PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. Best Gauges/ Indicators
  2. Reversion with mild cam???
  3. Identifing an HP500
  4. Steering Problem ??
  5. 575 SCI fuel filter?
  6. Right X-Dimension for 23' Nordic Viking
  7. differance between oils.
  8. problem with Eldebrock carb
  9. gen 6 454 block-1037 gasket question
  10. Silent Thunder Exaust
  11. Lots Of Food, Fun & Prizes< Come On!!!!
  12. Recipe for 800+ Motor
  13. Why not extended tip plugs on S/charger
  14. E-tec vs Verado 250 ???????????
  15. Flushing Bravo 1 with LWP
  16. 500 efi w/whipple life span?
  17. Flexplate Vs. Flywheel......and a stupid question?
  18. Merc575 Spark Arrestor
  19. Fuel Gauge Problem.
  20. spark plugs
  21. Which on board battery charger?
  22. EGT or AFR Gauge and Bung
  23. 502 Mag camshaft
  24. Twin Step Cat X Dimension Positioning.
  25. Quality
  26. Expert Kaama help needed!
  27. Super charger on 454
  28. " IAC Muffler"
  29. Stuck drive rams
  30. Correct trailer tire psi & torque?
  31. Non working GPS speedo
  32. HP increase between SuperChiller/Whipple
  33. Changing axle bearings w/ disc brakes?
  34. T-Bolt IV Question
  35. Where to find Mechanical trim indicators?
  36. Drive Centerline on Single Engine V
  37. merc module timing
  38. Water temp rising and falling
  39. slop in bravo 1
  40. need info on p&d hulls
  41. Engine Flushing
  42. 496 HO engine sound varies
  43. Shallow Water!!
  44. Blower on 500HP
  45. overheating and water in the bilge
  46. over heating problem
  47. Setting points BBC
  48. distributor/cam gear
  49. Belt tension
  50. towing a 29 outlaw
  51. 427BB in a boat??
  52. best oil to use
  53. Did this kill my alterntor?
  54. Bolsters need anchored to the floor better, any ideas?
  55. Stainless Marine HI-TORQUE manifolds
  56. SmartCraft install help
  57. 502 EFI Sudden High Oil pressure
  58. Drive Trim & K-Plane Fluid
  59. watercooled turbo's
  60. Bravo 1, gimble/transom pivot point pic?
  61. 454/MCM Trans/TRS - Died and Won't Turn
  62. Merc Thunderbolt 4 Modules And No Advance.
  63. water pressure questions
  64. Standard vs HP Gimbal
  65. winterizing my I/O
  66. Fuel Pickup Problem
  67. Header Leaking / What to do?
  68. Trident steering hose/reusable fitting
  69. Ran over rope! Won't start :(
  70. 575sci Heads On A 502 Mag
  71. Trim plate moving way too fast
  72. Intercoolers and water pick ups
  73. water problem
  74. WTB: HP Bravo Transom Assembly
  75. Pad bottom. What is it?
  76. 496 Oil Question
  77. BBC distributor upgrade
  78. Timing setting 525efi
  79. Mirage Plus 25p Prorps
  80. What should Fuel Pressure be at WOT?
  81. need to kno what camshaft
  82. Faucet washers for Boat sink
  83. 496 HO Guardian Mode
  84. harmonic damper
  85. 96 carb'd 500's
  86. 502 with a few shake down problems
  87. gps speedo problem
  88. Fuel from Exhaust
  89. How much?
  90. Gear Change Question
  91. Odd issue with 454 mag
  92. Need Help & Parts info
  93. 496 HO mufflers
  94. Ethanol and winterization
  95. 502MagMPI Surging at Idle when Hot
  96. 496 EFI upgrades????
  97. Found 44ft. Open Ocean Hi-Performance boat
  98. Reliability 1075's vs 700's
  99. Starter problems (starting to HATE this boat!)
  100. boat died, what happened ?
  101. manuals
  102. 496 Ho Steady Alarm
  103. marine machine sea strainer lid
  104. 454 Bravo 1 engine overheats on first run only then works fine
  105. Port motor hitting 190 and alarm going off!
  106. torque curve
  107. Testing Fuel Pressure (under load?)
  108. Code reader...
  109. Never seen anything like this.
  110. can you run S/M EXHAUST on a blower
  111. New to boating
  112. Interittent issue WOT
  113. Advantages of Race Fairing?
  114. 525EFI manifold??
  115. pinion nut
  116. Labbed 32 bravo 1
  117. Advance timing
  118. How big is the fuel tank on a 26 ft. American offshore?
  119. 454 Mag. Only running on 5 Cyl.
  120. Engine Alignment
  121. New Temp alarm units for Closed Cooling 454 Mags
  122. distributor vibration?
  123. so should i stay away from 460 ford with omc?
  124. Options for boats to fit in 25' garage
  125. Anyone have a Thunderbolt IV V8-24
  126. Kill switch
  127. plaese help guys waht should i put tomy 1994 formula 382 s
  128. Need diagram Imco elec fuel valve.
  129. SSM6 prop vent kit in need
  130. Bulldog / 7.4L TB-V Ignition Experts; Question
  131. Another water in oil question
  132. Does 500HP=?
  133. What size?
  134. 500 efi running hot HELP
  135. Engine Air Intakes
  136. Seperator filter
  137. 300 Tempest: max RPM on stock engine ???
  138. Aftermarket Couplers?
  139. engine backfire
  140. Oil Cooling
  141. TB-IV Rev Limiters??
  142. K-Planes goes down but not up
  143. Flywheel for 502/454 the same?
  144. Need advice; Top end oiling
  145. Fuel Pumps
  146. Holley 80552 problems
  147. 500 EFI Fuel Filter change:
  148. Lost ~17mph@WOT and ~10mph@3000RPM (cruise) Please any ideas?
  149. K-plane trim indicator cables.
  150. Will Headers interchange?
  151. When secondaries open engine dies
  152. Need part number for V8-20 TB IV ignition module..
  153. 496 Broke ?
  154. Hard To Shift Into Forward
  155. Strong Chemical to flush cooling jackets???
  156. Formula 357 power steering cooler mounting ?
  157. Diesel Day Dream?
  158. HP500 taller than 502 MPI
  159. Panama city fun run OCT. 13th
  160. HP Limit for Stock 496 Cast Aluminum Piston?
  161. hp / torque and trimming for speed
  162. What should I do
  163. turbo charged
  164. Oil squirt in Merc. 350 mag.
  165. Best Engine?
  166. Whipplecharger and t-stat
  167. 97 silverado, electric brake hook-up
  168. uneven rpm readings
  169. BBC louvered valve covers
  170. outlaw windscreen
  171. Aluminum Heads Paint or Not?
  172. Pulling outdrive question
  173. Cabin Fan install in 30 Outlaw -questions
  174. 225 Merc OB overheating
  175. How many powerups does it take for an ECU to re-set itself?
  176. Will this valve spring tester work with headers??
  177. Prop Info
  178. How to diagnose broken/weak valve springs...
  179. SAE J2005 and J1970
  180. Extension box or not?
  181. 312 Fastech
  182. Aero Tek With Cavitation/blowout Problem
  183. 525 SC's oil change
  184. cooling problem
  185. New to boating... questions (90' Sunsation Rocket)
  186. Looking at 87 Scarab Panther
  187. new pole
  188. belts
  189. LSX Motor In A Boat
  190. Higher Octane Gas?
  191. 500 efi upgrades
  192. Max bore for a "production" 502 block
  193. Idle control - Big cams and carbs
  194. Camshaft recommendations
  195. ECM3 to a 4
  196. Knock sensor ?..HP500 carbed
  197. 502 ci / 454 block ???
  198. 525 SC upgrade
  199. GMPP Ram Jet 502 vs Merc HP500/525 EFI
  200. MPI and morepower
  201. 27' Magnum
  202. State of Shock
  203. HP500 carb metering blocks
  204. Old Style Engine Syncronizer Light
  205. posting my avatar
  206. 496 ho/headers to lean?
  207. Turning props in?
  208. I'm Starting To Think I Should Take Up Basket Weaving
  209. I might be onto something
  210. Tach
  211. Engine cuts out when I hit a wave ???
  212. engine from Bravo to Alpha
  213. 502 Mag MPI, Max tq/hp?
  214. Arneson drives
  215. msd or carb
  216. Who has used non marine msd
  217. WTB- HP500 intake and carb
  218. Carb tuning help
  219. ignition help
  220. Ignition advance curve on 454
  221. Old parts
  222. Pics from Kemah this afternoon
  223. Sea Strainer w/ relief valve?
  224. Bravo One Problem
  225. Replacing Hydrolic Lifters
  226. spun prop
  227. Slow Yamaha 250
  228. Swap Cam with out pulling engine
  229. offset sterndrive
  230. 2 Stage Water Pump
  231. TRS alignment tool
  232. Nose cone, good or bad idea.
  233. how many pumps of grease in a bravo transom ass.?
  234. Oil temp too cold now oil pressure too low
  235. 300 X beeps 4 X's
  236. water wich wiring
  237. What is the CPS.. ??
  238. Walmart Drops Price On Mobil 1
  239. merc 377 scorppins
  240. vapor lock
  241. PCM, wiring ??? (Engine shuts down) ???
  242. good marine upholstry shop in Md. ????
  243. Any USED Plug-in #6 Transom assembly's for sale ??
  244. Deal On MR43T Plugs
  245. Anyone have feed back on Hardin Marine Cyclone Shorty Manifold?
  246. Red Zone Lifters
  247. fresh out of ideas
  248. ECM repaire
  249. Flame arrester
  250. 87 or 89 octaine
