PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Gimble ring rebuild
  2. Black Thunder
  3. Guess at HP gains from HP500 carb/intake package
  4. good battery location???
  5. 6.2 Horizon upgrades
  6. Shipping cost of a Motor.
  7. Lavey Craft 24 w Ilmore 625
  8. Bravo gear oil- where to buy a case/bulk?
  9. Can you change the rotation of 5.7 Mercruiser?
  10. Excalibur Hull ID Location
  11. # 4 drives ???
  12. Mobil 1 302 oil filter
  13. Spark Plugs
  14. Performance Question
  15. Hydraulic Helm question
  16. Engine Hatch Miror??
  17. Source for an Escape Hatch
  18. Conventional oil for break in
  19. Is there an upgrade from bennett tabs?
  20. Best clamp on mufflers
  21. IMCO Extreme to BMAX conversion question
  22. reporting and resizing heads- how much hp gain?
  23. Corsa Q&Q Exhaugst question
  24. Water mixed with the oil ?
  25. offshore x box games ?
  26. Senders for K planes
  27. Mixing S/S fittings with Bronze
  28. Anyone know of a windshield fabricator near St Louis
  29. Minor out drive dillema
  30. 280 or 380 k plane
  31. What Heads And Cam For Procharged 454
  32. merc 150
  33. engine coatings
  34. How much hp are 496's efi's good for
  35. Anyone got HP 500 intake
  36. Lake of the Ozarks Engine Builder
  37. swim step
  38. Cam Selection Help
  39. MPI mag wont start (#@%*@ing Thing)
  40. What parts to get?
  41. How much HP with this Combo?
  42. Shortened life of a 525 w/ a Whipple?
  43. lower unit shine
  44. Putting an EFI Whipple on an NA HP500
  45. Does anybody know what the name off the
  46. Difference between these two MPI/EFI intakes?
  47. 600SCi Upgrades
  48. Octane Boost.....
  49. Need a oil Pump Pickup Tube for 502
  50. 454/330 Compression Ratio
  51. Best motor package for $30000.
  52. Engine Builder - Greensboro Nc Area.
  53. Gibson Exhaust Turn Downs
  54. Trs Swap
  55. oil temp sender
  56. Konrad Ace Install Pictures?
  57. looking for info on a Monza hx-24
  58. Does anybody use rear plate style motor mounts?
  59. Hp 500 Rebuild
  60. Mesa Needs help with stolen #5s
  61. More SBC questions
  62. Stereo - wiring for 6 speakers?
  63. Headers ?
  64. Flywheel removal
  65. aftermarket marine parts?? fuel injection
  66. shorty on 25 daytona.
  67. Supercharging...Bigger injectors and a 2 bar MAP sensor
  68. Twin blower for wedge heads
  69. Stern Drive Installer
  70. 454 400/330 swap
  71. Drive Showers For TRS
  72. Bravo 1 question
  73. HELP HELP HELP 557CI PISTONS 4.375 stroke
  74. Ouch, need to re-build 400 sbc
  75. Flame Arrestors VS air cleaner????
  76. Injector size in a stock 500 EFI?
  77. Phone # for McGard that mngfr of sterndrive lock nut...
  78. TRS trim cylinder rams
  79. Air conditioning duct material
  80. Want to do trim tabs for Scarab 22
  81. Preparing to build a 502
  82. Who makes the best fuel tanks
  83. 575's w/ intercoolers by whipple
  84. Whipple charger question (525's)
  85. Shop Vacs
  86. 1999 Baja 29 project
  87. Anyone know the part number for ARP...
  88. parts reqd to switch from late to early style sbc's
  89. Any One Know Who Does Media Blasting In Sarasota-tampa?
  90. digital to analog box for 525
  91. MSD Crank Trigger Wheel Thickness?
  92. Sheet metal Intake manifold
  93. Reversion Question
  94. Trim Solenoid Help??
  95. Gas overflowing
  96. Bravo Modification
  97. Drake exhaust headers
  98. Aircraft wiring on a 500 EFI?
  99. Help with SBC identity
  100. Help, i lost the bolts to my hood on my 72 chevelle
  101. X dimension ponderings...
  102. #6 wet sumps, what kind of oil?
  103. Bowtie Small block heads
  104. Taylor Wires. Any tips on how to assemble?
  105. Whipple service
  106. WEBER carb?
  107. fountain executioner hinges
  108. 15yrs, 1100hrs, time for carb service?
  109. EFI Technology ECU reprograming
  110. ECU reprogramming
  111. Making lines for Mercury trim pumps
  112. question on early style SBC flywheels
  113. Imco Oil Change
  114. Globe blue impellers for the 496??
  115. Did your early 496 lose power after merc reprogrammed it for you???
  116. paging Big Block Billy
  117. Sterling Heads
  118. Bravo rebuild spec?
  119. 1986 Merc 350 (260HP) to 300-310 HP HELP
  120. Antifreeze 496
  121. After Market Heads?
  122. Autotron software
  123. Any Snap-On Reps
  124. EFI Upgrade Kit
  125. XR coupler ????'s
  126. Any good mobile boat mechanics in the Tampa Bay area?
  127. 2000 34' Powerquest Viper
  128. steering pulley size??
  129. KAAMA, 540's in my future
  130. meaningless rfi and gage fyi
  131. why not buy...............
  132. 454 stroked to a 489
  133. must have for garage
  134. 1" bravo Spacers
  135. Sea Strainer Installation
  136. merlin big block lifters.
  137. Fuel leak at carb inlet
  138. Power Steering Cooler?
  139. Bravo 1 muffs
  140. purging water from the 496 cooling system
  141. CMI Sport Tubes - Down turned vs. straight
  142. 502 Build Up
  143. mercruiser perfect sealant ??
  144. Any1 heard of a Switzer
  145. Drive Lube
  146. Mechanical gauge lines
  147. Boat Trailer Protection
  148. CMI Unitops and 502s
  149. Bravo rebuilding guru's ????
  150. messy 496HO spin on oil filter change
  151. Will a pair of HP500 GIL Manifolds fit a Merc. 454?
  152. SBC Cam Question
  153. Found why we breaking rockers
  154. Water pickups?
  155. plumbing fuel system
  156. alarm codes for 525 merc ?
  157. Quicknomad, can't reply to your PM!!??
  158. Aluminum Heads on Cast Iron Block
  159. Drawer Liners?
  160. paging nashpda
  161. oil cooler recomendation
  162. ECM Mods
  163. Procharger TekTalk
  164. Iron Eagle Heads Build Recomendations
  165. Gil Exhaust
  166. Help, I need a Gen 6 injector!
  167. Whipple or procharger for 7.4
  168. metal dust in oil
  169. Drive pump solenoid?
  170. Stroking an HP500 to a 540.
  171. #6 Swept back skegs
  172. Alternator problem/dead batteries....
  173. Mark IV fuel pump sprung a leak
  174. Rear Motor Mount
  175. engine builder says gear drine
  176. MPI to Carb ??
  177. 525 shut down ?
  178. Filter/Breather?
  179. Whipple Dealers - I need 2
  180. SBC Serpentine Belt Conversion
  181. GM 502 Piston Replacement
  182. What should piston to wall clearance be
  183. Help, need computer
  184. Pulling Sadle tanks
  185. Breaking Roller Rockers??????
  186. 496 mag-496h.o.------------------------
  187. Module Identification - How to tell?
  188. Ratcheting wrenches?
  189. HP capabilites of the #2 drive.
  190. Fuel tank question
  191. Looking for Vandy021
  192. 496 improvement options- narrowing choices down
  193. Balancing Rotating Assembly Question??
  194. Out Drive experts : What Kind of drive is this? Off 71 Pachanga
  195. Runing prop with caps removed?
  196. Need Some Help With My Shifter Parts...
  197. Need Good Motor Guy in So. MD
  198. engine room lighting
  199. 1" Bravo Drive Spacer Studs
  200. Merc SBC gurus?
  201. Spark plug type for 502 EFI
  202. Cross-over install
  203. Which Nose Cone
  204. Spark Plug Wires for Mercruiser SB
  205. oil capacity
  206. Oil Temp Sender thread size
  207. Torque Ratings for Optimax
  208. Some supercharger ?'s
  209. 1994 Baja Bandit Question
  210. Shifter replacements
  211. Blower experts please advise fuel system requirements for Procharger M-1
  212. Prop Questions Hydromotive-bravo
  213. Shift interrup 6.2MX
  214. My SBC Upgrades I have settled on. What do you think?
  215. 2" shortie on a 04' 29 fountain?
  216. Can you run two oil coolers in series on a Gen 6 502?
  217. Water Pump
  218. Head, valves, springs, retainers, etc.
  219. Fogging the 496
  220. Pulling The Timing Chain Cover
  221. 502 head bolts?
  222. Drive height, Baja 235 Force
  223. Supercharging ???
  224. dana exhaust
  225. Exhaust Discoloration?
  226. BBC heads Fit 396 ?
  227. Trim Tabs for Scarab 22
  228. Mercruiser Recall (496 MAG)
  229. early fountain executioner
  230. 525efi dead in 85 hours!
  231. engine lift????
  232. 502 Mag MPI cam???
  233. Kaama oil pan help
  234. Does anyone make a better than OEM intake manifold for a 350 EFI Motor?
  235. What to do
  236. upgrade 454 mag carb.
  237. bad main bearing
  238. 2 Pc. Valve Covers
  239. Thunderbolt ign Rev Limiter ?
  240. 496 belt
  241. 300hrs 500 EFI's
  242. Bravo drive guru near Chicago/Rockford
  243. problems with 500efi
  244. Winterizing question - good enough??
  245. Real cheep and easy Mag air intake
  246. Found 400rpm in the 454Mag
  247. Hull blueprinting in Southern California
  248. help 261 liberator
  249. what do you do to kill time
  250. Need a Whipple recipe
