PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 [175] 176 177 178 179 180
  1. Replacement Gas Deck Fill... Help...
  2. CMI Etop pyrometer boss?
  3. HP500/500EFI cam grind?
  4. Ground Strap between motors???
  5. Ground strap between motors??
  6. wHERE IS THE SPEED'O" HOSE INSIDE THE TRANSOM?
  7. Hull Cleaner?
  8. Solid roller lifter life
  9. what grade of gas.
  10. Spark Plug Question
  11. Repitching a 19 to a 21 pitch prop
  12. Salt Away
  13. Found an alternate Optima Battery hold down
  14. Perko flush
  15. Marine painters in Ohio?
  16. Cam didnt make it!
  17. Anybody weld on extensions on there risers to prevent reversion?
  18. cam profile
  19. V6/V8 ignition module
  20. bleeding power steering
  21. ? for KAAMA
  22. Raw water pump impellers. Whose are they?
  23. Bravo drive shift problem -HELP!!!!!!
  24. Changing Bravo I drive Oil
  25. taking on water
  26. Labbed Props?
  27. Need Help With Prop Selection
  28. Dyno question
  29. Compression Ratios with Boost?
  30. Adjusting Throttle Linkage 454 Mpi
  31. ProCharger, Whipple or Vortech?
  32. TRS...Where are they most likly to leak?
  33. carb jetting and timing for alt.>6000
  34. Voltage drop, 29 Fountain.
  35. Checking full advance
  36. 502 Dyno numbers
  37. RPM drop after installing drive with nose cone
  38. Bravo gearcase swapping
  39. How do you change a Bravo Lower Unit ?
  40. will these props work?
  41. Effects of prop rotation on RPM
  42. Standard and reverse rotation?
  43. 33ft Fountain, How fast?
  44. Ignition wires? solid or....
  45. A Quick TRS Question?
  46. Tach Help
  47. carb. help
  48. 1998 5.7 350 LX info needed....
  49. 29 outlaw props
  50. Merc 200 carb year 2000
  51. Mechanical Trim cable ends?
  52. Life expectancy of these motors
  53. OT: Carb question for car tuners.
  54. degree your cam? Degree your balancer
  55. engine upgrade
  56. Has anyone seen gel coat check ??
  57. 502 MAG Timing
  58. Any body running a CompCams XM270 Roller cam on a SBC
  59. Engine guys, need your opinions on this...
  60. Carb gurus, please read.!
  61. Fuel Tank Problem
  62. 496HO Alarm Problem Fixed
  63. Still bad
  64. Water pressure with crossovers/t-stat
  65. Paint problem
  66. Blower lube oil ?
  67. Boggs down coming out of the hole??
  68. Rect Heads w/ oval intake
  69. Fuel Pressure gauge installation
  70. Procharger won't fit.
  71. Help, trim sender wires
  72. Setting 4 corner idle circuits
  73. Please Help - Bad 502
  74. Maybe supercharging
  75. steering
  76. overheat?
  77. Problems with oil blow-bye!
  78. 500 EFI and black oil
  79. Water temp on a Promax 300
  80. HELP! - Bravo Shift Cable
  81. Sea Strainer Installation
  82. Roller rocker clatter
  83. Do I really need Drive showers for my TRS?
  84. Trim Indicator??
  85. More transom soot out of starboard side exhaust
  86. Paging Whipple Charged!
  87. Whipples
  88. What Octane
  89. broken valve spring reversion
  90. Flush Muffs for Bravo one Performance drives
  91. stripped head bolt hole in block
  92. Hp500 Efi
  93. Who is running solid rollers?
  94. Battery mess
  95. Gas In Bilge - Help!!
  96. Props,Carbs, or Throttle Linkage?
  97. SHE RUNS!!, but...
  98. Rapid Fire # 1"s - HP500's - Gap?
  99. Mercrusier Fault Codes
  100. Adapter to run engines on hose
  101. Crane Hi6 tach problem fixed
  102. Damn leaky oil pan plug....
  103. Mobil One Gear Lube BLACKKKK
  104. 454 420 HO Carb Jetting
  105. How to dial in prop/motor
  106. TR TRS drive seal
  107. shift cable
  108. Bravo I props wanted
  109. Marine Holley 830?
  110. Destroyed impeller...again..
  111. fresh water hrs or yrs on stock Merc Manifolds??
  112. What prop for TRS??
  113. Trim Cylinders
  114. Kaama/ Twin Disk Oil Consumption???
  115. 502 mpi - raw gas out the exhaust
  116. Drive lube problems
  117. 502 mpi header gains
  118. water preaser cross over pipe
  119. Need help on Procharger carb set up
  120. McGuard prop locks with XR shaft
  121. tach buried andhumming noise??
  122. Supercharge or not?
  123. flywheel question
  124. KPlane indicator adjustment?
  125. Anyone use a return fuel line to tank?
  126. Full Hydraulic Steering
  127. Raw water pumps-will this work?
  128. What timing for blower motor ? and carb? ?
  129. Why did spark plug pop out ??
  130. 496 (Stroked 454)
  131. Water seeping down transom wall?
  132. What gauge alternator wire?
  133. Fuel injection
  134. Cast Aluminum Oil Pans Kiekaefer?
  135. Need rebuild Kit for Holley Carb
  136. ALPHA Question
  137. suzuki water pump
  138. Ignition Problem?????
  139. 502 engine
  140. Help :454 problems
  141. Steam Lines -- Pulled My Heads
  142. exhaust flaps
  143. Paging Tinkerboater, Troutly, Anyone Else
  144. Force trim pump
  145. Remote Oil filter & Cooler Plumbing
  146. Whipple prices
  147. electric fuel pump failures????
  148. My boat sucked the flush hose flat
  149. I finally got my fuel line right
  150. 502 repower/bravoIII 2.0 28P's question
  151. Procharger thermostat question
  152. NEED HELP PROPING 29FT FOUNTAINi
  153. How much HP is my motor making?
  154. Blower Carbs
  155. No tach with crane hy6
  156. Whipple Chargers & Fountain
  157. MSD 6M-2 Ignition Box - Need help!
  158. Aftermarket Oil Coolers?
  159. Labbed rt/left 23 Mirage Plus
  160. Engine Alignment Tool Part Number
  161. Replacing Oil Seal Behind Gimbal Bearing
  162. MPI Computers ECM
  163. Merc drain plugs
  164. Rev 4 or Bravo for bow lift?
  165. Nordkog DIgital GPS Speedo
  166. Exhaust caulk?
  167. How Much Horsie Power?
  168. AZ Speed k&N Billet filter
  169. Fuel Injector size?
  170. Engine Swap
  171. Merlin vs Dart who's better
  172. Quick Carb. Question!
  173. 502 Mpi Idle Speed
  174. oIl Plugs..Sending Unit
  175. After Market Efi Fuel Managment System
  176. Max engine rpm ?
  177. Arizona speed
  178. XZ drive vs XR drive?
  179. bravo3
  180. Engine Info?
  181. TRS Lower Gear's Material?
  182. K-Plane Braided Lines, Available?
  183. bravo outdrive oil change
  184. Trim in the wheel???
  185. Need Hawk 525SC info
  186. Fuel and Water Seperator?
  187. bravo 3
  188. How to polish aluminum skegs?
  189. 454 help please and thankyou
  190. mercruiser pulley
  191. Got my Crane ignition in.....tack wire???
  192. need more rpm out of my 502 mag mpi
  193. deadrise?
  194. Son of a ***** I have oil like chocolate milk!!!
  195. 454 mags; what's inside
  196. question for dustin whipple
  197. all 8 plugs sopping wet with oil and fuel?
  198. GIL Stealth Exhaust
  199. B&M blowers w/tstats
  200. 502 MPI Adj
  201. Carb jetting a 525sc
  202. "perma cool" oil thermostat
  203. Where to mount Fuel Pump Safety Switch
  204. What plug's does everyone run?
  205. Outboard bracket height??
  206. Drive numbers???
  207. Water pump question
  208. Cutting off angled tips, any Suggestions??
  209. VDO Bulbs where?
  210. Braided SS Fuel line
  211. Distributor cap part #
  212. TRS/SpeedMaster lower for sale
  213. Overheating during engine flush...
  214. valve cover breather?
  215. Changing Shifter/Throttle Set-up
  216. Fouling #2 on BBC
  217. More bow lift from those planing plates?
  218. Factory Rev Limiter ? on HP500EFI.
  219. Trim indicator cables
  220. Location of the EGT Sensor-Where???
  221. Learning??? Outdrive oil change.
  222. CheckmateF1, DK...K&N question
  223. Help - Mud Sucking Low Water Pick-ups
  224. Starter Problem
  225. 2 batteries?
  226. offshore engine mounts
  227. Sucking up sand
  228. Outboard bracket height ??
  229. Want to buy: marine wiring & supplies
  230. Perfect start to summer
  231. Another Alpha shifting problem
  232. Lining up grease hole on gimbal bearing
  233. F3LS's Problems...Two out of Three ain't bad!
  234. Alpha one inner transom plate
  235. fiberglass layup???
  236. Transmission Help Please!!!
  237. What jets for stock 454 w/750cfm Holley 4150
  238. Prop for Velocity 22
  239. speedo accuracy?
  240. Intake steam pocket bypass lines
  241. vhf radio question
  242. Engine Knock w/first startup of the year
  243. Quick Silver Prop
  244. Ran the boat today with the new closed cooling system
  245. Head gaskets weepeing...HELP!
  246. Corroded manifolds = engine rebuild
  247. Correct way to prep new hydraulic roller lifters/pushrods?
  248. Want to buy: shifter/throttle control
  249. K/N Filter setup?
  250. Exhaust Tips?
