittings??????
  77. Drive Shower Choice
  78. Exhaust Suggestions
  79. Valve/spring retainers/locks tech...
  80. 468 vs 454 vs 502
  81. Replacement fuel tanks
  82. alt/ps low mount brackets
  83. cam and intake question?
  84. Ignition module swap for blower?
  85. 500 hp's
  86. Best MI Motor rebuilder . . .
  87. Converting Inboard to I/O
  88. winter boating
  89. Prop shaft
  90. merlin heads
  91. Whipple Users thread deleted
  92. Tech is not dead, it's just resting!
  93. Gutted Exhaust Tips??
  94. Crossover and thermostat housing install??
  95. Whipples for 700hp/torque???...
  96. Engine value???
  97. Cam specs?
  98. prop for 27 Fountain
  99. water pick-ups in tabs ?
  100. Exhaust for 500HP
  101. Trying to get a little more power out of my 572
  102. What do you think of this BBC combo?
  103. Vacuum Secondarys ???
  104. Vacuum Pumps
  105. Holley carb power valve
  106. Rebuilding Trim Rams
  107. Coming soon- Camless Engines?
  108. 36 Outlaw/HP500's, top speed
  109. Rod Length?
  110. World Class Marine Hydraulic Steering?
  111. K-planes For 675.00
  112. Bravo Out drive Questions
  113. another question for dennis
  114. Rebuilding SSM#3's
  115. Desk Top Dyno Questions
  116. Raising compression by milling heads
  117. 36'Turbine cat? (help!)
  118. Electric over hydraulic brakes
  119. Slipping Top Cap on Blackhawk Drive!
  120. nosecone problems
  121. How do you guys run your breathers?
  122. Demon carbs???
  123. SS ARP head bolts??
  124. Running at night dash guages change
  125. repower
  126. Could someone explain this please?
  127. Bravo 1 gear question
  128. How much force is on the top cover on the drive shaft housing
  129. CMi header gaskets
  130. wiring harness??
  131. Heads?
  132. Alingment W/extension boxes??
  133. 502 build up
  134. Look Under General Dissicussion ,group Rocker Sale ,for Prices
  135. Turbine powered eliminator (project)
  136. Tech Q & A has been DEAD lately...
  137. Free Downloads For My Homies> Merry Xmas... DYNO 2000
  138. anyone know where to get info\parts for an "Olson Marine" remote oil cooler?
  139. Serpentine blower belts
  140. props for a skater?
  141. Trailer recommendations.
  142. Mercury throttle question????
  143. Mirage Props Blowout/cavatation
  144. v6 to v8 swap
  145. ProCharger Guys, another question...?
  146. Engine Simulation Software
  147. power steering -- hydraulic steering
  148. Baja 272 engine hop up
  149. Holley 800 vs 850
  150. Is it possible to change the pitch of
  151. drive height on 32 skater
  152. Long Idles
  153. Dual Batteries
  154. "Winterizing" on the Gulf Coast. Other ways besides drop lite in engine compartment
  155. Steering Intallation
  156. Boca Speed Rails ???
  157. MERLIN vs DART HEADS
  158. 454-330 build up help
  159. Alternators
  160. I WAS RIPPED OFF ON OSO, BUY WARREN MILLER screen name HIGHPRIORITY
  161. Dart Pro 1 head thickness (FYI)
  162. What connecting rods are you custom motor guys using?
  163. Electric Fuel Pump Installation Question
  164. Vinyl / Boat Flooring
  165. How do you know?
  166. Roller Rockers
  167. MPI Short-Runner Intake Manifold
  168. How high
  169. 7.4 / 330 oil consumption
  170. 502 Mag Procharged Fuel Injector Service
  171. Kiekhaefer disassemble question
  172. Oil - Water Condensation
  173. 1996 7.4 Piston Rings????
  174. Anyone have parts for SB Chevy? 4.3 or 350
  175. Steering upgrade or not?
  176. Extension box on 24 Outlaw??
  177. Bravo Drive ID. Question
  178. Blower height??
  179. Trim on Throttle
  180. Easy ?? about 500HP's
  181. power band of 454 mag
  182. Head size for a 598" engine...
  183. Dennis Moore Book
  184. aluminum head and head gasket info needed
  185. Draining oil with Thermostat bypass
  186. 496mag (375)
  187. Valves and springs for HP 500 EFI
  188. Gas Fume Detectors ???
  189. The dirty (fuel foolish) 502 MPI
  190. How much boost can I run??
  191. oil cooler
  192. Prop Questions
  193. Carter seawater mounted pump question??
  194. What Outdrive do I have?
  195. 350 with water in cylinders ???
  196. 454 vs 502 reliability
  197. Bravo I Prop ??
  198. Whippled 540 EFI
  199. Anyone with labbed REV 4 results?
  200. Cam recommendation
  201. EMI Switchable Mufflers
  202. camshaft pressure bleed off vs. compression ratio
  203. Thermostat replacement
  204. Bravo 1 Question
  205. Drive Oil Reseivor overflowing
  206. Reprogramming EFI Computer MEFI3
  207. need valves
  208. Main Bearing Failure - Thrust Surface
  209. The devil had kids
  210. IMCO Powerflow Reversion Questions
  211. whats the white stuff
  212. 454 Mag MPI Hop-Ups
  213. Full Cover for Velocity 280.
  214. HP500 EFI Dyno Question
  215. Portable GPS to feed GPS speedo?
  216. Oil temperature
  217. Dry Pipe Questions
  218. I saw drive oil in my bilge
  219. I have a stupid question...
  220. pistons in the 377 scorpian merc motor.
  221. ext box removal
  222. Extended Warranty????
  223. OT-hp estimation
  224. need info on bb-cylinder head part no:.....
  225. Dry Stainless
  226. Happy Thanks Giving To All
  227. To all of you awesome Offshore fans.....
  228. Need Engine Info
  229. the devil within......
  230. Honda Generator Model EU2000i
  231. Engine ventilation Q about 28 Cigarette?
  232. 2 Question - out drives and bottom paint.
  233. Turbo's
  234. turbo systems for bb-chevy
  235. Meltdown #2...not quite !!
  236. Another AO Question
  237. Alternator mounting
  238. compression reading on 454mag
  239. Bravo Trim switch wiring diagram??
  240. 496...500efi
  241. Vortech EFI Maxflow Power Pak?
  242. Engine pulleys
  243. procharger and thermostats
  244. Paging Dennis Moore!
  245. Alpha drive HELP
  246. OT- need info about nitrous
  247. Silent Choice Question
  248. what is the lenth of a bravo drive??????
  249. Helpful tool to get at side mount nuts
  250. TRS experts????
