View Full Version : General Q & A
- supercharger
- hynautic turns ratio?
- Engine Dyno DTS ?
- Distributor gear question 454 to 502.
- Question: power steering and external hydralic steering
- throttle, shifter, assembly
- Speed Pro Piston Installation
- Gen V Cam in Gen VI Engine
- GPS handheld
- GPS speedo
- #5 to #6 on skater
- fuel pump blower motor
- Building a BBC
- roller lifters
- power steering cooler
- mallory 140 fuel pump
- Anyone running Wheelerpower shortblocks?
- Intake manifold water ports
- Question for Ray: Optional Lifter for Merc 496HO
- Weiand 177 boost??
- Intercoms
- 502 fuel rail
- Oil pan question
- MSD..... marine or no..??
- Fuel injection and altitude question
- stereo/amp question
- Thinking about 540 build
- Salt water corrosion?
- Crank mounted water pump on 420hp 454 conversion
- prop advise
- 706 Ci Dart Block?
- Another boat speaker Question
- Tall deck 427 into a 540?
- 7.4 Mpi
- ECU reprogram
- 502 Good Base for Upgrades?
- Change analog(Mag Mpi)to 525 SmartCraft?
- 502 Base motor questions. Intake/ Fuel pump Provisions.
- need a lil help!
- water pressure question-extra pressure blow off
- 454 Flywheel help.
- 500 EFI Refresh rates?
- sunpad question
- WHIPPLE (engine running temps)
- jl amp Question.
- innercooler
- Distributer question
- Blower Shop XR series NEW
- Vinyl Guy - Delray Beach, FL???
- Merc 496 lifter oiling issue
- mercruiser 5.0 question
- 427
- What heads/intake/cam setup for most hp out of a NA 540??
- merc. racing blue paint code?
- Quad rotor Whipple HP?
- Boost retard or locked out timing?
- offshoreonly LOGO Decals
- hours to expect on 350 mag mpi
- Has anyone personally installed a GM Marine 502 Base engine?
- chinewalking
- Fuel Injection on a blower
- Hydra sports question!!!!HELP!!!!
- Bbc Brodix Bp Bb-2xtra 355 Cnc In Need Of Valves!
- What Trim Fluid to use ? 30wt oil or Trans fluid??
- Will K-Planes make you faster
- External Steering: Stern only, worth it?
- BBC Valve Size
- Corsa Captains call diverters
- JR marine or Hill Marine Swivel shaft?? Difference?
- ps fluid
- Drake headers
- Can anyone provide Wiring Diagram for 5.7 Mercruiser 1985 with round harnesses
- Trim tabs 21 scarab excel
- Boost gauge necessary?
- Keith Eickert Lightning Performance Package - HP-600 EFI Kit
- What's the difference between GM Marine Engines & Mercruiser?
- 496 sea water pump question
- Annular Vs Downleg?
- Gernation V Cam verse Gernation VI Cam
- Electrical Question On GPS?
- What needs to be done to Imco SC drives at 100 hrs??
- Bearings
- OZ. piston for 600sci
- Head Gaskets
- Eliminator Performane ?? 20'7" V bottom with pad
- 496 manifolds on a 502?
- Panther's Pan
- What fuel pump?
- What is Bellows Adhesive?
- Timing chain or gears
- Bravo Drive stiff!
- Gm Zz502
- Trim tab mounting angles
- Where to buy CMI Headers?
- BBC crank turning socket
- Powdercoating
- Over seas shipping.. WHO TO USE?????
- 496 to 496 ho conversion
- Prop speed - Drive ratio vs pitch. Which is better
- Ecu
- Mechanical Trim Sensor Cable???
- Oval port intake
- Have you heard of BAD LIFTER BORES?
- Twin or single ram full Hyd steering?
- TRS Trim Sensors
- Hydraulic Steering Helms
- Running engine with power steering pump
- Would you even consider running a hydrolic cam?
- Moisture test
- Ideal Bearing Clearance
- Whipples on 496 H.O's
- 575 SCI Head specs.
- SSM VI service in MN or WI ?
- copper oil tubing lines ???
- Looking for a closed cooling kit
- Best Intake BBC gaskets with Merlin Intake?
- Garmin 440 GPS install HELP!!
- air dock boat lifts
- Ultraflex Engine Hatch Lifter - Repairable???
- Whats the best air compressor to get?
- Depthfinder install question NEED HELP!!!!
- Water hose connection help (serpentine) 454 / 502 mag
- Increasing Compression
- Scat engine components
- Clarion CMD6 Head Unit
- Water in Power Steering
- Barry Grant Mighty Demonsss????
- Cam help for an x-575 SCI
- 6.2 MPI Camshaft specs ?
- 525 efi Headers Leak Issues
- HP 500 Compression
- VHF Radio
- Will a 454 seapump bracket fit on a 350?
- northstar 557 gps?
- Will this motor be any good in a boat?
- HP500 Valve Springs, which ones?
- gen vi roller cam bolt lock plate
- supercharger throttlebody
- 496 HO Engine Cowling
- Bondo or something on intake ??
- Bottom Blueprinting
- roller rockers
- 383 Rotating Assy.
- Drive Couplers....
- 1:1 lower gears for #5 SSM
- Shift bracket wire question.
- Twin INBOARD Sport/Cuddy
- Installing Amps under rear Bench (Over Heating)
- remote oil filter adapter???
- whats next? looking for future up grades on 454
- rinda merc tool
- movie question
- 454 magnum exhaust
- 502 with blower, how many hrs before adj valves?
- 1075 SCI and Transmission?
- Adding fuel injection
- Which exhaust ?
- 4" stainless - reducers and 45's
- Dumb twin engine question
- Bravo "y" pipe removal
- Alpha to Bravo swap, what to expect
- Oil sandwich plate ???
- Best subwoofers
- Bravo outdrive install question
- Holley Vs Demon?
- Lake cumberland Marine???
- merry xmas to all
- Alpha/bravo transom assembly differences
- 496 to 525sc conversion ???
- Short drive shafts
- safe to run our boats/trucks now..gotta watch
- DART PRO 1's are the 119 or 121 cc
- REV Control for TB-1V Ign.
- 500efi throttle body
- Coupler Question
- 496's and TRS drives?
- 525sc stalls when trying to engage gears
- Need New Tow Vehicle
- Alt Charging ?
- acrylico
- sea water fuel pump ???
- Mercruiser Shift Cable Mount Bracket
- TRS Merc II Tranny Weight?????
- Can you run 87 octane in an Ilmor 625?
- CMI tails - HELP
- 525sc valve Springs
- 7.4 exhaust header fit 502/450hp
- Holley's (Cutting the Air Horn)
- Help On A 272 Sr1
- BBC oil pump ?
- BBC Canfield heads 320cnc or 350cnc? are the heads any good?
- Bravo prop's?
- Jabsco 43210 vs. Stock Mercruiser
- Mechanical oil pressure gauges
- Has anybody ever purchased Heads,Blocks from Cobra Power In Florida
- Prop Question
- Water pressure gauge and 496HO
- Mercruiser motor mounts! Were to find?
- Synthetic Oil in HP500
- Flushing Engines with fresh water and Dawn
- CURTIS Snow Plow (wont lift)
- marine jobs
- Question about Volvo Penta 454
- water pressure tubing
- Ilmor Vs. Merc Racing
- Custom Vents... Who makes them?
- Lets see some under the swim step exhuast
- 83 29 scarab
- MSD REV Control
- New Builds - What to expect???????
- riser question.
- building BBC 572 Supercharge need Heads DART/AFR 325/335/345/357cc
- Whipple side mount crank pulley
- Neebie here with a problem...
- Stellings on a Cig
- corsa exaust
- 496 HO Throttle Body Question
- DISH NETWORKS or DIRECT TV ????????
- Life expectancy 500 EFI Engine & Bravo XR drives
- Thinking about putting a blower / procharger on 383
- 1989 21 ft scarab
- K-planes???
- What oil pan to use?
- Coil Over Plugs, Anyone using them?
- Single Engine Twin Drive
- water pressure gauge
- Best upgrades to a stock 502?
- Factory rods BBC
- Intake Manifold Removal. Prying for help
- Knock in a 496mag?? Bogus temp sender alarm??
- Proper Compression for HP500
- Swap 351 to 302 w alpha one
- water pressure
- Bravo VS Trs exhaust HELP
- 502 Wipple/Upgrades?
- Where to get my Supercharger Rebuilt
- #6 plug-in transmissions
- small blocks or big blocks?
- Auto start on diesel?
- 454 Tall deck question
- Life span of Iconel valves
- need help with whipple install...
- 502 MPI top end rebuild options??
- hynautic cylinders
- Tell Tale, water line/side dump? (so you know its getting water)
- Blueprinting
- brt 27
- Helm and cockpit pictures.
- Carbon Fiber Vinyl pros and cons
