PDA
View Full Version : General Q & A
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180
  1. teague pop up add
  2. idler pulley
  3. merc gear lube
  4. Hardin SS Exhaust Flappers......Alternative?
  5. Hydraulic Steering help.
  6. 500efi Saga Continues
  7. Timing question (setting initial/total)
  8. Roots blower top pulley not lined up with crank
  9. Merlin BB heads
  10. Engine builder wants $3000 more for Merlin block?
  11. Lets play the HP guessing game
  12. MSD Control Box wiring
  13. What are the chances of getting parts back from a engine builder
  14. Ilmor Oil Filter
  15. 502 harmonic balancer
  16. Any thoughts on how easy making power is?
  17. 572's with inter cooled 14-71's
  18. Compression numbers all over map on new , not yet broken in kongblock
  19. Marine Bluetooth 4.0 receiver
  20. 598 Engine Advise
  21. Valve springs
  22. Cylinder Head Volume: mercury 525 efi
  23. twin outboard V setup
  24. Is an air gap manifold needed?
  25. New 540 Combo
  26. Engine swap
  27. Anything to prevent where the outdrive "rubs" the gimbal ring
  28. Potential soft floor issue?
  29. Another Procharger needed ASAP!!!!
  30. 700 sci shift interrupt switch
  31. K plane sending units
  32. Valve seat materials
  33. 496 HO randomley turn off/on video
  34. Goodmorning from Italy!
  35. Clay Smith cams???
  36. What valves to use in EQ320 BBC heads?
  37. MEFI 4 to Nema
  38. 496HO problems looking for input.
  39. 454 oval port build results
  40. 2000 500EFI - Fuel Issues - need expert advice if possible
  41. Mrercury 700 dropping boost
  42. Converting from crossover to circulating pump.
  43. 4.3 Gl volvo ignition problem
  44. Afrs vs temp
  45. 38 ft mates cat. Aka cat scratch fever
  46. Dayton, Ohio
  47. Winterize with Super Chillers
  48. Jumping power hatch switch
  49. Motor Issue WOT 4000RPM
  50. 588 Idle Question
  51. New engine issue
  52. Alignment question with off shore mounts
  53. Waterjet system at transom of the ship hull
  54. SBC oil bypass question , reuse ok and orientation ?
  55. Rear Anchor
  56. Raylar 540 cu Short Block 496 upgrade ??
  57. holley throttle cable bracket
  58. What should a healthy vacuum reading be on 525 EFI?
  59. Exhaust manifold choice
  60. Couple videos for you guys
  61. I do believe I got bit by my purchase...
  62. Oil bypass question
  63. 496 Exhaust Risers on 6.2MPI's?
  64. Electric Hatch Actuator, Solenoid?
  65. What to do With My MK Cams
  66. DIY Winterization
  67. quick fuel carbs
  68. Drive setup on 30' Advantage
  69. Livorsi oil pressure gauge problems
  70. Some carb / intake info
  71. 509 MPI Starter
  72. Sonic Vendetta
  73. Help picking out a cam...
  74. Boat preparation for hurricane?
  75. Solid cam VS hydraulic VS short travel hydraulic?
  76. 4500 series intake that also has 4150 bolt pattern?
  77. facebook powerboat swap shop
  78. 2.3 on a 502
  79. Suggestions for a 35-38 cc under 300k?
  80. bell housing bushings
  81. Sealant / adhesive for sealing foam gimble gasket to transom
  82. Cleaning White Upholstery?
  83. Best Gel-Coat Repair
  84. Phone borescope...kinda cool!!
  85. Hardin Seaward 525 replacement exhaust
  86. Replacing Water distribution valve.
  87. Winterizing - battery maintenance
  88. 32 maelstrom
  89. Custom cam thread
  90. Fram XG5 502 MAG MPI & 20W50
  91. Would you rebuild those 500 efi with those readings?
  92. Merc Gen 3 cool fuel filter
  93. Need some help - Port motor not running
  94. Hydraulic steering
  95. How much reversion is too much??
  96. Gen1 Stainless MArine limitations??
  97. Four Winns Liberator 211
  98. Sc scoripion. Lots of questions
  99. Using freshwater flush port to winterize
  100. MEFI 4B CD or Download Needed
  101. 496 HO Question - What are these and how should they be adjusted?
  102. Give this 502/509 Combo Some Thought
  103. What Carbs would you buy
  104. Fighting a miss under load
  105. The curse continues... Brand new coupler slipping?
  106. Best Carb Spacer 4 hole or Open?
  107. Merc Smartcraft mpg... U.S. or Imperial?
  108. Water in hydraulic trim system
  109. Go badgers.
  110. US gasoline power beginner questions
  111. Heads/Cam or Supercharger?
  112. Water Traps in the Fuel Tank?
  113. best hole shot Trim tab position
  114. AFR numbers what's good and what's bad ..
  115. Bmax drives input
  116. gaffrig silencers
  117. 525 Edelbrock head
  118. 502 oil issue
  119. Setting the base timing on rebuilt 500 EFIs???
  120. 6.2 MPi
  121. Engine Air Temp
  122. Looking for engine builder in ct area
  123. Mercury 600SCI - Engine Fault - IAC Output
  124. Stainless marine exhaust converted to dry? Gains?
  125. Dyno... Marine trim VS Dyno (race) trim
  126. Upgrading fuel lines due to age and upgraded engine
  127. Repower/ long lock opinions
  128. Mercury 520 Performance upgrades
  129. 454 suddenly stopped, abruptly, would not even turn over. Took plugs out and
  130. Boat plugs out with pipe dope
  131. Boat plugs out with pipe dope
  132. Powerquest razor 22
  133. Aluminum heads
  134. Cam and valvetrain longevity....??? low duration high lift...
  135. Mercruiser 470 stalls after it has been warmed up. Wont idle under 2000 rpm
  136. Going from 5.0 to 5.7 or 6,2 SBC
  137. Opinions on rewiring engines
  138. Fluctuating engine temperature in my 2000 7.4 mpi Mercruiser Bravo 3
  139. 1075 sc cam in a 565 NA build
  140. How to clean oil coolers
  141. Need a boat brought to Florida from the NH area.....
  142. Mercruiser 7.4 LX MPI Intermittent Overheat
  143. Driving thru chine walk
  144. recommends on engine oil
  145. Lightning or GiL
  146. Alternator only charging one battery while running - Scarab 33 AVS???????
  147. Wow I heard of msd issues. But dam.
  148. How fast can I go
  149. 500EFI Help!
  150. Horsepower VS Torque
  151. What are you guys using for water PSI and vacuum line?
  152. Acceleration and efficiency
  153. Bravo 1 outdrive sagging help
  154. Spun Drive coupler (or whatever the proper name is)?
  155. Larson Senza Spectre
  156. 496 HO sounds much louder when cranking
  157. Anybody know where I can get a 500 EFI Rubber seal for Throttle Postion Sensor?
  158. Need Help finding Power Steering Pulley
  159. Typical places oil leaks occur in the port side rear of the engine
  160. smartcraft alarm question
  161. MEFIBURN tuning help
  162. Slight poping sound out exhaust. Comes n goes. See first post. Spellcheck
  163. Cause has developed slight piping ish sound.
  164. Faria gauges on early merc smartcraft
  165. SBC hydro locked, water in #1 cylinder
  166. 600SCi 5 beep alarm
  167. faria tach setting
  168. Loading up at idle
  169. water hose to helmut connection
  170. 500 efi dipstick loose
  171. 500efi help
  172. Water in oil.
  173. Turbulators for Gil exhaust
  174. AFR 325 flow sheets.... anyone ever flow these heads?
  175. Anyone run 108 LSA cams in boat before? 700 HP DYNO proven combos welcome...
  176. Worlds fastest boats
  177. late '01 496 HO poor idle/occasional stall in nuetral at idle only
  178. 350 Mag engine wake up
  179. 525 hp
  180. 32 fever steering cables
  181. Baja 232 Voltage Issue
  182. oil cooler with built in thermostat
  183. 2002 Baja 29 Outlaw Fuel Vent Question
  184. Header tube discolouring, what should I do?
  185. Wierd sea water hose problem
  186. How much timing advance should I run?
  187. Stainless Marine manifolds SBC power steering line in the way
  188. Loosing fuel pressure
  189. I'm cursed!
  190. Cams size
  191. shipping a outdrive
  192. 500 HP Intermiten Idle Issue
  193. show me your Fountain speaker locations
  194. 575 sci
  195. Older 575hp 540ci merc bulldog engine knocking
  196. 1995 502mpi won't start when hot
  197. New style and old style 525
  198. Bravo 3
  199. Detonated piston & blew head gasket. Now what?
  200. frictional losses of 4.25 stroke motor vs 4.0 stroke
  201. efi for supercharger.
  202. Reoccurung water pump failures...
  203. Mag efi
  204. Mercury 525 Rocker arm replacement
  205. Oil pressure flutter at higher rpms.
  206. Do anti-reversion dams work?
  207. Replacement steering Verado 400R
  208. Hydraulic Hatch Actuator
  209. Oil Pressure Bypass Valve Question
  210. slip %
  211. Pre-Filter Oil Filter Screen - YEA or NEY ?
  212. Power steering pump fitting Aeroquip?
  213. Catalyst elimination for "test purposes"
  214. whats the torq spec for bravo transom plate?
  215. Msd total timing procedure when locked out
  216. A little more Tinkering
  217. 502 MPI intermitant no start when hot.... not fuel prob
  218. Fuel Coming out exhaust
  219. Hammer knocking noise when in gear over 3000 rpm
  220. Will MSD digital 6 work with thunderbolt distributor?
  221. Holley Commander 950 mpfi won't fire!
  222. Thunderbolt V ignition, will big block module work on a small block?
  223. need part # for hose transom to sea water pump
  224. GM Fastburn heads, any experience with these?
  225. Weber carburetor
  226. new 540 water in oil
  227. Vessl View & DTS
  228. Push rod retainers.
  229. 5.7 timing with comp 270 cam
  230. CMI headers. Are they fixable?
  231. EFI Systems
  232. Impeller
  233. Chaparral Villian SLV Speed Capability
  234. Motor Issues
  235. procharged 454 Mag rebuild upgrades ????
  236. Heat exchanger help
  237. Rosella Oil
  238. converting my 350 cid merc. 320 efi's to carbs. what jet sizes?
  239. Plug for ?
  240. 500 efi 50lb fuel injector
  241. 502 mag loads up under load.
  242. Outdrive line help
  243. drive swap alpha 1 gen 2 to bravo one
  244. Blind mounting swim ladder? - 89 Baja 226 Islander
  245. Advantage 27' rear seat removal
  246. Where to get gaskets 5.7 mag gen +?
  247. Imco riser gaskets
  248. 502 build
  249. External steering on a B1 vs XR
  250. 496 intake manifold gasket
