View Full Version : General Q & A
- boostpower usa ?
- bilge pump recomondation
- water pickup
- hp600sci to hp700sci conversion
- 496 upgrade
- Cast Iron versus Aluminum Heads
- Trim on handle only works one drive
- riser length for cam
- Bilge Pumps 101
- Dana marne throttles/shifters
- Manifold spacers?
- Cigarette 20' HP425 update
- lightning exhaust
- Bennet tabs?
- Overheating 454 Mag Bravo Gen IV
- CD Ignition
- Oil pressure gauge
- lookin for new boat
- Trouble Shifting into forward
- recessed style cleats before the days of pop ups
- Raylar small block
- motor parts quote needed.
- Whats the Difference between Bravo drive couplers??
- pushrods needed
- LS engine exhaust?
- Stnd. CMI tails Wet to Dry Conversion
- Mounting Twin O/Bs On 24' Banana Boat
- good one !
- Intake off Gen IV 454 420hp
- cracked vinyl
- gasket set
- 2003 8.1 Mercruiser Horizon (No Fire 2,4,6,8)
- Livorsi Mechanical Indicator Adjustment
- Hull Blueprinting
- 500EFI to 575SC Conversion
- Moving the motor forward.
- Anyone running wideband o2 sensors?
- merc 500hp is that at prop or flywheel
- GM Technician
- Whipple or Pro Charger ?
- standard crane or summitt roller rocker???
- BB exhaust manifold id
- CHEAP ADIDAS SHOES HERE,just kidding-Help with hose sizing
- How do I hotwire a Thunderbolt IV?
- crane gold roller ???
- 420trs Blower upgrade
- Wanted 525EFI valve covers
- raylar with headers
- Bow Lights
- Fuel Usage Triple Engine
- Bow Lift..prop rotation
- engine oil
- cable trim tab indicators
- wire connector
- Oil temp sender location
- Is it reversion, if so how?
- 502EFI's
- Bravo steering how do I know if Ive got a Saginaw or a Brazilian connector
- GM crate 572 motor
- SS competiton gauges
- 572 Supercharged Engine build
- Pressurizing/vaccum testing Bravo 1
- boat will not start!
- k Tabs
- Pro-Charger on a 496...
- low water pickup
- k plane bolts
- tall valve covers needed ???
- genIV cam selection
- Corrossion Protection?
- Size box for sub?
- Paging Axapowell
- how many volts
- Fountain electrical question
- Plugs, Timing jets and Dyno
- Steering
- 700 sci problems?
- 575sci Blower Question....
- 502 impeler efi part number
- Cleaning & care of fiberglass hull bottoms
- cheap voguejordan shoes
- Staring problem??
- Any GM techs?? Preferably in South FL??
- Exhaust
- Gear Driven starter for boat?
- 525EFI Timing Question
- hydraulic steering question
- oil/ps cooler and filter system ???
- sterling's wb site
- Props for alpha's
- Blower for a 500hp
- Gen VI 502 block
- Are the 420's good?
- remote oil filter removeal
- 575 Sc Timing Chain set
- 3-5% Gas in the Oil, NA BBC MPFI
- oil pressure problem
- exhaust question
- 502 cylinder heads torque specs
- is there a replacement made for B&M/Merc water neck
- stern jack with bravo3
- oldsmobile 455
- What can you do to a 525efi
- Msd - Yes Or No
- Modifying AZM/HP500 manifold
- water pres
- 496, 6.2, 350 waterpump kit
- CMI headers
- Headers
- What Exhaust Seat Material?
- mercury ECU program upgrade
- Pacemaker 500EFI and 525 EFI
- Not Again!!! The Sonic Project
- degreeing a camshaft ???
- Dry sump ?
- 25 Merc water pressure
- Raw Water Pump Change over
- More hp out of a 500hp
- GM 572 crate eng.
- 575sci Compression....?
- octane on stock 454 Mags?
- stinger logo help
- stinger logo help
- advice for best solid roller cam 609
- FACE OFF movie(scarab, does it run almost a hundred??
- New HP ratings
- what carb is best
- 350or400motors for novaspyder
- Suggestions Please - Crank Case Venting
- plug number for the 525
- 502 Valves
- Turbulator ?
- Offshore 420 6.2L 426-437HP
- starting engine on test stand, no spark driving me nuts!!!
- help on 454 mpi eng
- Drive Temperature Sensor
- spark plug qeustion???
- What size sea pump?
- Blower motor oil temps
- Anyone Use Non Power Assist Hydraulic Steering for Single I/O
- Wiring harness wiring and kill switch wiring
- 174 blowers
- who makes the most hp from there headers
- zr1 motor in a boat
- fuel injector cleaning
- Oil coolers with stats
- Lost phone number
- Iron wear debris in oil filter
- 110 cc combustion chamber heads ???
- Help with Powdercoating
- What am I missing ??
- cigarette 31
- Big block starters
- Spectre Rigging
- valves
- HEI Distributor Shaft Diameter
- Oil in Puke tanks Blower motor
- Spun Bravo one drive coupler ????
- paging noise polution
- Merc Distributor Gear Removal
- Freshwater Corrsion??
- 502 oil pump question ???
- Pulse Plugs-anyone tried these?
- Gestimate on worth or 1983 21' superboat
- Nitrogen fire rings?
- exhaust valve clearance
- What roller cam spec. for 454 SS truck??
- prop shafts
- Intake manifolds
- Looking for reliable hp
- Mercury Marine Racing Placard
- "ROSS ARNOURGH" Of Cigarette?
- 500 Hp Whats It Worth
- No water flow .....
- IMCO Lower on a Nordic Rage
- 575sci warning buzzer after blower rebuild?
- 496HO Oil Line Fittings - American Std or Metric Threads?
- BEST EXHAUST MANIFOLDS FOR STOCK 502 MPI's
- 575 cam specs
- pistion rings
- plug gap???
- cold idle problem
- Looking For A Name
- Staggared Jetting question
- Need To Close Up Motor Well
- logistics question
- 575 sci's
- fuel injector
- Fuel hose to dash gauge???
- 496 Manifolds
- Tramson Bracket On A 24' Banana Boat
- Battery Tender?
- bennett tab location ???
- Hydraulic roller lifters
- what is a overspeed assembly on hp500
- Stock 502 Mods for efficiancy
- Vinyl wraps or subtle graphics?(Houston area)
- Replace or repair fuel pump.
- Wiring Diagram
- valve float / reversion ???
- carb rebuild kit for weber 4bbl
- 454 SS Truck engine
- intake manifold
- 496HO 1/2" Oil System Plumbing Upgrade to 5/8"
- Need a longer hose.
- What does the color mean ?
- Cam Too rough ?
- oval port or rectangle port ?
- Fountain Windshield
- Loking for 30' Stalker Cat
- intake manifold
- 496magho vs. 496magho ?
- Lubicant for Mechabical indicators?
- BIG CHIEF HEADS / Berylium exhaust seats-
- Ketten
- help!! fuel in my oil
- 500 Bulldog
- Merc. 500 HP info
- Converting 525EFI rods to floating pins...
- Cam vs Exh Manifold vs Reversion
- need advice more power from modified 525sc
- whipple SC kit
- fuel lines
- Jetting
- 496 sea water pump question!
- Thermostat
- CMI Split Elbow Tops?
- Water in Gimbal area
- 496 Mag or Mag HO Spark Arrestor?
- 496 Mag HO Cams
- trim sender wiring
- 496 Mag Ho Heads (2 sets)
- ValakoRaceHeads
- Changing oil in jet drive on 18 Seadoo Challenger
- Oil Drain Hose
- Northern IL outdrive repair
- 496 Mag Ho Rpm Sweet Spot
- Water circulating pump re-build?
- exhaust reversion
- Which Gauges Do You Recommend?
- Small Block rebuild
- Fogging fuel injected big blocks for winterization
- Melting flappers and exhaust hose
- Water Separator/Fuel Filter
- Straight bottom V's X dimension
- EMI exhaust
- mercury oil filter
- Cam and Lifters
- marine carb selection
