PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Mayfair add on steering kit
  2. 2000 502 Gen VI Issues - Fuel Injection or No Fuel Injection - Rebuild Questions
  3. trying to figure out what cam
  4. trying to figure out whay cam
  5. Anyone know what speaker size came in Baja Hammer?
  6. windless system, anchors away
  7. 225 Outboard
  8. 500efi intake on a 502mpi what is needed to make it work?
  9. vapor separator issues
  10. Lets talk about roots blowers.
  11. Scarab 22 Trim Tab Question
  12. Arias Pistons VS JE Pistons
  13. What removes carbon deposits?
  14. Water Reversion?
  15. Simple prop question???
  16. Where does everyone order their Marine perfomance parts?
  17. Is a cavation plate really needed w/ 5 or 6 blade Props?
  18. Any difference in a marine 502 gen 6 and a standard gen6 502?
  19. Gear Ratio vs acceleration/speed
  20. Which intake gasket to use?
  21. Any way to prevent corrosion on aluminum intake?
  22. Where to get corsa exhaust parts?
  23. Garmin hooked into Smartcraft?
  24. Trying Q&A looking for the A on a GIL Q
  25. belt size/length for hp500 or other bbc with larger pully setup
  26. merc 525sc engine oil bypass valve
  27. What is correct cam end play for Gen VI, and how do you set it?
  28. Donzi 26/28ZX closed cooling questions????
  29. 79 31 excalibur weight???
  30. scarab iii manuals
  31. Confused - my new oil rings are much thinner than originals
  32. Bravo XR Broken top cap stud
  33. Foil Stickers
  34. oil pump pickup choice
  35. Power steering fittings
  36. Dart Heads 320 Race or 325 Pro 1
  37. Hyd steering advice
  38. Dana marine trim tab question.
  39. Merc Racing 1075 dyno video
  40. cat re power
  41. Prestige Motors/ to be recommended?
  42. Need Great HEAD advice (509) MAG
  43. 383 Street Engine / balancing issue
  44. Help with a procharger spacer PLEASE!
  45. Opinions needed......should i straighten the bottom or not?
  46. W/B 02 sensors
  47. Custom engine name plate
  48. CMI Air Cylinders
  49. K plane transom bolts
  50. What blocks do I have in '93 Fountain?
  51. 35' Fountain carpet
  52. Best sounding Marine subwoofer. 10 or 12?
  53. This might be a dumb question
  54. 2 stage KE waterpumps and Sportmaster LWP help...
  55. JR Marine Template
  56. Need GPS Speedo feedback, What brand.
  57. new 800 cfm from holly jetting
  58. Metal spray crank repair?
  59. 1997 scarab 29 ft
  60. 1997 scarab 29 ft
  61. More On Engine Oil
  62. Bearing fitment for proper clearance
  63. 555 CU IN Blower
  64. V-6 Module ?'s
  65. bb heads
  66. Gil long tail riser on 454 GLM Manifold.
  67. bolster seats
  68. Fuel valve
  69. control handle upgrade
  70. tapatalk
  71. 26" wellcraft scarab
  72. Ethanol is it as harmfull as they say?
  73. Porpoising probems on a 34 Eliminator Eagle
  74. how to determine indicator cable lengths?
  75. bob madera/marine kinetics
  76. 28 obsession cat
  77. more power
  78. 575 Induction
  79. Intake Manifold Help
  80. Prop: Polished or Not
  81. 496mag to 500efi
  82. 500efi price
  83. number stamped in front of block
  84. Gasparilla Invasion
  85. Whipple upgrades on 700 merc
  86. High-Perf PCM Calibration for HP525 ?
  87. mech tab indicators
  88. Chevy 540
  89. Ever use nite shades paint
  90. steering question
  91. Imco BBC Engine mounts or full offshore mount
  92. Small block - vortec or aluminum heads
  93. Which head gasket for a 4.280 bore?
  94. Drop in power 600-700hp
  95. Looking to get a idea what a bow cover would cost
  96. Looking for parts
  97. Looking for ideas
  98. Cam specs....opinions
  99. How to clean out powers steering pump?
  100. Cobra 1100 blower motors
  101. cam for 525
  102. sitting blue 525....
  103. boost at 6250 ft altitude
  104. Oil Pan for a Gen VI 502
  105. HP 500 carb jetting w/525 cam
  106. 525 hawk (BoBo build) Take 2
  107. Replacement Rocker Switches w/ print
  108. Bilge Wiring Issue Formula 382 - Challenge to any electrical geniuses out there
  109. Canvak waterproofer
  110. A boat designed for a 23 Mirage Plus and a complete overhaul and repower
  111. When to upgrade steering?
  112. leak down test
  113. merc ITS steering
  114. Vacuum gauge installation 500hp carb
  115. How to test manifolds
  116. gaskets
  117. "What's New In Piston Rings"
  118. torque or horsepower
  119. Looking for a 24/7 project
  120. Avatar
  121. Liberator ?
  122. TRS SS long pipes bravo conversion?
  123. 575SCI Head Specs
  124. 525 Hawk low budget (BoBO build?)
  125. spray paint for outdrives?
  126. Donzi 26ZX engine cover electric motor....
  127. MEFI 4B controller
  128. Cool Fuel
  129. Help with Gen VI circulating pump with IMCO cover
  130. Somewhere to get a full cover made in WI?
  131. Anchor holder?
  132. Whats my 454 Merc???
  133. Hours before rebuilding DPX600's
  134. Boat survey
  135. Let's talk thermostatic oil cooler sandwich adapters!
  136. Hydraulic Steering Addition
  137. McLeod Actuators
  138. Forged 454 crank work in 502 block??.
  139. Preparing for SuperChargers
  140. Boat survey
  141. whipple kit for 496,what do you guys think
  142. Prop Dyno Questions...
  143. Baja Steering SEIZED UP !!!!!!
  144. What do you glue carpet down with?
  145. FelPro 1211 or 1275 gasket?
  146. valves ?
  147. Help! Need to locate trim switch
  148. 509 whipple sidemount blower set up
  149. california to wi shipping any help
  150. merc 1075 cam,s
  151. need some hp525efi service manual info
  152. Audio- 6.5" vs 7.7"
  153. Tinting windscreen
  154. Triple 700's
  155. Cam Thrust Plate
  156. Who checks fuel injectors and $$
  157. RPM Loss/ MSD/GPS Turns off/Fountain
  158. Hvm supersucker
  159. Crane hi6 ignition box
  160. Shore Power Install
  161. 575 sci diag plug
  162. Best carb for procharger?????
  163. what cam for 454 mag
  164. What cam for 454 mag?
  165. 525 efi fuel pum and cooling question
  166. Bearings - dirt or oil starvation - need expert opinions, please
  167. best exhaust manifold style?
  168. how much for these 496 builds?
  169. Allen wrenches/keys storage?
  170. 496 Crank
  171. Best cam selection?
  172. Envision Boats
  173. Help, coil and plug wire for upgraded 500 efi
  174. Composite Dist. Gear
  175. procharger v groove pulleys
  176. electric fuel valves ?
  177. Stock 454 carb replacement...use quadrajet or switch to Holley etc
  178. Whats a 502 block worth
  179. What a 502 block worth
  180. small block vortec head maching
  181. 572 talldeck fit ment in older icbm
  182. Rooster tail
  183. 76 formula f-20
  184. Can a radar scanner be repianted?
  185. What bearing to run for 489 build
  186. P&D factory Logo
  187. gen VI oil pickup
  188. Diamond Performance OSO Discount?
  189. supercharger carb questions
  190. Best place to buy Merc Engine rebuild supplies
  191. Stereo speaker question
  192. manifold - riser replacement
  193. any reason not to by Mayfair steering?
  194. Small block fuel pump thoughts
  195. 525 efi help
  196. 350 mag mpi engine upgrade options?
  197. 81 merc 260 powersteering removal
  198. Installing new motor with trans help
  199. Pictures of single TRS mounts ?
  200. blower
  201. B&m 250 blower to m3 sc ProCharger
  202. Does anyone make a 15 to 25 thou head gasket or a 400sbc
  203. Climate controlled boat storage in KC
  204. dry exhaust
  205. blower
  206. My Boat Engine Shop, I need help on Air Compressors??
  207. CMI Tails.....pressure test???
  208. 496 ecm help
  209. flame arresters?
  210. Aluminum block in boats ??
  211. superchiller cooling
  212. Quick question on Bravo please. twins, ear loading
  213. Dana Power hinge problem
  214. k plane template
  215. Whipple 3.3 to 4.0 or twin 3.3 upgrade
  216. Looking for throttle mounted trim switch info
  217. Stereo, Subs and boxes help needed
  218. what are the "wings" for on the k-planes
  219. 502mpi v belt setup to serpentine setup like 98-00 502 mpi's?
  220. 502 6 rib serpintine to 8 rib for my procharger?
  221. eBay headers? Anyone have experience with them?
  222. EXHAUST TIPS: Straight or Angle Cut?
  223. thoughts about running an aluminum water pump
  224. Can i use a flat tappet cam in a roller block
  225. 509 600hp 9.5cr dry exhaust 32 fountian
  226. Want to add a on board batt charger
  227. Mcleod bolster seat repair/ adjustment?
  228. What Would 50 # of TQ and HP Gain Get Me?
  229. sce cooper gasket
  230. Boring a gen V 454 bowtie 4 bolt maint to .120"?
  231. Do you get nervousness when you see " 0 hours on rebuild"
  232. The squish, or quench thread..
  233. EMI Thunder exhaust
  234. Fuel Pump Question- 500 EFI vs 502 mpi
  235. 500 EFI Fuel Rail Schrader Valve question
  236. Blow thru carb....chill at idle or no??
  237. Total seal gapless top ring cyl.wall finish question
  238. Baja 36OL 525EFI Rebuilds and Upgrades
  239. Anyone Tried Extractors?
  240. 496, Gen. 7, engine oil cooler line removal? Safety relief valve in the block?
  241. outdrive switch kiekhaefer
  242. Kiekhaefer 380 help
  243. Causes of tight wrist pins and scuffed pistons ?
  244. 454 Rebuild - Advice?
  245. NXT Drive - 250 hrs - pull it or not
  246. 500 EFI Valve Springs
  247. Safe Continuous EGTs?
  248. eletronic engine sequencer ?
  249. 525 Whipple
  250. Amber like material in exhaust
