PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Thru hull exhaust hose getting hot on one side!!! Help!!!
  2. Read my plugs
  3. Who can modify the tune in a factory Mercruiser EFI ECM
  4. 496 MAG HO Overheat Alarm Faster After Raw Water Pump Rebuild...
  5. Mercruiser 500hp efi: Rocker Bolt cracked ...
  6. 496 HO Fuel pump issue?
  7. Bbc help
  8. 496 no start electrical issue
  9. Mercuiser External Ram (TRS)
  10. New to boating and have a couple of question
  11. 98 454 mpi with prochargers fuel issue
  12. ECM 555 Locked?
  13. 2005 Nordic Heat questions
  14. Looking for a wiring diagram for 14 pin 496ho
  15. Fueling issues!?! Help!
  16. GM 049 head valve seats
  17. 500 efi
  18. Manifold Restrictors Recommendations
  19. TRS Starters Grinding
  20. 98 mercruiser 5.7 Carb start no run
  21. Smartcraft Waterpressure sender isues on 600SCi!!!!
  22. 525 SC Head gasket Or??
  23. Quad O Ring for Fuel Line Cool Fuel System
  24. Donzi Blackhawk engine ID help
  25. Calling 496 gurus. Fault 36 - Sea Pump block/high pressure
  26. Envision boat construction question
  27. Gen 5 454 to gen 6 454
  28. 88 7.4 Oil Change
  29. 496 shut down
  30. HP500 white smoke from exhaust
  31. 454 mag mpi shutting down under load
  32. Wet transom, okay to run for one season?
  33. Chargecooler plumbing
  34. Quadrajet designed for 454 Mag on 330hp engine
  35. Drive and trim cables
  36. 1983 scarab 300 prop pitch
  37. 2004 Baja H2X Loud Beep
  38. 2004 Baja H2X Loud Beep
  39. oil for 575sci
  40. GEN VI 502 MPI Timing
  41. Any Donzi 38ZR (Staggered) Experts Out there? I Need help.
  42. 496 Ho Impeller change out
  43. Recomendation for a great tech to perform head job on 525's in Texas
  44. Oil out the exhaust
  45. Whats everyones thoughts on Ceramic Coating
  46. Comp ultra pros
  47. Cracked 502 block
  48. cooler heat range plug for supercharged 502 mag mpi with stock iron heads
  49. Engine misfire
  50. 02 575sci which one is the oil temp sensor
  51. 502 mag mpi dies for unknown reason
  52. Intercom System
  53. Temps
  54. Hydromotive prop instalation
  55. Installing Mercruiser Exhaust in Volvo Penta Setup for BBC 454
  56. Can anyone give me some guidance on putting Safety's in the Holley HP system?
  57. Quicksilver 48 13704A41 23P Hub Question
  58. No throttle response
  59. mercruiser 350 to 383 stroker, 2mph gain??? what gives.
  60. Need volvo 496 injectors
  61. Mercury 500EFI Blue Motor Running Poorly
  62. 525 EFI wiring pin outs
  63. Corsa Exhaust subsitute
  64. 2018 Loto shootout results??
  65. 600sci rebuild cost
  66. 700sci Supercharger Belt Spring Tensioner - Whats the correct GM Part Number?
  67. Mercury Scorpion 350 DTS Hail Mary need help!
  68. Please Read My Spark Plugs
  69. through transom water pickup placement
  70. Engine heating
  71. Motor Issues, Pulled Plugs and Look Unused?
  72. Engine Cutting out
  73. 40hp Evinrude
  74. BBC 489ci oil cooling
  75. Yanmar diesels. More power!
  76. Stallings extension boxes- can it go straight shaft?
  77. Help on 2003 Fountain twin 6.2s
  78. First Mistake Of The Season
  79. Help on 1998 fountain 38 SC
  80. Has anyone ever used L29 vortec heads on a carbureted 502
  81. Carburated 355 hard starting and stalling
  82. ARP Rocker Studs for EQ320 Heads
  83. Corsa exhaust cutouts , again !
  84. 496 HO starboard exhaust burning hole
  85. Dyno testing eddie marine manifolds vs headers
  86. Info needed Supercharged Mercury Racing 500 EFI (blue motor)
  87. Will Hot Sauce strip wax?
  88. 1996 26 Scarab 454mag issues and experiences.
  89. Power steering pump problem
  90. Having trouble locating a marine surveyor in Davenport IA, any recommendations?
  91. Xs-power headers
  92. What are these spots in my exhaust manifolds?
  93. Turbo Wastegate Help!
  94. 500efi won’t fire!
  95. Hard shifting on 1997 Bravo 3
  96. Mercruiser 5,0 mpi- rough idle/stalling ecm 555
  97. Creepy steering twin BBC/Bravo
  98. M150 Motec Tuner
  99. cooling water pressure with Alpha 1
  100. 700 Mis range crap out
  101. 280 k plane oil fitting question
  102. PSI testing cyclone headers
  103. Oil thermostat systems
  104. 1997 Fuel pressure problems - help me understand
  105. I want to borrow a edelbrock proflow 90 mm throttle body for dyno testing
  106. Bravo 1 to Bravo 3X swap
  107. CMI E-top LS headers
  108. Slow trim pump? 87 Formula Mercruiser Alpha
  109. Bilge Pump Operation
  110. 454 mag rectangular port head specs?
  111. 8.1L Surging Help (Video)
  112. 98 454 Mag Mpi mid range missfire
  113. ignition switch cover
  114. AERO MARINE windshield?
  115. alignment
  116. 525EFI cam sensor
  117. Keel guards on cats??
  118. Pulling mercruiser bbc?
  119. question for fuel injection guys or any pro auto techs
  120. How to seal the riser on a Merc 330
  121. shouldered bolt
  122. Slow starter - BBC
  123. How to detect Detonation without knock sensors?
  124. Vibration
  125. Where to dump excess water?
  126. Who makes Steering hose in Stainless???
  127. What is this?
  128. What part number for EST distabutor for marine (voyager)
  129. 900hp 10-71 540
  130. Bravo One Replacement Advice
  131. Weird Electrical Battery Issue
  132. 525EFI questions
  133. 496 key on beep
  134. Outdrive oil line
  135. Re jetting quadrajet carb
  136. 496 Mag Ho Spark Plug Wires
  137. P/S pumps
  138. Mercruiser carbs
  139. Battery Load Test
  140. Take Off Parts
  141. Aurora VS 721 Clear bottom treatment.
  142. cnc motorsports short block
  143. Cabin configuration of the old Scarab 300's
  144. Max overlap with these risers
  145. New Member looking for some help
  146. ****Need Help**** 496 MAG HO CAM Specs
  147. Jetting Opinions - Pics inside
  148. Anyone ever try the BBC trick flow intake manifold? 540-565 ci
  149. Mercury 700 blower belt cross reference
  150. 600SCi Coolant Temp. sender
  151. Mercruiser 7.4. 400hp cyclone. Carb specs.
  152. Port side engine/drive vibration
  153. last minute advice - cutting transom for tail pipes
  154. 525EFI No spark.
  155. pan gasket MK IV
  156. Looking for BUP
  157. Valve guide clearance question
  158. Question: Anyone Know a 30' Cigarette Hull Weight?
  159. Summit cam calculator- anyone play with it?
  160. Char-Lynn steering helm - can’t find number
  161. Engine scan hours not adding up
  162. 525sc pulley sizes
  163. Fair price to r&r engine on a 242?
  164. Cigarette Cafe Racer prop choice
  165. K-plane template
  166. Corsa exhaust issue
  167. Bleed ITS steering system
  168. Repowering with a 1994 Gen 5 7.4
  169. 496HO, fast beep and voltage drop
  170. Holley HP EFI Knock Sensor Tuning
  171. Jersey shore Surveyors
  172. Kiekhaefer controls ball bearings fell out
  173. Bowtie 10.2 MKIV
  174. Bravo xr drives
  175. Smart craft transom replacement, trim limit switch
  176. Corsa Captains Call Solonoid
  177. 540 block Raylar
  178. What Sealant or Adhesive for Cabin Hatch Windows
  179. Dry exhaust / reversion question
  180. Remote Oil mount - Vertical HP6A
  181. dual cooler bellhousing
  182. Merc 525 EFI Whipple build
  183. Need help with 8.2 Ho DTS rigging Kit!!!
  184. 600SCi Misfire....
  185. Need advice stat- filled block with water!
  186. Eddie Marine exhaust flap rattle
  187. New pipes!
  188. 525sc
  189. What bbc rods?
  190. 383 conversion
  191. Getting a 454 mag gen V running again
  192. 177 Tension Spring
  193. Reversion - Should I be worried?
  194. 889275T Fuel Pump Assembly
  195. Tbi engine intermittend squirting
  196. mild build 454
  197. Help with 26ft enforcer
  198. Smartcraft help
  199. Tachometer and oil pressure needles jumping around above 3300 RPM - Anyone have this?
  200. 7.4 mpi timing issues
  201. Mercruiser Overheating (so am I)
  202. Interior in Pennsylvania
  203. CMI header dimensions
  204. Engine check up
  205. Mercruiser Cool Fuel 3, mint housings, DIY threading?
  206. Donzi 38/35 ZR
  207. 469 ho cam swap, and lots top end speed
  208. Missing coolant flow restrictors
  209. Fuel injection 502
  210. 2 temp sensors?
  211. VP performance suggestions
  212. S pipes and water reversion
  213. Not so good find on my 502 MPI
  214. Intake water distribution
  215. cutting jacketed exhausts
  216. Main Bearing Dilema
  217. Velvet drive 72c fluid capacity
  218. Clamp on silencers
  219. What am I looking at here
  220. 500efi questions
  221. Whipple Upgrades on 700SCI Engines
  222. Corrosion at trim tab position cable fitting
  223. Water flow
  224. Weiand 177 Spark Arrest Air Filter
  225. Oil Question???
  226. Teague custom cams
  227. 575 sci fuel system upgrade
  228. Polishing Headers?
  229. Need help with an A/F issue on new build
  230. HP upgrades for 280TRS x2
  231. Intercooler fitment with weiand intake
  232. oil extracting units
  233. silent choice
  234. ILMOR MV-10 Top end rebuilt
  235. Cylinder Head info/Specs??? anyone?
  236. More HP and prop blowout
  237. How much HP can a original seawaterpump mounted fuel pump take?
  238. DUI distributor
  239. Ignition Wiring Help
  240. Trans cooler dumps
  241. Black widow 30???
  242. Big block hardware differences
  243. Merc 454 Gen VI 10 pin help
  244. A wire diagram for a 35ft cigarette 1978
  245. Top mount starter jamming.
  246. 540-565 intake question
  247. water hose
  248. 280 K plane install on Formula 312
  249. CMI Air Actuated Mufflers
  250. Supercharger Pulley
